Web Content Viewer
CXDI-501C Digital Radiography System
Digital Detectors
  • High Resolution and High Sensitivity
    With a 125 micron pixel pitch, the CXDI-501C Digital Radiography (DR) System delivers exceptional spatial resolution. The high sensitivity of the Cesium Iodide (CsI) scintillator helps reduce the X-ray exposure to the patient. The maximum 3 second exposure time allows this digital detector to be used with tomography equipment and for other exams that may require an exposure time of up to 3 seconds.
  • True Portability with Detachable Cable
    Weighing less than 7 pounds, either the patient or the x-ray technician may comfortably hold the CXDI-501C DR System in place during image capture. The built-in groove in the detector also helps maneuver the detachable cable easily.
  • CXDI Control Software NE
    The CXDI-501C Digital Radiography System uses the Canon CXDI Control Software NE. The software gives a wide range of selections and images can be taken within three touches. An on-screen preview image is available 3 seconds after exposure. The image processing shows subtle details of trabecular bone structure and soft tissue in the same image. For more information, visit our CXDI Control Software NE webpage.
This is to make Misc appear on the page when needed.
Images are simulated.
 Return to Top
