Web Content Viewer
Actions
Support - Multifunction
Brochures
Loading...
Features
The Canon imageRUNNER LBP Series is powered by a system architecture that is similar to the current imageRUNNER line, and provides unparalleled speed, power and functionality. Fast processing of large and complex documents is further enhanced through expandable onboard memory. Whether the needs of users are basic or more demanding, the imageRUNNER LBP Series offers a scalable solution to all environments.
The imageRUNNER LBP Series produces output of unparalleled quality, regardless of the document. Users can print remarkably sharp and impactful presentations, architectural renderings, engineering diagrams or general office documents at high speed. The imageRUNNER LBP3560 model delivers crisp output at up to 600 dpi.
Users will appreciate the clarity of the 5-line LCD display and intuitive control panel of the imageRUNNER LBP3560 model. The distinctive panel features on-screen navigation to facilitate device setup, animations to help guide operations, at-a-glance consumable levels, and the status of current print jobs.
All models in the Canon imageRUNNER LBP Series are remarkably compact and feature front-load access to consumables such as drum, toner, fuser and paper supply. This enables the devices to be conveniently placed either on top of or below a desk, in a corner, or in previously unusable space.
The imageRUNNER LBP Series utilizes the same consistent printer driver that Canon developed for the imageRUNNER line. By standardizing the driver interface across the entire imageRUNNER series - from desktop to production devices - users need to only familiarize themselves with one universal set of print functions. Each intuitive tab in the printer driver provides graphical icons representing the device, as well as the page layout of the particular print job being submitted. Additionally, the Dynamic Configuration function of the printer driver always displays accurate information on the device's configuration options and installed paper to eliminate errors. The imageRUNNER printer driver is compatible with both Windows and Macintosh environments.
The Canon UFR II Print Controller is included in all five models in the Canon imageRUNNER LBP Series. This proprietary architecture has been consistently proven to deliver faster output than PCL or PS page description languages for complex documents that include images, graphics and text. The UFR II Controller achieves high-performance printing by automatically distributing data processing between the print driver on the user's desktop computer and the imageRUNNER LBP device. The intelligent architecture automatically determines the optimal balance of processing by analyzing the layout and graphic components of each page. This unique approach maintains exceptionally high print performance on office documents and PDF files. The print controller provides support for UFR II, PCL 5c (Color imageRUNNER LBP5975/5970 and LBP5460), and PCL 5e/6 (imageRUNNER LBP3560 and LBP3470).
The long wait for printed output is over since the Canon imageRUNNER Series requires no warm-up time from standby mode to produce documents fast. The power of the RAPID Fusing System is inside each model, which uses a special fixing film and ceramic heater unlike traditional roller-fixing devices. RAPID Fusing System provides exceptional image quality with zero warm-up time and reduces first print-out time, while requiring less heat and energy consumption. The TEC (Typical Electricity Consumption) value is only 1.8 kWh/week for imageRUNNER LBP3560.
The Canon imageRUNNER LBP Series features a standard auto-duplexing function that can save paper costs by printing double-sided documents with nonstop productivity. Using a trayless duplexing design, the imageRUNNER LBP Series assures high reliability of paper feeding in a very compact size. In addition, each model offers options that provide extra paper capacity for even longer continuous operation. The imageRUNNER LBP3560 offers the option for two additional 500-sheet cassette.
imageRUNNER LBP3560 and LBP3470 offer the Closing Assist Mechanism, which allows users to reload paper easily with less stress by featuring a suction effect when closing the cassette. This new feature is available on both the standard and optional cassettes of imageRUNNER LBP3560 and the optional cassette of the imageRUNNER LBP3560.
The imageRUNNER LBP models gives IT managers control and helps drive cost out of operations with a variety of tools including the standard Remote User Interface, support for Canon's imageWARE Enterprise Management Console application, and Canon's Generic PCL6 driver to simplify driver deployment.
The imageRUNNER LBP3560 is ready for today's customers seeking managed print services with internal counters, and Canon's advanced management tools.
