Web Content Viewer
Actions
imageRUNNER Pro 7125VP
Support - Multifunction
Specifications
Model Name
Type
Digital, Multifunction Imaging System
Imaging System
Electrophotographic Process
Developing System
SPD, Two-Component Dry
Duty Cycle
2.5-4.25 million impressions/month (depending on customer job stream and number of shifts)
Acceptable Originals
Sheets, Transparencies, Tabs, and Covers
Maximum Original Size
14.33 x 18.5 *
Min. Paper Size: 7 x 8.27 *
Engine Resolution: 600 dpi x 600 dpi
Paper Feeding: 3-Drawer Modular
Standard Paper Capacity
2 x 1,000 Sheets + 1 x 2,000 Sheets
Maximum Paper Capacity
12,000 Sheets Print Speed
In-track sizes 7 - 9: 125 ppm
In-track sizes > 9 - 10.9: 104 ppm
In-track sizes > 10.9 - 13.8: 83 ppm
In-track sizes > 13.8 - 18.5: 62.5 ppm
Acceptable Paper Weights
Cassette
16 lb. Bond - 150 lb. Index
Duplexing
Standard Automatic Trayless Duplexing
Warm Up Time
6 Minutes or Less
Power Requirements
208V / 60Hz / 30 Amps
Dimension
64 x 119.5 x 47
Weight
2,695 lbs.
Paper Supply Options
Description
Paper Supply Module (Optional)
Number Of Cassettes
3
Paper Capacity
Paper Sizes
7 x 8.27 to 14.33 x 18.5 *
Paper Weights
Power Source
Directly from Main Unit
Output Options
Finishers Output Trays
Description
imageRUNNER Pro 7125VP Basic Finisher (Std.)
Paper Weights
Up to 150 lb. Index
Paper Size
Top Exit Tray: 7 x 8.27 to 14.33 x 18.5 *
Staple Exit Tray: 7 x 8.27 to 9 x 14 *
Number Of Trays
2
Top Tray
500 Sheets Non-Staple (All Sizes)
Staple Exit Tray: 3,000 Sheets Straight or Offset (85 Sets Stapled)
Staple Capacity
Up to 100 Sheets
Staple Positions
Multiposition Stapling
None / Top / Bottom / Both
Power Source
Dimensions
61.5 x 22.5 x 34
Weight
650 lbs. Puncher
Power Requirements: 120 VAC, 60Hz, 2.5A
100 VAC, 50/60Hz, 2.5A
Power Consumption: 320 VA
Dimensions (H x W x D): 49.6 x 40.2 x 31.9
Weight: 595 lbs.
Punch Tools:
Loose-leaf/Office Hole Punch Tool: 2-hole
3-hole (Diameter 0.313)
4-hole (Diameter 0.276)
Plastic Comb Punch Tool (Rectangular): Rectangular Holes (0.315 x 0.126)
Wire Comb Punch Tool 2-1 Pitch (Round): Round Holes (Diameter 0.236)
Wire Comb Punch Tool 3-1 Pitch (Round): Round Holes (Diameter 0.157)
Wire Comb Punch Tool 2-1 Pitch (Rectangular): Rectangular Holes (0.256 x 0.217)
Wire Comb Punch Tool 3-1 Pitch (Square): Square Holes (0.157 x 0.157)
Punch Tool Durability: 12-15 Million Actuations
Note: You may order customized Punch Tools to meet your specifications. Please contact your Canon-authorized Dealer for more information. Stacker(s) (Opt.)
Paper Weights: Up to 150 lb. Index
Paper Sizes: 7 x 8.27 to 14.33 x 18.5 *
Number of Trays: 1 Tote Wheel Cart (Stacker Dolly)
Tray Capacity:
Tray: 5,000 Sheets Straight or Offset
Power Source: 115V
Dimensions (H x W x D): 49.5 x 33 x 31.6
Weight: 450 lbs. Booklet Maker (Opt.)
Paper Weights: Up to 20 lb. Bond
Paper Sizes: 8 x 10 to 14 x 18
Number of Trays: Conveyor Belt Output - Up to 42 Booklets
Stitching Capacity: 2 to 22 Sheets
Stitching Position: 2 Center Staple Positions
Staples: 50,000 Stitches
Saddle Stitch Specifications
Folding: V-Folding
Folding Capacity: 2 to 22 Sheets
Trimming: Edge Trim Folded Booklets
Power: 115V
Dimensions (H x W x D): 58 x 100 x 24
Weight: 970 lbs. In-line Perfect Binder (Opt.)
Book Thickness: 15 Sheets to 1-1/2 (40 mm) about 350 sheets @ 20 lbs.
Book Size
(In-Line Binding): 8.5 x 11
(Off-Line): 2-1/3 x 4 to 12 x 14
Cover Type: Any Paper
Cover Weight: 80 - 250 gsm, 30 - 90 lb. Cover
Paper Weight: 15 lb. to 40 lb.
Binding Technology: Hot Bind Technology
Warm-Up Time: 25 minutes
Miss Detector: Yes
Maximum Speed: 250 cycles/hour (on-line for books of 15 sheets)
Milling + Notching: Yes
Paper Waste Collection: Yes
Book Counter: Yes
24 Hour Start Up Timer: Yes
Fume Extractor: Yes
Outdoor Fume Exhaust: Optional
Dimensions (H x W x D): 45 x 8'4 x 5'11
Weight: 1,676 lbs.
Power Source: 208V/230V or 240V-20ABourg Perforating Rotating Folding Unit (BPRF) (Opt.)
Power Requirement: 120VAC, 60Hz
Power Consumption: 920 Watts
Dimensions (HXWXD): 51 x 64 X 31
Weight: 562 lbs. Scanners
imageSCANNER 65 (Opt.)
Optical Resolution: 600 dpi x 600 dpi
Output Resolution: 150 to 2,400 dpi (Scale: 25% to 400%)
Speed:
Simplex/Duplex: 65 ppm
Letter: 36 ppm
Duty Cycle: 100,000 Scans/Month (300,000 Peak)
Feeder Capacity: 100 Sheets
Paper Sizes: 5-1/2 x 8-1/2 to 11 x 17
Paper Weights: 16 lb. Bond - 110 lb. Index
Image File Format: TIFF
Interface: ISIS/TWAIN
Power Source: 120/208 VAC, 60Hz
Dimensions (H x W x D): 15 x 39 x 27
Weight: 200 lbs.
Document Inserters
Description
Post Process Inserter (Opt)
Paper Weight
Paper Sizes
Feeder Capacity
4,000 Sheets (2 x 1,000 Sheets + 2,000 Sheets)
Power Source: Directly from Main Unit
Dimensions (H x W x D): 49-1/2 x 31 x 33-1/2
Weight: 610 lbs. Optional Features:
MICR Printing*
Enhanced Feed Mode*
Digital Print Quality Adjustments*
PCL Interpreter*
Extended Paper Size Range** Optional License upgrade is required
** Caliper must fall within 3.5 mil to 10 mil (0.09mm to 0.25mm)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you imageRUNNER Pro 7125VP that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
 Return to Top
