Web Content Viewer
Actions
imageRUNNER LBP3460
Support - Multifunction
Features
The Canon imageRUNNER LBP Series is powered by a system architecture that is similar to the current imageRUNNER line, and provides unparalleled speed, power and functionality. Fast processing of large and complex documents is further enhanced through expandable onboard memory. Whether the needs of users are basic or more demanding, the imageRUNNER LBP Series offers a scalable solution to all environments.
The imageRUNNER LBP Series produces output of unparalleled quality, regardless of the document. Users can print remarkably sharp and impactful presentations, architectural renderings, engineering diagrams or general office documents at high speed. The imageRUNNER LBP3460 model delivers crisp output at up to 600 dpi.
The imageRUNNER LBP Series utilizes the same consistent printer driver that Canon developed for the imageRUNNER line. By standardizing the driver interface across the entire imageRUNNER series - from desktop to production devices - users need to only familiarize themselves with one universal set of print functions. Each intuitive tab in the printer driver provides graphical icons representing the device, as well as the page layout of the particular print job being submitted. Additionally, the Dynamic Configuration function of the printer driver always displays accurate information on the device&#39;s configuration options and installed paper to eliminate errors. The imageRUNNER printer driver is compatible with both Windows and Macintosh environments.<br/> <br/>
The Canon UFR II Print Controller is included in all three models in the Canon imageRUNNER LBP Series. This proprietary architecture has been consistently proven to deliver faster output than PCL or PS page description languages for complex documents that include images, graphics and text. The UFR II Controller achieves high-performance printing by automatically distributing data processing between the print driver on the user&#39;s desktop computer and the imageRUNNER LBP device. The intelligent architecture automatically determines the optimal balance of processing by analyzing the layout and graphic components of each page. This unique approach maintains exceptionally high print performance on office documents and PDF files. The print controller provides support for UFR II, PCL 5c (Color imageRUNNER LBP5960 and LBP5360), and PCL 5e/6 (imageRUNNER LBP3460).<br/> <br/>
The long wait for printed output is over since the Canon imageRUNNER Series requires no warm-up time from standby mode to produce documents fast. The power of the RAPID Fusing System is inside each model, which uses a special fixing film and ceramic heater unlike traditional roller-fixing devices. RAPID Fusing System provides exceptional image quality with zero warm-up time and reduces first print-out time, while requiring less heat and energy consumption.<br/> <br/>
All models in the Canon imageRUNNER LBP Series are remarkably compact and feature front-load access to consumables such as drum, toner, fuser and paper supply. This enables the devices to be conveniently placed either on top of or below a desk, in a corner, or in previously unusable space.<br/> <br/>
The Canon imageRUNNER LBP Series features a standard auto-duplexing function that can save paper costs by printing double-sided documents with nonstop productivity. Using a trayless duplexing design, the imageRUNNER LBP Series assures high reliability of paper feeding in a very compact size. In addition, each model offers options that provide extra paper capacity for even longer continuous operation. The imageRUNNER LBP3460 offers the option for one additional 500-sheet cassette.
The Canon imageRUNNER LBP Series has been designed to optimize productivity through the minimization of downtime. This is achieved through the front-load access to all customer replaceable components. When replacements are required, each toner cartridge and image drum can be replaced individually to improve operating cost effectiveness. The imageRUNNER LBP3460 features a standard or high-volume all-in-one toner and drum cartridge.
Specifications
Model Name
imageRUNNER LBP3460
Printing Process
Type: Desktop Laser Printer
Copying Method: Electrophoto method (On-Demand Fusing)
Developing System: Dry Dual Component Developing System
Letter
35 ppm
First Print Time
8.0 Seconds
Warm-Up Time: 0 Seconds From Standby
9 Seconds After Powering ON
Processor
R4000-333 MHz**
Memory
Standard 64 MB RAM
Maximum 320 MB RAM*
Page Description Language
UFR II / PCL5e /PCL6Print Resolution
UFR II / PCL5e / PCL6: 2400 dpi equivalent x 600 dpi
Engine Resolution: 600 dpi x 600 dpi
Printer Driver
UFR II: Windows® (Windows 2000/XP/Server 2003, Citrix MetaFrame), Macintosh® (OS 10.2.8 or later)
PCL5c / PCL6: Windows (Windows 98/Me/2000/XP/Server 2003, Citrix MetaFrame)
Halftone: 256 Gradations (Continuous-Tone)
Interface
Connections: 10/100 Base-TX (RJ-45)
Other Interface: USB 2.0 High Speed / USB Full-Speed
(USB 1.1 equivalent)
User Interface: LCD 16 characters x 1 line
8 LED indicators
8 Operation keys
Paper Handling
Standard Input Upper Cassette
Paper Size
Legal, Letter, Executive, Custom Sizes (Width: 5-7/8 to 8-1/2 Length: 8-3/8 x 14)
Paper Weight
17 lb. Bond to 35 lb. Bond
Standard Input Multi Purpose Tray
Paper Size
Legal, Letter, Executive, Statement, Index Card, Custom Sizes (Width: 3 to 8-1/2 Length: 5 to 14) and Envelopes
Paper Weight
17 lb. Bond to 65 lb. Cover Paper Sources
Standard: 250-Sheet x 1 Paper Cassette (20 lb. Bond)
100-Sheet Multi Purpose Tray
Optional: 500-Sheet x Up To 1 Paper Cassette
Maximum: 850-Sheets
Maximum Paper Size: Legal (216x355.6mm Paper Size)
Output Capacity: Approximately 250 Sheets (Face Down)
Approximately 50 Sheets (Face Up)
Paper Output: Face Down / Face Up
Duplexing: Standard Automatic Trayless Duplexing (Legal, Letter)
Dimensions
10 3/4 x 17 5/8 x 16 1/4
Installation Space (W x D): 17 5/8 x 24 1/2 (when the Multi-Purpose Tray is extended)
Weight
Approximately 35.5 lb.***
Power Source
100-127 V 50/60Hz
Power Consumption
Standard
Operating: Approximately 580 W (average)
Standby: Approximately 10 W (average)
Deep Sleep Mode: Approximately 7 W (average)
Estimated Toner Yield For Black and White
Black (cartridge 110): 6,000 images@5% coverage
Black (cartridge 110 II): 12,000 images@5% coverage Optional Accessories
Paper Feeder PF-36****
Paper Sizes: Legal, Letter, Executive, Custom Sizes (Width: 5-7/8 to 8-1/2, Length: 8-3/8 x 14)
Paper Cassette Capacity: 500 Sheets (20 lb. Bond)
Dimensions (H x W x D): 6 5/8 x 17 5/8 x 18 7/8
Weight: Approximately12.4 lb.
Other Optional Accessories EXPANSION RAM ER-64EXPANTION RAM ER-128EXPANTION RAM ER-256Footnotes:
* One memory slot available for expanding memory.
** The upper limit of the frequency range.
*** Excluding the Toner Cartridge.
**** Up to one additional paper cassette can be added.
Toner cartridge yield in accordance with ISO/IEC 19752
Brochures
Loading...
 Return to Top
