Web Content Viewer
Actions
imageRUNNER 600
Support - Multifunction
Specifications
Model Name
imageRUNNER 600
Type
Digital Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle
Up to 250,000 impressions/month
Image Server Memory
2.1GB Standard
Max Mailboxes Supported
100
Max Copy Reservation
2 Jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
1,200 dpi x 600 dpi
Halftone
256 Gradations of Gray
Letter
60 cpm/ppm
First Copy Time
6 Seconds or Less (from ADF)
Multiple Copies
1 to 999
Magnification
25% - 400%, in 1% increments
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books and 3-Dimensional Objects (up to 4.4 lbs./2 kg)
Maximum Original Size
11 x 17
Standard Paper Capacity
2 x 550 Sheets + 2 x 1,500 Sheets
Manual Bypass
50 Sheets
Maximum Paper Capacity
7,650 Sheets
Output Sizes
Cassette
Statement to Ledger
Bypass
Statement to Ledger
Acceptable Paper Weights
Cassette
17 lb. Bond - 110 lb. Index
Bypass
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
5 Minutes or Less
Exposure Control
Automatic or Manual (Text or Photo)
Power Requirements
115V, 60Hz
Dimension
44-3/4 x 30-1/8 x 31-3/8
(1137mm x 764mm x 795mm)
Weight
553 lbs.
Toner
GPR-1 Black Toner
Estimated Toner Yield
33,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Automatic Document Feeder (Standard)
Statement to Ledger
Scanning Speed
55 opm
Capacity
100 Sheets (Letter)
Paper Weights
13 lb. - 110 lb. Index
Different Size Originals
Standard
Power Source
Directly from Main Unit
Dimensions
5-3/8 x 25-1/2 x 22-3/8
(143mm x 646mm x 562mm)
Weight
46.2 lbs.
Paper Supply Options
Description
Paper Deck-C1 (Optional)
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Power Source
Dimensions
20-1/2 x 12-3/4 x 33
(519mm x 323mm x 583mm)
Weight
90.3 lbs.
Output Options
Finishers Output Trays
Description
Stapler Stacker Finisher-D1 (Optional)
Paper Weights
Up to 110 lb. Index
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
250 Sheets (All Sizes)
Lower Tray
2,000 Sheets (Letter)
Staple Capacity
Up to 50 Sheets
Staple Positions
Multiposition Stapling
1 - Top Corner (Any Corner)
2 - Side Margin (Book Staple)
Power Source
Dimensions
39-1/4 x 25-3/4 x 27-7/8
(995mm x 655mm x 708mm)
Weight
141 lbs.
Description
Saddle-Stitch Finisher-D2 (Optional)
Paper Weights
Up to 110 lb. Index
Paper Size
Statement to Ledger
Number Of Trays
3 (Including Saddle-Stitch Tray)
Top Tray
1,000 Sheets (Letter)
Lower Tray
Saddle Stitch Tray
900 Sheets
Staple Capacity
Up to 50 Sheets
Staple Positions
1 - Top Corner
3 - Saddle-Stitch
Hole Punch
3 Hole Punch (Left Margin)
Paper Sizes
Letter/Ledger
Stapling Capacity
15 Sheets
Fold Type
V-Folding Standard
Power Source
Dimensions
39-1/4 x 31 x 27-7/8
(995mm x 787mm x 708mm)
Document Inserters
Description
Post Process Document Inserter-A1 (Optional - for Saddle-Stitch Finisher)
Paper Weight
Paper Sizes
Letter to Ledger
Feeder Capacity
100 Sheets
Paper Folding
Description
Z-Folding Unit-B1 (Optional - for Saddle-Stitch Finisher)
Paper Weight
17 - 20 lb. Bond
Paper Sizes
Ledger Only
Fold Type
Z-Fold
Print Board
Description
Network Multi-PDL Printer Board-F1 (Optional)
Processor
MIPS R5000 200 MHz RISC Processor
Standard Memory
64MB
Maximum Memory
64MB
Hard Disk
4.2GB
Continuous Print Speed
60 ppm (Letter)
PDL Support
PCL5e, Adobe PostScript 3
Postscript Fonts
136 Fonts
PCL Fonts
45 TrueType®
Interface Connections
Ethernet (10/100BaseT)
IEEE 1284 (Parallel)
Token Ring (Optional)
Print Controller Technology
Compression and Decompression
PostScript Font Management
Resolution Enhancement Technology
Direct EPS File Printing
RIP-While-Print®
Font and Forms Downloading
Continuous Print™
Other Features
Access to Full Finishing Features
Internet Connectivity
NetSpot Supported
Spooling Support
Automatic Job Recovery
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 600 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
