Web Content Viewer
Actions
EF 85mm f/1.4L IS USM
Standard & Medium Telephoto
Item Code: 2271C002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Features
Canon's First 85mm L-series with IS Capability
The EF 85mm f/1.4L IS USM marks a new level of agility in a medium-telephoto lens as Canon's first 85mm L-series lens to incorporate Image Stabilization. It delivers up to 4* stops (CIPA Standard) of stabilization, making handheld operation possible in a vastly increased number of scenarios from portraiture to snapshots and everywhere in between.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS-1D X Mark II SLR camera. The number of stops may vary based on the camera model used.
Large, Bright f/1.4 Aperture
The EF 85mm f/1.4L IS USM features a large f/1.4 maximum aperture, which produces a shallow depth of field for beautiful background blur, captures at a fast shutter speed, a bright viewfinder image as well as easy operation in low-light situations. Combined with its built-in IS, the EF 85mm f/1.4L IS USM helps capture images in a variety of environments where other lenses may require the use of a flash or alternate lighting source.
Image Stabilization at up to 4* Stops of Shake Correction
For consistently sharp results, the EF 85mm f/1.4L IS USM features an Image Stabilizer system that provides significant shake reduction for up to 4* shutter speed steps. This helps provide reliable handheld performance and clear image detail in low-light situations or at lower ISOs. Because of Image Stabilization, the EF 85mm f/1.4L IS USM can also help minimize the need for a tripod.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS-1D X Mark II SLR camera. The number of steps may vary based on the camera model used.
GMo Aspherical Lens with Air Sphere Coating Technology
The EF 85mm f/1.4L IS USM is engineered to help render crisp and clear images. For high-contrast images that remain sharp from corner to corner of the composition, it features a molded glass (GMo) aspherical lens, and the Image Stabilizer lens is coated with Canon's Anti-reflective Coating (ASC) technology for significantly reduced flare and ghosting from reflected light.
Dust- and Water-resistant Professional-grade Design
Built to L-series specifications, the EF 85mm f/1.4L IS USM not only offers optical excellence but is designed to perform in even the most challenging environments. It delivers a dust- and water-resistant construction with seals around the switch panel, the focus rings and the mount. The surface of the lens even features a smudge-resistant fluorine coating that repels water and oil and can easily be cleaned with a dry cloth.
Circular Aperture (9 blades) for Beautiful Bokeh
Thanks to its 9-blade, circular aperture, the EF 85mm f/1.4L IS USM is capable of gorgeous, evocative out-of-focus areas and soft backgrounds. With an incredible level of control over background blur, the 9-blade circular aperture helps create intimacy and intensity in both photos and videos for impactful results.
33.5 in/85cm Minimum Focusing Distance
With a minimum focusing distance of 33.5 in./85cm, the EF 85mm f/1.4L IS USM enables operation close to the subject, perfect for intimate portraits, headshots and detail work.
High-speed AF Using Ring USM Technology and Rear Group Focusing
To help capture every movement, the EF 85mm f/1.4L IS USM features a fast and near-silent AF system. It uses an inner focusing ring USM (ultrasonic motor) system that works with a high-speed CPU and optimized AF algorithms to help deliver precise, lightning-fast performance. For even more refinement, the EF 85mm f/1.4L IS USM offers full-time manual focus as well.
Specifications
Focal Length & Maximum Aperture
85mm f/1.4
Lens Construction
14 elements in 10 groups
Diagonal Angle of View
28° 30'
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
2.79 ft. / 0.85m
Filter Size
77mm
Max. Diameter x Length, Weight
Φ3.5 x 4.1 in., approx. 33.5 oz. / Φ88.6 x 105.4mm, approx. 950g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 85mm f/1.4L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Sample Images
More Details
More Details
More Details
Videos
Introducing the Canon EF 85mm f/1.4L IS USM
Introducing the Canon EF 85mm f/1.4L IS USM lens. This is a classic portrait-length telephoto lens which combines great image quality, focusing speed, Image Stabilization, and excellent low-light performance.
Effect of Image Stabilization in the Canon EF 85mm f/1.4L IS USM
Watch how the Image Stabilization in the Canon EF 85mm f/1.4L IS USM lens helps when shooting handheld stills at slower shutter speeds and the effect when shooting video.
Canon EF 101: Series Overview
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: Telephoto Lenses
Telephoto lenses let you get close in on a subject. Canon expert Jon Lorentz shows you how to get the most out of your Canon telephoto lenses.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
DISCLAIMERS
 Return to Top
