Web Content Viewer
Actions
imageRUNNER 5070
Support - Multifunction
Features
Operating at 50 pages-per-minute (letter), the imageRUNNER 5070 is equipped with a 20GB Hard Disk Drive and 512MB RAM, providing users with exceptional productivity and reliability.
With a scanning resolution of 600 x 600 dpi, enhanced copy resolution of 1200 x 600 dpi, and enhanced print resolution of 2400 x 600 dpi, the imageRUNNER 5070 delivers superior quality or faithful reproduction of text and images.
Incorporating Canon's MEAP™ (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 5070 can be customized to meet unique business needs. Customized applications can run from the device's control panel, streamlining document workflows.
A color user interface panel and intuitively designed device drivers provide user-friendly operation for both walk-up and desktop environments.
With its standard Duplexing Automatic Document Feeder, the imageRUNNER 5070 makes quick work of multi-paged, double-sided and mixed-size originals.
Users can choose to add the optional Finisher-T1 or Saddle Finisher-T2 for advanced document finishing capabilities. The Saddle Finisher allows users to create folded booklets for paper sizes including Letter, 11" x 17", and Legal-sized paper. Each finisher can be configured with a hole punch unit for professional-looking documents.
Supports a host of Internet-ready capabilities, including the optional Web Access Software that allows users to call up Internet or intranet data right on the user-interface, and print Web Pages and downloadable PDF files when configured with the Canon print controller.
Incorporates Canon's IH (Induction Heating) Fusing Technology to significantly reduce energy consumption and improve productivity.
With a standard paper capacity of 4,150 sheets, which can be expanded to 7,650 sheets, the imageRUNNER 5070 has been designed to meet the high volume requirements of large corporate workgroups.
The Mail Box functions of the imageRUNNER 5070 serve as a centralized system for information-sharing, on-site document storage and print-on-demand applications.
Users can choose to add the Canon Multi-PDL Printer Kit-G5, which delivers printing capabilities with support for PCL 5e/6, PostScript® 3™ emulation, and Canon's UFR II (Ultra Fast Rendering) technology.
The imageRUNNER 5070 can be equipped with an optional Super G3 fax board for the ability to transmit faxes at impressive speeds.
With its Universal Send™ technology, the imageRUNNER 5070 allows users to scan directly into the device for distribution to multiple destinations. Advanced Send options such as searchable PDF and Encrypted PDF can be added for an even more sophisticated solution.
With Remote UI, features and functions of the imageRUNNER 5070 are controlled and accessed right from a user's desktop.
Through the Remote Operator's Software Kit, users in wheelchairs can operate the imageRUNNER control panel functions such as Copy/Box/Send/Fax from their laptops or personal computers.
Specifications
Model Name
imageRUNNER 5070
MSRP
15,500
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Mono Component Developing
Fixing System
Induction Heating Fusing System
Image Server Memory
Standard 512MB RAM/20GB HDD
Max Mailboxes Supported
1000
Max Copy Reservation
5 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
2400 x 600 dpi
Interpolated Resolution
1200 x 600 dpi (Copy); 2400 x 600 dpi (Print)
Halftone
256 Gradations
Letter
50 cpm/ppm
First Copy Time
Approx. 3.3 Seconds or Less From
Multiple Copies
1 to 999
Magnification
25% to 400% (Platen); 25% to 200% (Feeder); (in 1% Increments)
Acceptable Originals
Sheets, Books, 3-dimensional Items (Up to 4.4 lb.)
Maximum Original Size
11 x 17
Standard Paper Capacity
4,150 sheets
Manual Bypass
50 sheets
Maximum Paper Capacity
7,650 sheets
Output Sizes
Cassette
3 7/8 x 5 7/8;11x17
Bypass
3 7/8 x 5 7/8
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index
Bypass
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
Approx. 30 Seconds or Less
Exposure Control
Automatic or Manual (9 Levels)
Power Requirements
120VAC, 60Hz, 16A
Dimension
47 x 25-3/8 x 29-1/4 (1192mm x 643mm x 743mm)
Weight
Approx. 474 lb. (215kg)
Toner
Dry, Monocomponent
Estimated Toner Yield
45,000 Images (at 6% Coverage)
Drum
Amorphous Silicon Drum
Estimated Drum Yield
Estimated 3,000,000 Impressions
Feeders
Description
