Web Content Viewer
Actions
imageRUNNER 5055
Support - Multifunction
Specifications
Model Name
imageRUNNER 5055
Type
Monochrome Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Mono Component Toner Projection
Fixing System
Induction Heating Fusing System
Image Server Memory
Standard 1GB RAM + 40GB HDD (Shared)
Max Mailboxes Supported
100 User Inboxes, 1 Memory RX Inbox, 50 Confidential Fax Inboxes
Max Copy Reservation
20 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
1200 x 1200 dpi (available on certain page description languages)
Interpolated Resolution
1200 x 600 dpi
Halftone
256 Gradations of Grey
Letter
Up to 55 ppm
Letter R
Up to 58 ppm
Legal
Up to 45 ppm
Ledger
Up to 37 ppm
First Copy Time
3.3 Seconds from Platen Glass
Multiple Copies
1 to 9,999
Magnification
100%
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%Zoom Mode: Platen: 25% - 400% (In 1% Increments)
Feeder:25%-200%(In 1%Increments)
Acceptable Originals
Sheets, books, and 3-Dimensional objects up to 4.4 lb.
Maximum Original Size
11 x 17Max. Copy Size: 11 x 17Min. Copy Size: 3 7/8 x 5 7/8 (via Stack Bypass)
Standard Paper Capacity
Dual Paper Drawers (1,500 Sheets Each)
Dual 550-Sheet Paper Cassettes (550 Sheets Each)
50-Sheet Stack Bypass Optional: 3,500-Sheet Paper Deck
Manual Bypass
Maximum Paper Capacity
7,650 Sheets
Output Sizes
Cassette
Upper: Letter
Lower: 11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Bypass
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive, Free Size (3 7/8 x 5 7/8 to 11 5/8 x 17), and Envelopes Acceptable Paper Weight: 17 lb. Bond to 110 lb. Index (From All Sources)
Acceptable Paper Weights
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
30 Seconds or less from Main Power Off or Sleep Mode
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120V AC, 60Hz, 20APower Consumption: 1.92kW (Max.)Plug: NEMA 5-20P
Dimension
47 1/2 x 25 3/8 x 29 1/4 (1,207mm x 643mm x 743mm)
Weight
474 lb. (215 kg)
Estimated Toner Yield
48,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Single-Pass Duplex Scan Document Feeder
Statement to 11 x 17
Scanning Speed
Up to 100 ipm (Letter @ 300 dpi, Two-Sided)
Up to 77 ipm (Letter @ 300 dpi, One-Sided)
Capacity
100 Sheets (20 lb. Bond)
Paper Weights
One-Sided Scanning: 11 lb. to 32 lb. Bond
Two-Sided Scanning: 13 lb. to 32 lb. Bond
Paper Supply Options
Description
Paper Deck-AD1 (Opt.)
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
Dimensions
22 5/8 x 12 3/4 x 23
Weight
Approx. 65.7 lb.
Description
Paper Deck-AE1 (Opt.)
Paper Capacity
Paper Sizes
Paper Weights
Dimensions
22 5/8 x 23 1/2 x 24 1/2
Weight
Approx. 99.4 lb.
Output Options
Finishers Output Trays
Description
Finisher-AD1/Saddle Finisher-AD2 (Opt.)
Paper Weights
17 lb. Bond to 140 lb. Index
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement, Statement-R, Executive, Free Size (3 7/8 x 5 7/8 to 11 5/8 x 17)
Number Of Trays
3 Trays
Top Tray
Non-Collate Mode (Tray A): 250 Sheets (Letter, Statement-R,Executive)
125 Sheets (11 x 17, Legal, Letter-R)
Middle Tray
Non-Collate Mode (Tray B): 1,300 Sheets (Letter, Statement-R, Executive)
650 Sheets (11 x 17, Legal, Letter-R)Collate, Group Modes (Tray B): 1,300 Sheets (Letter, Executive) 650 Sheets (11 x 17, Legal, Letter-R)
Lower Tray
Non-Collate Mode (Tray C): 2,450 Sheets (Letter) 1,700 Sheets (Statement-R, Executive)
650 Sheets (11 x 17, Legal, Letter-R)Collate, Group Modes (Tray C): 1,700 Sheets (Letter, Executive)
650 Sheets (11 x 17, Legal, Letter-R)Staple Mode (Trays B & C): Tray B, Tray C: 1,300 Sheets/100 Sets [or 7 3/8 (188.4mm) in Height] (Letter, Executive)
650 Sheets/50 Sets [or 3 3/4 (96mm) in Height] (11 x 17, Legal, Letter-R)Paper Sizes: 11 x 17, Legal, Letter, Letter-R, Executive
Staple Capacity
50 Sheets (Letter, Executive) 30 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Any Corner Staple Double Staple in Right or Left Margin
Saddle Stitch (Center Staple)*
Paper Sizes
11 x 17, Legal, Letter-R*
Fold Type
V-folding Saddle-Stitch Tray: Saddle-Stitch Capacity: 15 Sheets (60 Page Booklets)
Tray Capacity: 25 Sets (1 to 5 Sheets) 15 Sets (6 to 10 Sheets) 10 Sets (11 to 15 Sheets)*
Dimensions
Finisher-AD1: 44 1/8 x 25 1/2 x 25 7/8
Saddle Finisher-AD2: 44 1/8 x 25 5/8 x 25 7/8
Weight
Finisher-AD1: Approx. 106 lb.
