Web Content Viewer
DISCLAIMER
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
imageRUNNER 6020i
With output speeds of 60-pages-per-minute and 600 x 600 dpi scanning resolution, the imageRUNNER 6020i is the productivity solution you have been waiting for. With Universal Send technology standard, the imageRUNNER 6020i eliminates the expense and burden associated with printing, forwarding and filing hard-copy documents. Incorporating Canon's newly developed MEAP (Multifunctional Embedded Application Platform) architecture, the imageRUNNER 6020i gives businesses greater control over costs and productivity by embedding diverse and customizable applications for a wide range of business workflow activities. The imageRUNNER 6020i streamlines workflow with unprecedented speed and unparalleled convenience.
Features
Operating at a rated duty cycle of 230,000 impressions per month, the imageRUNNER 6020i boasts one of the highest duty cycles in its class.
The imageRUNNER 6020i's Stackless Duplexing technology makes double-sided copies and prints at 60-pages-per-minute. It also supports paper sizes up to 11" x 17", and weights up to 110lb-index.
With its standard 256MB RAM and 10GB HDD, the imageRUNNER 6020i supports powerful, digital-enabled features.
With its Universal Send technology, the imageRUNNER 6020i can scan and distribute information to multiple destinations, including individual or groups of e-mail and Internet-Fax addresses, to internal Mail Boxes, to network or host folders, and to document management applications such as Canon imageWARE.
With its newly added Universal Send capabilities, the imageRUNNER 6020i has the ability to preview a document prior to sending and to register up to 5 LDAP servers for searching for e-mail addresses on a corporate server.
The imageRUNNER 6020i ships standard as a fully network-connected model featuring the Canon-designed network Multi-PDL Printer Kit-D1 for PCL 5e/6 emulation and PostScript 3 emulation.
The imageRUNNER 6020i features MEAP™, Multifunctional Embedded Application Platform, a unique open design platform that has been designed to deliver customized applications for every business need.
The imageRUNNER 6020i boasts resolution quality of true 600 x 600 dpi for scanning. Enhanced resolutions for copying and printing are 1200 x 600 dpi and 2400x 600, respectively.
With the imageRUNNER 6020i, users are able to preview scanned images directly from the Color LCD control panel. Also, when MEAP applications are installed, the interface can be designed to meet specific customer needs.
With its standard Duplexing Automatic Document Feeder, the imageRUNNER 6020i makes quick work of multi-paged, double-sided and mixed-size originals. It can handle up to 100 originals and can accept paper weights up to 32lb. Bond.
The imageRUNNER 6020i is equipped with an extensive paper supply.<br/>
Standard 4,150-sheet paper capacity can be upgraded to support up to 7,650 sheets through 6 sources.
Dual 1,500-sheet paper drawers are fixed for LTR stocks and can accept up to 110lb. Index stocks.
Dual 550-sheet paper cassettes can accept up to 24lb. Bond in various sizes.
3,500-sheet Paper Deck-G1 supports LTR-sized paper.
Standard 50-sheet Stack Bypass handles transparencies, specialty media, and heavy paper in weights up to 110lb-index.
Specifications
Model Name
imageRUNNER 6020i
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle
Up to 230,000 impressions per month
Image Server Memory
Standard 256MB RAM + 10GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 jobs
Scanning Resolution
600 dpi x 600 dpi
Printing Resolution
600 dpi x 600 dpi
Interpolated Resolution
2400 dpi x 600 dpi
Halftone
256
Letter
60 cpm
Letter R
42 cpm
Legal
36 cpm
Ledger
30 cpm
First Copy Time
3.8 Seconds from Platen
5.1 Seconds from ADF
Multiple Copies
1 to 9,999
Magnification
25% to 400% in 1% increments
Acceptable Originals
Sheets, Books, 3-dimensional items (Up to 4.4 lbs.)
Maximum Original Size
11' x 17' (Ledger)
Standard Paper Capacity
Dual Front Loading Trays (1,500 sheets each)
Dual Front Loading Cassettes (550 sheets each)
Manual Bypass
50 Sheets
Acceptable Paper Weights
Cassette
17 to 24 lb. Bond
Bypass
17 to 110 lb. Index
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
6 minutes or less
Exposure Control
Automatic or Manual (Text, Photo or Text & Photo)
Power Requirements
115V/60Hz, 15A
Dimension
44-3/4 x 25-3/8 x 29-1/4
(1,136mm x 643mm x 743mm)
Weight
462 lb. (210kg)
Toner
Magnetic Negative Toner
Estimated Toner Yield
33,000 Copies/Bottle (Estimated yield at 6% Coverage)
Feeders
Description
Statement to Ledger
Capacity
100 sheets (Letter/20 lb.)
Paper Weights
Up to 32 lb. Bond (Letter)
Power Source
Directly from main unit
Weight
Approximately 30.8 lbs. (14kg)
Paper Supply Options
Description
Paper Deck-G1 (Optional)
Paper Capacity
3,500 Sheets (20 lb. Bond)
Paper Sizes
Letter
Paper Weights
17 lb. Bond to 11 lb. Index
Power Source
Directly from Main Unit
Dimensions
34-7/8 x 3 x 24-1/4
(574mm x 75.5mm x 614.4mm)
Weight
Approximately 11.9 lbs. (5.4 kg)
Output Options
Finishers Output Trays
Description
Finisher-F1 (Optional)
Paper Weights
17 lb. Bond - 110 lb. Index
Paper Size
Statement to Ledger
Number Of Trays
2
Top Tray
1,000 Sheets (Letter)
Lower Tray
Staple Capacity
Up to 50 sheets
Staple Positions
Multipositioning Stapling
1 - Top Corner (Any Corner)
2 - Side Margin (Book Staple)
Hole Punch
With optional Puncher Unit-B1
Power Source
Dimensions
41-3/8 x 26-3/8 x 24-1/4
Weight
70.5 lbs.
Description
Saddle Finisher-F2 (Optional)
Paper Weights
Paper Size
Statement to Ledger
Number Of Trays
3 (Including Saddle-Stitch Tray)
Top Tray
Lower Tray
Saddle Stitch Tray
300 Sheets
Staple Capacity
Up to 50 Sheets
Staple Positions
Multiposition Stapling
1 - Top Corner ( Any Corner)
Hole Punch
With Optional Puncher Unit-B1
Paper Sizes
Letter, Ledger
Stapling Capacity
15 Sheets
Fold Type
V-Folding
Power Source
Dimensions
(1052mm x 669mm x 614mm)
Weight
114 lbs.
Print Board
Description
Network Multi-PDL Printer Kit-D1(Standard)
Processor
Canon Custom Processor - shared
Standard Memory
256MB
Maximum Memory
256MB
Hard Disk
10GB
PDL Support
PCL 5e, PCL 6, PostScript® 3 Emulation
Postscript Fonts
136 Fonts (117 Adobe Type and 19 TrueType)
PCL Fonts
Roman 80, Bar Code 32
Interface Connections
RJ-45 (10/100 Base-T)
IEEE 1284 (Compatibility: Nibble, Byte, and ECP Mode)
Token Ring (Optional Card)
Other Features
Remote UI®
Network ScanGear
JBIG Viewer
NetSpot Resource Downloader
EMS Open View
EMS NetView
EMS Unicenter® TNG
Network ScanGear
JBIG Viewer
EMS Open View
EMS NetView
EMS Unicenter® TNG
Brochures
Loading...
Complementary Content
- ${title}${badge}
${loading}
