Web Content Viewer
Actions
CXDI-50RF Digital Radiography System*
Digital Detectors
Features
  • Digital Radiography
    The Cesium Iodide scintillator has effective x-ray absorption and high signal-to-noise performance providing less x-ray dosage to the patient. The detachable cable makes the sensor easily transferable to multiple rooms or multiple locations within the same room.
  • Fluoroscopy
    Real time x-ray images of blood flow studies, investigations of the gastrointestinal tract, including barium enemas, barium meals, and barium swallows can be viewed on the high definition monitor (sold separately). Placement of internal devices may be completed with precision, such as feeding tubes, pacemakers, catheters, and implantable cardioverter defibrillators. Depending on the image capture mode and size, the CXDI-50RF Dynamic/Static Digital Radiography System can take up to 30 fps in 9" x 9" field of view (15 fps in full field 14" x 17"). Similar to a cassette tray, the docking station is equipped with an active cooling system.
  • High Resolution Images
    Easily acquired, the 160µm pixel pitch produces smooth, high resolution images in both radiographic and fluoroscopic views. A high definition monitor (sold separately) can be added to help make the fine details viewable. Live motion images (fluoroscopic only) are immediately available on-screen and radiographic images are available on-screen 2-4 seconds after exposure.
  • Control Software
    Advanced image processing and standard DICOM® functions are available in the control software made especially for the CXDI-50RF Dynamic/Static Digital Radiography System. X-ray controls from the generator can be ported into the control software as well.
  • Enhanced Productivity and Program Imaging Mode
    Program Imaging Mode for Canon CXDI Digital Radiography control software with DICOM Modality Worklist assists in optimizing workflow in the imaging suite and help improve productivity. This high performance solution utilizes the Procedure Code ID from the RIS to configure the exam on the CXDI Digital Radiography system.
  • Seamless Network Integration
    Ethernet 10/100/1000 Base T connectivity with DICOM 3.0 compatibility enables seamless data transfer to any DICOM hard copy output device, PACS, or HIS/RIS for efficient printing, archiving, and remote viewing of images. The system complies with IHE® (Integrating the Healthcare Enterprise) standards for interoperability resulting in easy, effective integration with the hospital network.
This is to make Misc appear on the page when needed.
DISCLAIMERS
*Only sold with the RadPRO® SOLEGRA® 500 Universal RF System.
 Return to Top