Saddle Finisher-AD2: Approx. 155 lb. Attachable Accessories: Document Insertion Unit-E1, Document Insertion/Folding Unit-F1, Puncher Unit-AT1
Document Inserters
Description
Document Insertion Unit-F1 (Opt. for Fin. AD1/AD)
Paper Weight
Insertion: 17 lb. Bond to 140 lb. Index
Folding: 17 lb. - 28 lb. Bond
Paper Sizes
Insertion: 11 x 17, Legal, Letter, Letter-R, Executive
C-Fold: Letter-R
Z-Fold: 11 x 17, Legal, Letter-R Folding Method: Roller Pressure Folding
Feeder Capacity
100 Sheets
C-Fold Output Tray Capacity: 40 Sheets Dimensions (H x W x D): 487/8 x 26 1/8 x 26 3/4Weight: Approx. 168 lb. Puncher Unit-AT1 (Option for Finisher-AD1/Saddle Finisher-AD2)Acceptable Paper Sizes: 11 x 17, Legal, Letter, Letter-R
Punch Method: Sequential Processing System (1 Sheet at a time)
Punch Type: 2 holes: (Legal, Letter-R)
3 holes: (11 x 17, Letter)
Punch Waste Capacity: Approx. 3,000 Sheets
Dimensions (H x W x D): 32 3/4 x 4 1/4 x 24 1/4
Weight: Approx. 15.9 lb.
Description
Document Insertion Unit-E1 (Opt. for Fin. AD1/AD)
Paper Weight
Paper Sizes
Feeder Capacity
100 Sheets Dimensions (H x W x D): 48 7/8 x 26 1/8 x 26 3/4Weight: Approx. 88.2 lb.
Fax Board
Description
Super G3 Fax Board-Z2
Applicable Line
Public Switched Telephone Network (PSTN)Connection Lines: 1Sending/Original Size: Statement to 11 x 17Receiving/Printing Size: Statement to 11 x 17
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds/Page
G3MR/G3MH: Approx. 13 Seconds/Page
JBIG: Approx. 2.6 Seconds/Page
Auto Dial Function: Address Book: 1,800 Destinations
Print Board
Description
UFR II/PCL/PS Printer Kit-R2
Processor
Canon Dual Custom Processors Type: Embedded Print Controller
Standard Memory
1GB (Standard) (Shared)
Hard Disk
40GB (Standard) (Shared)
PDL Support
UFR II, PCL 5e, PCL 6, PS3 Emulation Resolution: PCL 5e/6: 2,400 x 600 dpi (Interpolated)
UFR II/PS3 Emulation: 1200 x 1200 dpi
Postscript Fonts
136 Scalable fonts
PCL Fonts
80 Scalable fonts, 10 Bitmap
Interface Connections
10/100Base-TX (RJ-45), USB 2.0 High Speed
Print Controller Technology
UFR II: Windows® 2000/XP/Server 2003, Vista, Citrix MetaFrame, Macintosh® OS X (OS 10.2.8 or Later)
PCL 5e/6: Windows98/Me/2000/XP/Server 2003, Vista, Citrix MetaFrame
PostScript 3: Windows 98/Me/2000/XP/Server 2003, Vista, Citrix MetaFrame Macintosh OS X (OS 10.2.8 or Later)Network Operating Systems: Novell® NetWare® v3.2, 4.1, 4.11, 4.2, 5, 5.1, 6.5 (IPX/SPX) Windows 98/Me/2000/XP/ Server 2003, Vista (TCP/IP) Apple® Macintosh OS 8.0 or Higher (DDP) Solaris™ 1.5x, 2.5x or Later (TCP/IP)
Send Expansion Sets
Description
Universal Send Kit-F1
Sending Method
Email, I-Fax, File Server (FTP, SMB, IPX, WebDAV), User Inbox, Super G3 Fax (Optional)
Address Book Capacity
Max. 1,800 Destinations
Max. 5 LDAP Servers
File Format
File/E-mail: TIFF, PDF, PDF (OCR),*** Encrypted PDF, #Digital Device Signature PDF, #Digital User Signature PDF##
I-Fax: TIFF (MH, MR, MMR)Communication Protocol
File: FTP (TCP/IP), SMB (TCP/IP), NCP (IPX), WebDAV
E-Mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
Scan Density
100 x 100 dpi to 600 x 600 dpi, User Selectable Other Optional Accessories Workflow Composer-B2Access Management System Kit-A1Wireless Network Adapter NB-W1****Encrypted Secure Print Software-C1###Barcode Printing Kit-A1###Web Access Software-F1^Digital User Signature PDF Kit-A1^^Universal Send Searchable PDF Kit-A1^^Universal Send PDF Security Feature Set-A1^^Secure Watermark-A1HDD Data Encryption Kit-B2HDD Data Erase Kit-A1Expansion Bus Board-D2Remote Operator's Software Kit-A2Voice Guidance Kit-B1^^^Cassette-AB1 (Replacement)Tab Feeding Attachment-B1Copy Tray-L1Card Reader-C1Card Reader Attachment-C2Braille Label Kit-A1ADF Access Handle-A1Stamp Unit-B1Stamp Unit Cartridge-C1Staple Cartridge-J1Staple Cartridge-D2eCopy Suite imageWARE™ Suite Footnotes:
* Available with Saddle Finisher-AD2 only.
** 1200 x 1200 dpi resolution for PCL printing is not supported on Win9X/Me Clients.
*** Requires Universal Send Searchable PDF Kit-A1.
**** Requires Expansion Bus Board-D2
t Requires Universal Send PDF Security Feature Set-A1.
tt Requires Digital User Signature PDF Kit-A1.
ttt Requires UFR II/PCL/PS Printer Kit-R1.
^ Requires UFR II/PCL/PS Printer Kit-R1 for printing Web pages and PDF files.
^^ Requires Universal Send Kit-K1.
^^^ Requires Expansion Bus Board-D2.
ENERGY STAR Qualified
Awards
2007 BLI Highly Recommended
BLI 2007 Reliability Seal
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 5055 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
