Web Content Viewer
Actions
imageRUNNER 7105
Support - Multifunction
Specifications
Model Name
imageRUNNER 7105
Type
Digital Multifunctional Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Image Server Memory
Standard 1GB RAM + 40GB HDD
Max Mailboxes Supported
100 (Max. Page Capacity: Approximately 20,000 pages)
Max Copy Reservation
20 Jobs
Scanning Resolution
600 x 600 dpi
Printing Resolution
1200 x 600 dpi (Interpolated)
Halftone
256-Level Grayscale
Letter
105 cpm, 53 cpm (11 x 17)
First Copy Time
2.8 Seconds (From Platen)
Multiple Copies
1 - 9,999
Magnification
From Glass: 25% - 400% (In 1% increments)
From Feeder: 25% - 200% (In 1% increments)
Preset Reductions
25%, 50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%, 400%
Acceptable Originals
Sheets, Books, 3-Dimensional Objects up to 4.4 lb.
Maximum Original Size
11 x 17
Standard Paper Capacity
4,150 Sheets
Manual Bypass
50-Sheet Stack Bypass
Maximum Paper Capacity
7,650 Sheets Output Sizes
Max. Copy Size: 11 x 17
Min. Copy Size: 3-15/16 x 5-7/8 (Stack Bypass)
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index (All Sources)
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
6 Minutes or Less
Exposure Control
Automatic or Manual (Text, Photo, or Text/Photo)
Power Requirements
Plug: NEMA 6-15R
Power Consumption: 2.15kW
Feeders
Description
Duplex Automatic Document Feeder
Statement to 11 x 17
Scanning Speed
85 Sheets Per Minute (Letter)
Capacity
100 Sheets
Paper Weights
13 lb. Bond to 80 lb. Cover
Paper Supply Options
Description
Paper Deck-W1/Paper Deck-X1
Number Of Cassettes
1
Paper Capacity
3,500 Sheets
Paper Sizes
Paper Deck-W1: Letter
Paper Deck-X1: Letter-R, Letter, Legal, 11 x 17
Paper Weights
Output Options
Finishers Output Trays
Description
Finisher-V1/Saddle Finisher-V2
Paper Weights
17 lb. Bond to 110 lb. Index (For Both)
Paper Size
11 x 17, Legal, Letter, Letter-R, Statement-R, Executive
Number Of Trays
2/3
Top Tray
3,000 Sheets
Lower Tray
2,000 Sheets
Saddle Stitch Tray
30 Booklets or Limitless
Staple Capacity
100 Sheets (Letter, Executive)
50 Sheets (11 x 17, Legal, Letter-R)
Staple Positions
Corner Stapling, Double Stapling Professional Puncher-A1 (For Finisher-V1/Saddle Finisher-V2)
Type: External In-Line Punch Unit
Hole-Punching Method: Press Punch Unit
Acceptable Punch Paper Weight: 20 lb. Bond to 110 lb. Index
Acceptable Punch Paper Size: Letter
Punch Speed: Up to 105 ppm (Depending on speed of main unit)
Punch Patterns (Optional): Plastic Comb (19-Hole)
Twin Loop (32-Hole)
Twin Loop (21-Hole)
Color Coil (44-Hole)
Velo Bind(11-Hole)
Loose-leaf Bind (3-Hole)
Proclick (32-Hole)Puncher Unit-V1 (For Finisher-V1/Saddle Finisher-V2)
Type: Internal Punch Unit
Hole-Punching Method: Press Punch System
Acceptable Punch Paper Weight: 17 lb. Bond to 110 lb. Index
Two Holes: Legal, Letter-R
Three Holes: 11 x 17, Letter
Booklet Trimmers
Description
Booklet Trimmer-C1 (For Saddle Finisher-V2)
Margin Trimming: Open-End Only
Trim Thickness: 40 Sheets
Waste Tray Capacity: 1,500 Sheets of Trimmed Strip
Acceptable Paper Weight: 17 lb. Bond to 110 lb. Index
Output Tray Capacity: 30 Booklets Perfect Binder-A1*
Bind Method: Perfect Binding
Cutting Method: Stack Rotation 3-Direction, or 1-Direction (for Open Edge)
Cut Finished Book Size: After 3-Direction Cutting
Width: 7-1/8 to 11-1/4
Length: 5-5/8 to 8-1/4
Book Thickness: 10 to 200 Sheets Using 17 to 24 lb. Bond
10 to 150 Sheets Using 24 to 28 lb. Bond
10 Sheets Using 28 lb. Bond to 110 lb. Index
Cover Source Location: Stack Bypass, Paper Drawers, Paper Deck (Imageable) Document Insertion Unit (For Pre-Printed Covers)
Stacker Tray Capacity: 3.94 (100mm) (Equivalent to 10 100-page Books with 17 lb. Bond)
Glue Warm-Up Time: 380 Seconds or Less
Glue Unit Capacity: Bind Approximately 180 100-page Books Using 20 lb. Bond Paper
Trim Range
Width: 7mm x 27mm
Length: 7mm x 39mm
Trimmer Waste Capacity: Space for 3-Sided Cuttings From Approximately 15 100-page Books