Color imageRUNNER LBP5975/5970/5460 and imageRUNNER LBP3560 models can benefit from Canon's Wireless LAN Kit option-the latest in wireless technology-to connect to a Local Area Network, without the need for a hard-wired Ethernet connection. Supported standards include 802.11g and 802.11b for up to 54Mbps and 11Mbps transmission speeds, respectively, and compliance with WPA(AES), WEP, IEEE802.x/EAP(TLS/TTLS/PEAP), and PSK security encryption.
The Canon imageRUNNER LBP Series has been designed to optimize productivity through the minimization of downtime. This is achieved through the front-load access to all customer replaceable components. When replacements are required, each toner cartridge and image drum can be replaced individually to improve operating cost effectiveness. Auto-rewinding tape seal offers easy installation for all-in-one toner cartridges.
Specifications
Model Name
imageRUNNER LBP3560
Type
Desktop Laser Printer
Printing Method Electrophoto Method (RAPID Fusing System)
Developing System
Dry Dual Component Delivery System
Standard PDL UFR II, PCL 5e/6, PS 3 Emulation
Image Server Memory
Standard 192MB RAM
Maximum 384MB RAM*
CPU: R4000 Series - 333MHz**
Interface Connections: 10Base-T/100Base-TX
Other Interface: USB 2.0 Hi-Speed
User Interface: LBP3560: LCD 22 Characters x 5 Lines, 9 LED Indicators, 10 Operation Keys
Printing Resolution
Engine: 600 x 600 dpi
Print UFR II/PCL 5e/6/PS 3: 600 x 600 dpi 2400-dpi Equivalent x 600 dpi
Print Drivers
UFR II/PS 3: Windows 2000/XP/Server 2003/Server 2008/Windows Vista/7/Mac OS 10.4 or Later/Linux/Citrix MetaFrame/XenApp
PCL 5e/6: Windows 2000/XP/Server 2003/Server 2008/Windows Vista/7/Linux/Citrix MetaFrame/XenApp
Halftone
256 Gradation (Continuous-Tone)
Letter
42 ppm (Letter)
First Copy Time
7.9 Seconds
Standard Paper Capacity
500-sheet Paper Cassette (20 lb. Bond)
100-sheet Multi-Purpose Tray
Optional 500-sheet Paper Cassette (Up to 3)
Maximum Paper Capacity
1,600 Sheets
Output Sizes
Cassette
Drawers: Legal, Letter, Executive, Custom Sizes
Multi-Purpose Tray: Legal, Letter, Executive, Index Card, Custom Sizes and Envelopes
Maximum Size: Legal (8-1/2 x 14)
Acceptable Paper Weights
Cassette
Cassettes: 60 - 120 g/m2 (16 lb. Bond to 32 lb. Bond)
Multi-Purpose Tray: 60 - 199 g/m2 (16 lb. Bond to 53 lb. Bond)
Duplexing
Standard Automatic Trayless Duplexing (Legal, Letter)Paper Handling
Paper Output: Face-down/Face-up
Output Capacity
Face-down Output Tray: Approx. 250 Sheets
Face-up Output Slot: Approx. 50 Sheets
Warm Up Time
14 Seconds or Less
Power Requirements
120-127V, 60Hz
Plug: NEMA 5-15P
Power Consumption (Approx., Average):
Operating: 650W
Standby: 12W
Deep Sleep Mode: 1.2W
Dimension
13-1/2 x 17-7/8 x 16-3/4
Installation Space (H x W x D) 17-7/8 x 24-1/2
(When Multi-Purpose Tray is Extended)
Weight
Approx. 36.8 lb. ***
Toner
Black (Starter): 6,000 Standard Pages†
Black: 12,500 Standard Pages†
Feeders
Description
Paper Feeder Unit PF-45
Acceptable Originals
Legal, Letter, Executive, Statement, Custom Sizes
Capacity
500 Sheets (20 lb. Bond)
Dimensions
6 x 17-7/8 x 18-1/2
Weight
Approx. 12.1 lb.* One memory slot available for expanding memory. Memory upgrade requires removal of standard memory.
** The upper limit of the frequency range.
*** Excluding the CRG.
† Toner cartridge yield in accordance with ISO/IEC 19752.
†† For LBP3560 only.
♦ Up to two Paper Feeder Units can be added.
Awards
Better Buys for Business 2011 Editor's Choice
2011 BERTL's Best Award
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER LBP3560 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
