Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
NP 7130
Your office productivity will soar with the NP 7130, a 13 cpm desktop copier with the reliable performance critical for your small business. Thanks to Canon's patented RAPID Fusing System technology, warm-up time is eliminated. Just turn on the power and you can immediately make copies. In addition to outstanding copy quality, the NP 7130 features zoom reduction and enlargement from 70%-141% and four common preset reduction and enlargement ratios, making it easy to control the image size. The NP 7130 also features a high-capacity 500-sheet user-adjustable cassette and a handy 50-sheet bypass, allowing you to have two different paper supplies available at all times. The NP 7130 is a highly reliable and low maintenance solution - all in a compact design.
Features
Specifications
Model Name
Type
Imaging System
Developing System
Fixing System
Duty Cycle (e.g. up to 100 impressions/month)
Letter
Legal
Statement
Toner Colors
Acceptable Originals
Maximum Original Size (e.g. 10 x 20 )
Standard Paper Capacity (e.g. 100 sheets)
Manual Bypass (e.g. 100 sheets)
Maximum Paper Capacity (e.g. 100 sheets)
Cassette (e.g. 10 x 20)
Bypass (e.g. 10 x 20)
Cassette
Bypass
Duplexing
Magnification (e.g. 10% - 90% (in 10% increments))
Preset Reductions
Preset Enlargements
First Copy Time
Warm-up Time
Exposure Control
Void Area
Multiple Copies (e.g. 20 - 30)
Power Requirements
Dimensions (H x W x D) (e.g. 10mm x 20mm x 30mm)
(330mm x 485mm x 447mm)
Weight (e.g. 10 lbs)
Toner
Estimated Toner Yield
Drum
Estimated Drum Yield
Brochures
- ${title}${badge}