Duplexing Automatic Document Feeder (Standard)
Statement to 11 x 17
Scanning Speed
65 Sheets/Minute (Letter)
Capacity
100 Sheets (20 lb. Bond)
Paper Weights
13 lb. to 32 lb. Bond
Power Source
From Main Unit
Paper Supply Options
Description
Copy Tray-L1 (Optional)
Paper Capacity
250 Sheets (20 lb. Bond)
Dimensions
7-3/8 x 17-5/8 x 13-3/8 (186mm x 446mm x 340mm) (When auxiliary tray and auxiliary wire are extended)
Weight
Approx. 1.4 lb. (670g)
Description
Paper Deck-V1 (Optional)
Number Of Cassettes
1
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
Power Source
From Main Unit
Dimensions
22-5/8 x 12-3/4 x 23 (574mm x 323mm x 583mm)
Weight
Approx. 101 lb. (46kg)
Output Options
Finishers Output Trays
Description
Finisher-T1 and Saddle Finisher-T2 (Optional)
Paper Weights
Paper Size
Letter, Statement-R, Executive, Legal, Letter-R, 11 x 17
Number Of Trays
3
Top Tray
No-collate Mode Tray A: 250 Sheets (Letter, Statement-R, Executive)
Middle Tray
No-collate Mode Tray B: 1,300 Sheets (Letter, Statement-R, Executive) Collate and Group Mode Tray B: 1,300 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11 x 17)
Lower Tray
No-collate Mode Tray C: 2,450 Sheets (Letter, Executive) 1,700 Sheets (Statement-R) 650 Sheets (Legal, Letter-R, 11 x 17) Collate and Group Mode Tray C: 1,700 Sheets (Letter, Executive) 650 Sheets (Legal, Letter-R, 11 x 17)
Saddle Stitch Tray
Staple Mode Tray B/C: 1,300 Sheets/100 Sets (Letter,Executive) 650 Sheets/50 Sets (Legal, Letter-R, 11 x 17)
Staple Capacity
50 Sheets (Letter, Executive) 30 Sheets (Letter-R, Legal, 11 x 17)
Staple Positions
Corner/Double
Hole Punch
Puncher Unit-M1 (Option for Finisher-T1/Saddle Finisher-T2): Sequential Processing System (One sheet at a time)
Paper Sizes
Stapling Capacity
1 to 5 Sheets/25 Sets; 1 to 5 Sheets/25 Sets; 11 to 15 Sheets/10 Sets
Fold Type
V-fold
Dimensions
42-3/4 x 25-1/2 x 25-7/8 (1,085mm x 648mm x 657mm)
Weight
Finisher T1: Approx. 88.2 lb. (40kg); Saddle Finisher T2: Approx. 163 lb. (74kg)
Fax Board
Description
Super G3 Fax Board-R1 (Optional)
Applicable Line
Public Switched Telephone Network (PSTN)
Transmission Speed
ECM-MMR: Approx. 3.2 Seconds; G3MR: Approx. 13 Seconds; G3MH: Approx. 13 Seconds; JBIG: Approx. 2.6 Seconds
Data Compression
Standard: 8 pels/mm x 3.85 lines/mm; Fine: 8 pels/mm x 7.7 lines/mm; Super-Fine: 8 pels/mm x 15.4 lines/mm; Ultra-Fine: 16 pels/mm x 15.4 lines/mm
Memory
Approx. 8,000 Pages
One Touch Speed Dialing Locations
Address Book: 1,800 Destinations
Print Board
Description
Canon Multi-PDL Printer Kit-G5 (Optional)
Processor
Canon Custom Processor Shared
Standard Memory
512MB Shared
Maximum Memory
20GB Shared
PDL Support
PCL 5e/6, PostScript 3 Emulation, UFR II (Ultra Fast Rendering)
Interface Connections
Standard: 10/100 Base-TX (RJ-45),USB 2.0 High Speed; Network OS: Windows 98/Me/2000/XP, Windows NT 4.0/Server 2003, Solaris 1.1x, 2.5x or later, Macintosh OS 8.0 or later (PPD), Novell NetWare v.3.2, 4.1, 4.11, 4.2, 5, 5.1, 6, 6.5 (IPX/SPX)
Print Controller Technology
UFR II: Windows 2000/XP, Windows Server 2003, Citrix MetaFrame, Macintosh OS X (OS 10.1.5 or later); PCL 5e/6: Windows 98/Me/2000/XP, Windows NT 4.0/Server 2003, Citrix MetaFrame; PS 3 Emulation: Windows 98/Me/2000/XP, Windows NT 4.0/Server 2003, Macintosh OS X (OS 10.2 or later)
Other Features
Internal Fonts PS: 136 Scalable Fonts; PCL 5e/6: 80 Scalable Fonts, 30 Barcode Fonts, 2 OCR Fonts, 10 Bitmap Fonts Utility Software: Network ScanGear, Remote UI, NetSpot Console, NetSpot Job Monitor, NetSpot Resource Downloader, NetSpot Device Installer, USB Class Driver, Fax Driver, JBIG ImageViewer, Canon LPR 2, Canon NDPS Gateway, Canon Font Manager, Canon Watermark Add-in, DSE (Device Status Extension), Address Book Conversion Utility Other Optional Accessories and Utilities Accessibility Handle-A1, Barcode Printing Kit-A1, Braille Label Kit-A1, Card Reader-C1, Card Reader Attachment-C2, Card Sets, Cassette-AB1, Document Tray-K1, eCopy Suite, Expansion Bus Board-C1, imageRUNNER Security Kit-A2, imageWARE Suite, NetSpot Suite, Remote Operator's Software Kit-A1, Tab Feeding Attachment-A1, USB Application Interface Board-D1, Universal Send PDF Enhancement Kit-B1, Voice Guidance Kit-A2, Web Access Software-A1
ENERGY STAR Qualified
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 5070 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
