Web Content Viewer
Actions
NP 7850
Support NP Copiers
Features
The NP 7850 boasts a speed of 83 copies-per-minute. Plus, Canon's Accelerated Copy System™ boasts productivity by automatically increasing the speed from 83 copies-per-minute to 90 copies-per-minute for single sets of letter-sized originals.
The NP 7850's Recirculating Document Feeder (RDF) stands up to the heavy demands placed upon a business's primary copier. It feeds up to 100 letter-sized sheets and supports up to 110 lb. Index Stock. The RDF handles different sized originals and can produce up to 999 finished sets of any combination on one- or two-sided documents.
The RDF is equipped with a built-in Semi-Automatic Document Feeder, which handles delicate originals and allows you to interrupt a current copy job without disturbing originals in the RDF.
With an enormous standard 6,100-sheet paper capacity through four paper sources, the NP 7850 provides virtually uninterrupted productivity when processing lengthy copy jobs. A 100-sheet Stack Bypass complements the dual 1,000-sheet user-adjustable drawers and 4,000-sheet Paper Deck. For added flexibility, up to 110 lb. Index Stock can be accepted from all paper sources.
With standard Automatic Duplexing, the NP 7850 can make two-sided copies on all supported paper sizes and paper stocks including 11" x 17" paper and 110 lb. Index Stock.
Fast and flexible Zoom capabilities allow reduction and magnification from 50% to 200% in 1% increments, with Preset Zoom settings in the seven most often used reduction and enlargement ratios. Plus, the Auto Zoom feature takes the guesswork out of copying by reducing or enlarging images to fit the desired paper size.
A choice of 20-bin stapler sorter options produce sorted, stapled, or 3-hole punched output with ease. If a document contains 25 sheets or less, the stapler sorter operates as a 40-bin sorter by placing two sets in each bin, doubling output without increasing the copier footprint.
Automatic Exposure and Photo Mode help you consistently produce documents of the highest quality, even when you're working with halftones, color backgrounds or other difficult-to-copy originals.
The core of the NP 7850's user-friendliness is its easy-to-use Touch-sensitive LCD Control Panel. Its clarity, flexibility and host of automatic functions contribute to office productivity.
The NP 7850's manufacturing status as a Canon Factory Produced New Model helps reduce waste and conserve the environment. A Canon Factory Produced New Model is manufactured by converting an existing Canon product into a new model by adding new features or functions not previously available. Given New Model status and a new product name and serial number, the product contains new, reconditioned, or recovered parts and fully meets Canon's new product performance and reliability specifications. This status follows Canon's long held "Reduce, Reuse, Recycle" philosophies and initiatives.
Specifications
Model Name
NP 7850
Type
Console/Stationary Platen
Imaging System
Dry Electrostatic Transfer
Developing System
Dry Monocomponent Toner Projection
Duty Cycle (e.g. up to 100 impressions/month)
Up to 350,000 impressions/month
Letter
83 cpm (90 cpm with Accelerated Copy System™)
Letter-R
62 cpm
Legal
55 cpm
Ledger
46 cpm
Statement
67 cpm
Toner Colors
Black
Acceptable Originals
Sheets, Books and 3-Dimensional Objects (Up to 4.4 lbs./2.0 kg)
Maximum Original Size (e.g. 10 x 20 )
11 x 17
Standard Paper Capacity (e.g. 100 sheets)
2 x 1,000 Sheets + 4,000 Sheets
Manual Bypass (e.g. 100 sheets)
100 Sheets
Maximum Paper Capacity (e.g. 100 sheets)
6,100 Sheets
Cassette (e.g. 10 x 20)
Letter to Ledger - Drawer
Letter to Legal - Paper Deck
Bypass (e.g. 10 x 20)
Statement to Ledger
Cassette
17 lb. Bond - 110 lb. Index
Bypass
Duplexing
Standard 50 Sheets and Limitless Duplexing
Magnification (e.g. 10% - 90% (in 10% increments))
50% - 200% (in 1% increments)
Preset Reductions
50%, 64%, 73%, 78%
Preset Enlargements
121%, 129%, 200%
First Copy Time
3.1 Seconds (Letter, 100%, Simplex, Automatic Exposure Off, Paper Deck)
Warm-up Time
6 Minutes (at 68° F/20° C)
Exposure Control
Automatic and Manual
Void Area
Lead: 4mm
Left & Right: 2.5mm
Trail: 2mm
Multiple Copies (e.g. 20 - 30)
1 to 999
Power Requirements
208V, 60Hz
Dimensions (H x W x D) (e.g. 10mm x 20mm x 30mm)
46 x 59-1/2 x 31-1/8
(1168mm x 1511mm x 789mm)
Weight (e.g. 10 lbs)
661 lbs.
Toner
NPG-12A Black Toner
Estimated Toner Yield
3,000 Images (6% Coverage)
Drum
NP 6085 Drum
Estimated Drum Yield
5,000,000 Impressions
Brochures
Loading...
 Return to Top
