Web Content Viewer
Actions
imageRUNNER 9070
Support - Multifunction
Specifications
Model Name
imageRUNNER 9070
Type
Digital, Multifunction Imaging System
Imaging System
Laser Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle
500,000 Impressions per Month
Image Server Memory
Standard 512MB RAM + 20GB HDD
Max Mailboxes Supported
100
Max Copy Reservation
5 jobs
Printing Resolution
2400 dpi x 600 dpi Interpolated
Interpolated Resolution
1200 dpi x 600 dpi Interpolated
Halftone
256 Gradations of Gray
Letter
90 cpm
Ledger
45 cpm
First Copy Time
2.8 Seconds from Platen Glass
4.1 Seconds from ADF
Multiple Copies
1 to 9,999
Magnification
25% to 400% in 1% Increments
Acceptable Originals
Sheets, Books, 3-Dimensional Items
Maximum Original Size
11 x 17 (Ledger)
Standard Paper Capacity
Dual Front-loading Trays
(1,500 Sheets Each)
Dual Front-loading Cassettes
(550 Sheets Each)
Manual Bypass
50-sheet
Maximum Paper Capacity
7,650 Sheets
Acceptable Paper Weights
Cassette
17 lb. Bond to 110 lb. Index
Bypass
Duplexing
Standard Automatic Trayless
Warm Up Time
6 Minutes or Less
Power Requirements
208V, 60Hz, 12A
Dimension
54-7/8 x 40-3/4 x 31-3/8
(1395mm x 1035mm x 795mm)
Toner
Magnetic Negative Toner
Estimated Toner Yield
36,600 Images
Drum
Amorphous Silicon
Estimated Drum Yield
5,000,000 Impressions
Feeders
Description
Automatic Document Feeder
Statement to Ledger
Scanning Speed
80 ppm (Letter)
Capacity
100 Sheets (All Sizes/20 lb.)
Paper Weights
13lb Bond -32 lb Index
Paper Supply Options
Description
Paper Deck-N1 (Optional)
Paper Capacity
3,500 Sheets
Paper Sizes
Letter
Paper Weights
Power Source
Directly from Main Unit
Dimensions
22-1/2 x 12-3/4 x 23
(570mm x 323mm x 583mm)
Weight
Approximately 90.3 lb. (41kg)
Description
Paper Deck-S1 (Optional)
Paper Capacity
3,500 Sheets
Paper Sizes
Letter-R, Letter, Legal, 11 x 17
Paper Weights
Power Source
Dimensions
22-5/8 x 23-3/8 x 24-1/2
(575mm x 593mm x 621mm)
Weight
Approximately 101 lb. (46kg)
Output Options
Finishers Output Trays
Description
Finisher-K1N (Optional)
Number Of Trays
2
Top Tray
1,000 Sheets (All Sizes)
Offset Stacking
Lower Tray
2,000 Sheets (Letter)
1,000 Sheets (11 x 17, Legal)
Offset Stacking
Staple Capacity
100 Sheets (Letter/Statement)
50 Sheets (Letter-R/Legal/11 x 17)
Staple Positions
1 - Any Corner
2 - Side Margin
Power Source
Dimensions
39-1/4 x 26-1/4 x 29-1/8
(995mm x 667mm x 738mm)
Weight
Approximately 141 lb. (64kg)
Description
Finisher-K2N (Optional)
Number Of Trays
2
Top Tray
Offset Stacking
Lower Tray
Offset Stacking
Staple Capacity
Staple Positions
1 - Any Corner
2 - Side Margin
Hole Punch
3 Holes (11 x 17, Letter)
2 Holes (Legal, Letter-R)
Power Source
Dimensions
Weight
Approximately 145 lb. (66kg)
Description
Saddle Finisher-K3N (Optional)
Number Of Trays
3
Top Tray
Offset Stacking
Lower Tray
Offset Stacking
Saddle Stitch Tray
30 sets
Staple Capacity
Staple Positions
1 - Any Corner
2 - Side Margin
Hole Punch
Paper Sizes
11 x 17, Letter-R, Legal
Stapling Capacity
15 Sheets (60 Pages)
Fold Type
V-folding Standard
Power Source
Dimensions
39-1/4 x 31-5/8 x 29-1/8
(995mm x 803mm x 738mm)
Weight
Approximately 279 lb. (127kg)
Booklet Trimmers
Description
Booklet Trimmer-A1 (Optional)
Can only be used with Saddle Finisher-K3N
Sheet Capacity
30 Sheets (60 Pages)
Stack Capacity
2,000 Pages
Dust Capacity
2,000 Pages
Document Inserters
Description
Document Insertion Unit-B1 (Optional)
Paper Weight
Paper Sizes
Letter-R to 11 x 17
Feeder Capacity
Letter, Letter-R: 100 Sheets
Legal, 11 x 17: 50 Sheets
Letter, Letter-R: 100 sheets
Paper Folding
Description
Paper Folding Unit-C1(Optional)
Paper Weight
17 lb. Bond to 22 lb. Bond
Paper Sizes
11 x 17 Only
Fold Type
Z-fold
Print Board
Description
Network Multi-PDL Printer Kit-F1 (Optional)
Processor
Canon-Custom Processor Shared
Standard Memory
512 MB-Share
Storage: 20GB - Shared
PDL Support
PCL 5e, PCL 6, UFR II, PostScript 3 Emulation
Interface Connections
Standard: 10/100Base-T (RJ-45), USB 2.0 High Speed
Description
Canon imagePASS-M3 Print Controller (Optional)
Processor
Intel® Celeron® 2.5GHZ
Standard Memory
256MB
Hard Disk
40GB HDD
PDL Support
Adobe® PostScript® 3, PCL5e, PCL6
Standard: 10/100/1000 Base-T (RJ-45)
Optional: Parallel Interface Adapter (IEEE 1284)
Send Expansion Sets
Description
Universal Send Kit-C1
Sending Method
E-mail, I-fax, File Server (IPX, FTP, SMB), User Inbox
Address Book Capacity
Maximum 1,800 destinations
File Format
Standard: TIFF, PDF
Optional PDF (OCR), PDF Encryption
Sending Size
Statement to Ledger
Scan Density
200 dpi, 300 dpi, 400 dpi, 600 dpi Other Accessories and Supplies:
Tab Feeding Attachment-A1
FL Cassette-P4
Card Reader-D1
GPR-7 Toner
Staple-G1
Staple-H1
Staple-D2
Basic Card Set, Copy Card Sets 1 (1-30), 2 (31-100), and 3 (101-200)
USB Application Interface Board-D1
Expansion Bus-A1
imageRUNNER Security Kit-A2
Universal Send PDF Enhancement Kit-B1
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER 9070 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
