Web Content Viewer
Actions
EF-M 18-150mm f/3.5-6.3 IS STM Graphite
EF-M
Item Code: 1375C002AA
EOS M Series
Stylish, compact and powerful. See the possibilities of the EOS M family.
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Features
Canon's First EF-M High Zoom Power Lens Covering a Broad Range of Shooting Scenes
From scenic landscapes to close-up intimate portraits, the EF-M 18–150mm f/3.5–6.3 IS STM's wide zoom ratio of up to 8.3x can help you capture both of these scenes without changing lenses. The 29mm-equivalent wide angle can help capture the entire mountain range, while the 240mm-equivalent telephoto lets you highlight just one peak.
Compact and Lightweight Design
To bolster its extensive zoom range, the EF-M 18–150mm f/3.5–6.3 IS STM is compact and lightweight, measuring only 3.4 in. long and 2.4 in. in diameter, and weighing approximately 10.6 oz. It's designed for easy portability, making it an ideal walk-around lens for everyday scenes, vacations and more.
Optical Design Helps Provide Excellent Image Quality
Featuring 17 lens elements in 13 groups, the EF-M 18–150mm f/3.5–6.3 IS STM's advanced optical design helps ensure high image quality throughout its zoom range, comparable to the EF-S 18–135mm f/3.5–5.6 IS USM lens. Optimal element placement, including one UD (Ultra Low Dispersion) lens element and two aspherical lens elements, helps minimize chromatic aberrations and fringing to help keep contrast and color accuracy high.
Maximum Magnification of 0.31x at Focal Length 150mm
To help you capture virtually every detail, the EF-M 18–150mm f/3.5–6.3 IS STM provides a maximum magnification of 0.31x at focal length 150mm. Zoom in and see the texture of a flower's petals, the eyelashes on a friend's face or the whiskers on a cat's nose. The closest focusing distance is 0.82 ft. at 18–50mm or 1.48 ft. at 150mm, meaning you can get right up close to your subject with ease.
Image Stabilizer Effect at up to 4* Stops of Shake Correction
For consistently sharp results, the EF-M 18–150mm f/3.5–6.3 IS STM features an improved Image Stabilizer system that provides significantly enhanced shake reduction for up to 4 stops* of shutter speeds. This means more reliable handheld performance and clearer detail in low-light situations or at lower ISOs. Because of its enhanced stabilization, the EF-M 18–150mm f/3.5–6.3 IS STM can also help minimize the need for a tripod.
* Measured at the focal length of 150mm (35mm equivalent of 360mm), using the EOS M3 digital camera based upon CIPA (Camera & Imaging Products Association) standards.
Combination IS is Achieved When Used with the EOS M5 Digital Camera
To help significantly reduce blur in videos due to camera shake, the EF-M 18–150mm f/3.5–6.3 IS STM features Combination IS when used with the EOS M5 digital camera. This hybrid system augments the EF-M 18–150mm f/3.5–6.3 IS STM's mechanical image stabilization with the 5-axis Digital Image Stabilization in the camera itself. This means that if you need to move the camera when recording video, your results can remain sharp and clear.
Panning Feature is Supported When Used with the EOS M5 Digital Camera
When used in conjunction with the EOS M5 digital camera, the EF-M 18–150mm f/3.5–6.3 IS STM helps you achieve a smooth panning effect. The camera detects the subject of the photo, then the lens and camera work together to keep accurate focus. The image stabilization system assists by helping to minimize blur due to the camera's movement. Combined, they deliver photos and videos of subjects caught sharply in motion, with the background artistically blurred.
Specifications
Focal Length & Maximum Aperture
18-150mm, f/3.5-5.6
Lens Construction
17 elements in 13 groups
Diagonal Angle of View
74°20' - 27°50'
Focus Adjustment
AF with full-time manual possible when [AF+MF] is selected on camera
Closest Focusing Distance
0.82 ft. / 0.25m (at 18-50mm)1.48 ft. / 0.45m (at 150mm)
Zoom System
Rotating Type
Filter Size
2.2 in. / 55mm diameter
Max. Diameter x Length, Weight
Φ2.4 x 3.4 in., approx. 10.6 oz. / Φ60.9 x 86.5mm, approx. 300g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-M 18-150mm f/3.5-6.3 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
DISCLAIMERS
 Return to Top
