Web Content Viewer
Actions
EF-M 11-22mm f/4-5.6 IS STM
EF-M
MSRP: ¤400
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
See the possibilities provided by the EOS M Series of digital cameras and EF-M Lenses.
EOS M Series
  • Wide-angle zoom lens for EOS M series digital cameras with Optical Image
  • Stabilizer for up to three equivalent stops of shake correction.
  • Lens retraction mechanism shortens the length of the lens and a compact, lightweight design allows easy portability.
  • Rear focus system and built-in stepping motor (STM) help provide smooth and quiet continuous autofocus when shooting video with an EOS M series digital camera.
  • Dynamic IS (Movie Shooting Mode only) helps deliver a wide image stabilization correction range, making it ideal for shooting while walking.
  • Two aspheric lens elements and one UD lens element deliver superb image quality from the center to the periphery.
  • Circular aperture (7 blades) helps deliver beautiful, soft backgrounds.
  • Full-time manual focus allows manual focus adjustment after autofocusing.
  • Minimum focusing distance: 5.9 in/0.15m.
  • Maximum magnification of 0.30x at the telephoto end.
This is to make Misc appear on the page when needed.
Specifications
Focal Length & Maximum Aperture
11-22mm f/4-5.6
Lens Construction
12 elements in 9 groups
Diagonal Angle of View
102°10'–63°30'
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
0.49 ft./0.15m
Filter Size
2.2 in./55mm diameter
Max. Diameter x Length, Weight
2.4 x 2.3 in., approx. 7.8 oz.
60.9 x 58.2mm, approx. 220g
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-M 11-22mm f/4-5.6 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