Document Inserters
Description
Document Insertion Unit (Std. Perfect Binder-A1)
Paper Weight
17 lb. Bond to 158 lb. Index
Acceptable Media: Covers and Inserts
Number of Trays: 2
Feeder Capacity
Upper Tray: 200 Sheets (20 lb. Bond)
Lower Tray: 200 Sheets (20 lb. Bond)
Description
Document Insertion Unit-C1 (For Finisher-V1/V2)
Paper Weight
Number of Trays: 2
Paper Sizes
Upper Tray: Letter, Letter-R, Executive
Lower Tray: 11 x 17, Legal, Letter, Letter-R, Executive
Feeder Capacity
Paper Folding
Description
Paper Folding Unit-D1 (For Finisher-V1/V2)
Paper Weight
17 lb. Bond to 20 lb. Bond
Paper Sizes
11 x 17
Fold Type
Z-Fold
Folding Method: Roller Pressure Folding
Print Board
Description
Canon Multi-PDL Printer Kit-H2
Processor
Dual Canon Custom Processors
Standard Memory
1 GB - Shared
Storage: 40 GB - Shared
PDL Support
PCL 5e, PCL 6, PostScript 3 Emulation, UFR II
Resolution:
1200 x 1200 dpi: UFR II, PCL 6, PostScript 3 Emulation
2400 x 600 dpi: PCL 5e
Interface Connections
Standard: 10/100Base-TX (RJ-45), USB 2.0 High Speed
Network OS: Windows 98/Me/2000/XP
Windows Server 2003/ Windows Vista/Solaris
1.1x, 2.5x or Later/Macintosh OS 8.0 or Later (PPD)
Novell NetWare v3.2, 4.1, 4.11, 4.2, 5, 5.1, 6, 6.5 (IPX/SPX)
Description
imagePASS-S2
Processor
Intel Celeron D @ 2.8GHz
Operating System: System 8e
Standard Memory
256MB RAM
Maximum Memory
512MB RAM
Hard Disk
80GB (Standard)
PDL Support
Adobe PostScript 3, PCL 5e/6
Resolution
PCL 5e: 2400 x 600 dpi (Interpolated)
PCL 6/PS3: 1200 x 1200 dpi**
10/100/1000Base-TX (RJ-45)
Network Operating System: Apple Macintosh OS 9.1 (PPD), OS X (10.2.8 or Later)
Solaris 8.0 or Later, Sun OS 4.1.3 or Later, Windows 2000/XP/Server 2003/Windows Vista/Novell NetWare v4.2, 5.1, 6.1
Print Controller Technology
Windows 98/Me/2000/XP Server 2003/ Windows Vista
Citrix MetaFrame/Macintosh OS X (OS 10.2 or later)
Internal Fonts: 136 Adobe Type 1 Roman PS fonts
Other Features
EFI Options: Hot Folders and Virtual Printers, Impose v2.6, 256 RAM
Send Expansion Sets
Description
Universal Send Kit-E1
Sending Method
E-mail, I-fax, File Server (FTP, SMB, IPX, WebDAV)
Address Book Capacity
1,800 Destinations
Communication Protocol
File: FTP(TCP/IP), SMB (TCP/IP), NCP(IPX), WebDAV
E-mail/I-Fax: SMTP, POP3, I-Fax (Simple, Full)
Supported Data Format
File/E-mail: TIFF, PDF, PDF(OCR), Encrypted PDF, Digital Dence Signature PDF, Digital User Signature PDF
I-Fax: TIFF(MH, MR, MMR)Other AccessoriesCassette-AB1Tab Feeding Attachment-A1Document Tray-L1Braille Label Kit-A1Control Card Reader-D1Control Card Sets Universal Send Searchable PDF Kit-A1Universal Send PDF Security Feature Set-A1Digital User Signature Kit-A1Encrypted Secure Print Software-C1Web Access Software-F1Remote Operator's Software Kit-A1Expansion Bus-D1Access Management System Kit-A1HDD Data Encryption Kit-B2HDD Data Erase Kit-A1Voice Guidance Kit-A2Secure Watermark Kit-A1Barcode Printing Kit-A1Finisher Option Power Supply Unit-R1High Capacity Stacker-A1Stacker Dolly-A1Punch Tools for Professional Puncher-A1ADF Access Handle-A1* The Professional Puncher-A1 cannot be installed simultaneously with the Perfect Binder-A1. The Professional Puncher-A1 and the Puncher Unit-V1 can be installed simultaneously.
** 1200 x 1200 dpi resolution for PCL printing is not supported on Windows 9x/Me Clients.
Note: Some accessories require additional equipment or may be prerequisites for other options. Check with your Canon Authorized Dealer for details.
Awards
BLI 2006 4 Stars
2007 BLI Highly Recommended
BLI 2007 Reliability Seal
BERTL 4 Star Highly Recommended
#1 Ease of Use Monochrome MFP Customer Survey
#1 Best Monochrome MFP's Customer Survey
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 7105 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Product Configurator
Click here for the imageRUNNER 7105 / 7095 / 7086 Series Configurator.
This is to make Misc appear on the page when needed.
Brochures
Loading...
 Return to Top
