Web Content Viewer
Actions
imageRUNNER 7095 Printer
Support - Multifunction
Specifications
Model Name
Type
Digital Multifunctional Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Image Server Memory
Standard 1GB RAM + 40GB HDD
Max Mailboxes Supported
100 (Max. Page Capacity: Approximately 20,000 pages)
Printing Resolution
1200 x 1200 dpi: UFR II and PostScript
2400 x 600 dpi (interpolated): PCL
Halftone
256-Level Grayscale
Letter
95 ppm (Letter); 49 ppm (11 x 17)
First Copy Time
7 seconds (The first print time may vary, depending on the print driver being used).
Standard Paper Capacity
4,150 Sheets
Manual Bypass
50-Sheet Stack Bypass
Maximum Paper Capacity
7,650 Sheets
Output Sizes
Cassette
Up to 11x17
Bypass
Up to 11x17
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index (All Sources)
Warm Up Time
6 Minutes or Less
Power Requirements
208V, 60Hz, 12A
Dimension
57 3/4 x 41 5/8 x 30 7/8
Weight
551 lb. (250kg)
Toner
Magnetic Negative Toner
Estimated Toner Yield
47,000 Images @ 6% Coverage
Paper Supply Options
Description
Paper Deck-W1/Paper Deck-X1 (Opt)
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Paper Deck-W1: Letter
Paper Deck-X1: Letter-R, Letter, Legal, 11 x 17
Paper Weights
Power Source
Paper Deck-W1/Paper Deck-X1: Directly From Main Unit
Dimensions
Paper Deck-W1: 22-1/2 x 12-3/4 x 23
(570mm x 323mm x 583mm)
Paper Deck-X1: 22-5/8 x 23-3/8 x 24-1/2
(574.5mm x 593mm x 621mm)
Weight
Paper Deck-W1: 90.4 lb. (41kg)
Paper Deck-X1: 101 lb. (46kg)
Description
Perfect Binder-A1
Paper Capacity
Cover Sheet Capacity:
Upper Tray: 200 sheets (20 lb. bond)
Lower Tray: 200 sheets (20 lb. bond)Output Tray Capacity: 3.94 (100mm) (equivalent to 10 books of 100 pages of 17 lb. bond)Glue Capacity: Glue-A1 (33 lb.) (15kg): Approximately 1,000,000 pages
Glue-A2 (11 lb.) (5kg): Approximately 200,000 pages Glue Warm Up Time: 380 seconds or less
Paper Sizes
Booklet Finish Size:
Width: 7-1/8 to 11-1/4
(after 3-direction cutting): Length: 5-5/8 to 8-1/4Cutting Method: Stack rotation 3-direction or 1-direction (for edge) cut Cover Sheet Sizes:
Width: 10-1/8 to 13
Length: 14-3/8 to 19-1/4
(11 x 17, 12 x 18, 13 x 19)
Paper Weights
Booklet Thickness: 10 to 200 sheets (17 to 24 lb. bond)
10 to 150 sheets (24 to 28 lb. bond)
10 sheets (28 to 110 lb. index)Cover Sheet Weight: 24 lb. to 158 lb. index (from Document Insertion Unit)
Output Options
Finishers Output Trays
Description
Finisher-V1/Saddle Finisher-V2 (Opt)
Paper Weights
Finisher-V1: 17 lb. Bond to 110 lb. Index
Saddle Finisher-V2: 17 lb. Bond to 110 lb. Index
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Number Of Trays
2/3
Top Tray
3,000 Sheets
Lower Tray
2,000 Sheets
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
100 Sheets (Letter, Executive) 50 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Corner Stapling, Double Stapling
Hole Punch
Professional Puncher-A1 (Opt)
Type: External In-Line Punch Unit
Hole-Punching Method: Press Punch Unit
Acceptable Punch Paper Weight: 20 lb. Bond to 110 lb. Index
Acceptable Punch Paper Size: Letter
Punch Speed: Up to 105 ppm (Depending on speed of main unit)Puncher Unit-V1 (Opt.)
