Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 24-105mm f/3.5-5.6 IS STM
Standard Zoom
Canon Store: $
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Overview
The EF 24-105mm f/3.5-5.6 IS STM lens is the first Canon EF standard zoom lens for full-frame sensor cameras to include a lead screw-type stepping motor (STM) for smooth and quiet AF and tracking while shooting movies or still images. It offers top-notch image quality thanks to two aspheric lenses and a UD lens for sharpness and clarity; optimized lens placement and advanced coatings that reduce ghosting and flare while delivering remarkable color balance; and a 7-blade circular aperture diaphragm that creates gorgeous, soft backgrounds. The lens is compact, has an advanced image stabilization system for up to four stops of compensation, and offers full time manual focus. With full-frame compatibility, outstanding STM AF performance, and covering a popular zoom range, the EF 24-105mm f/3.5-5.6 IS STM is an excellent choice.
Features
- The first standard zoom EF lens for full frame sensor cameras to include a lead screw—type stepping motor (STM).
- The focusing mechanism employs an inner focus lens, a stepping motor and lead screw to support the Canon EOS Movie Servo AF function and provide smooth and quiet continuous AF during video recording, as well as when shooting photos.
- Optical Image Stabilizer provides up to four shutter speed stops of correction*.
- New 7—group zoom optics allows for a conveniently compact design and outstanding optical performance.
- Two aspheric lenses plus a UD lens combine to provide high—quality results for both still images and movies.
- Circular aperture (7 blades) delivers beautiful, soft backgrounds.
- Optimized lens placement and coatings deliver exceptional color balance, while minimizing ghosting and flare.
- Inner focusing system, high—speed CPU and improved AF algorithm allow high-speed autofocus.
- Full—time manual focus allows manual focus adjustment while in AF Mode.
- *According to CIPA (Camera & Imaging Products Association) standards.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Approx. 18.52 oz. / 525 g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 24-105mm f/3.5-5.6 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
77mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 460.0
77mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter.
MSRP: 95.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Lens Cap E-77 II
The Lens Cap E-77 II is newly designed and fits Canon EF lenses with a 77mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 15.0
Lens Case LP1219
Soft drawstring lens case made for Canon EF 135mm f/2.0L, EF 24-70mm f/2.8, EF 28-70mm f/2.8L, EF 100mm f/2.8 USM, EF 50mm f/1.0L or EF 85mm 1.2L USM lens.
MSRP: 40.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood EW-83M
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 40.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
- ${title}${badge}