Type: Internal Punch Unit
Hole-Punching Method: Press Punch System
Acceptable Punch Paper Weight: 17 lb. Bond to 110 lb. Index
Acceptable Punch Paper Size Two Holes: Legal, Letter-R; Three Holes: 11 x 17, Letter
Paper Sizes
Stapling Capacity
20 Sheets (80 Pages)
Fold Type
V-Folding Standard
Power Source
Directly From Main Unit or 208V, 60Hz, 12A
Dimensions
Finisher-V1: 46-1/2 x 31-1/2 x 31-1/4 (1180mm x 800mm x 792mm)
Saddle Finisher-V2: 46-1/2 x 31-1/2 x 31-1/4 (1180mm x 800mm x 792mm)
Weight
Finisher-V1: 278 lb. (126kg)
Saddle Finisher-V2: 392 lb. (178kg)
Booklet Trimmers
Description
Booklet Trimmer-B1 (for Saddle Finisher- V2)
Sheet Capacity
Maximum Trimmable Sheets: 40 sheets (20 lb. bond)
38 sheets (20 lb. bond) + 2 sheets (158 lb. index) Possible Trimming Size: 11 x 17, LGL, LTR Trimmer Waste Tray Capacity: 1,500 sheets of trimmed strip Output Tray Capacity: 30 booklets Booklet Trimming Cutting Method: Upper knife reciprocating fore-edge trimmer with delivery tray
Document Inserters
Description
Document Insertion Unit-C1 (Opt)
Paper Weight
17 lb. Bond to 158 lb. Index
Paper Sizes
Upper Tray: Letter, Letter-R, Executive; Lower Tray: 11 x 17, Legal, Letter, Letter-R, Executive
Feeder Capacity
Upper Tray: 200 Sheets; Lower Tray: 200 Sheets
Paper Folding
Description
Paper Folding Unit-D1 (Opt)
Paper Weight
17 lb. Bond to 20 lb. Bond
Paper Sizes
11 x 17
Fold Type
Z-Fold
Print Board
Description
Canon Multi-PDL Printer Kit-H1 (Opt)
Processor
Dual Canon Custom Processors
Standard Memory
1 GB -- Shared
Maximum Memory
40 GB -- Shared
PDL Support
PCL 5e, PCL 6, PostScript® 3 Emulation, UFR II
Postscript Fonts
PostScript 3 Emulation
PCL Fonts
PCL 5e, PCL 6
Interface Connections
Standard: 10/100Base-TX (RJ-45), USB 2.0 High Speed
Network OS: Windows® 98/Me/2000/XP Windows NT® 4.0 Windows Server 2003 (TCP/IP) Solaris 1.1x, 2.5x or Later Macintosh® OS 8.0 or Later (PPD) Novell® NetWare® v3.2, 4.1, 4.11, 4.2, 5, 5.1, 6, 6.5 (IPX/SPX)
Description
imagePASS-S1 Print Controller (Opt)
Processor
Intel® Celeron® D 2.8GHz
Standard Memory
256MB
Hard Disk
80GB HDD
PDL Support
Adobe® PostScript 3, PCL 5e, PCL 6
Postscript Fonts
PostScript 3
PCL Fonts
PCL 5e, PCL 6
Standard: 10Base-T/100Base-TX/ 1000Base-T (RJ-45) (RJ-45), USB 2.0 High Speed
Network OS: Windows 98/Me/2000/XP Windows Server 2003 (TCP/IP) Solaris 8 or Later Sun OS 4.1.3 or Later Macintosh OS 9.2, OSX (10.2.4) or Later Novell NetWare 4.2, 5.1, 6.5 (IPX/SPX)Other AccessoriesCassette-AB1Tab Feeding Attachment-A1Document Tray-L1Braille Label Kit-A1Control Card Reader-D1Control Card Sets Web Access Software-C1Remote Operator's Software Kit-A1Security Expansion Board-F1Expansion Bus-D1imageRUNNER Security Kit-A2Secure Watermark Kit-A1Barcode Printing Kit-A1Finisher Option Power Supply Unit-R1Stacker Dolly-A1Perfect Binder-A1Punch Tools Hot Folder for imagePASS-S1Impose for imagePASS-S1
Brochures
Loading...
 Return to Top
