Web Content Viewer
Actions
EF 24-105mm f/4L IS II USM
Standard Zoom
Item Code: 1380C002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Features
All-new optical design with improvements in peripheral brightness
The EF 24–105mm f4/L IS II USM’s new optical composition includes 17 elements in 12 groups, including 4 glass-molded (GMo) aspherical lenses on 5 surfaces for excellent overall resolving power. These improvements help increase peripheral brightness for better edge-to-edge results with reduced distortions, delivering still photos and video of great clarity and resolution.
High-performance standard zoom lens with constant f/4L aperture and a broad angle of view covering wide-angle to mid-telephoto
Offering coverage from 24mm wide-angle to 105mm mid-telephoto, the EF 24–105mm f/4L IS II USM is a true walk-around lens that can be used for any number of shooting scenarios. From landscapes and portraits to snapshots and videos of breaking news, and anything else that catches the photographer’s or filmmaker’s eye, the EF 24–105mm f/4L IS II USM range is highly adaptable. You can spend less time changing lenses and more time taking pictures or recording video.
Air Sphere Coating (ASC) helps to significantly reduce flare and ghosting
The EF 24–105mm f/4L IS II USM features Air Sphere Coatings (ASC) on its lens elements to help combat flare, ghosting and reflections, and deliver clean images with reduced aberrations from reflected light. Designed to significantly reduce distortions, this technology puts an ultra-low refractive layer on the lens element. This layer works with the EF 24–105mm f/4L IS II USM’s overall optical formula to help deliver a clean image to the camera’s sensor, which can decrease the need for post-production.
Image Stabilizer performance at up to 4 stops* of shake correction helps capture sharp images
For consistently sharper results, the EF 24–105mm f/4L IS II USM features an improved Image Stabilizer system that provides significantly enhanced shake reduction for up to 4 stops* of shutter speeds. This means more reliable handheld performance and clearer detail in low-light situations or at lower ISOs. Because of its enhanced stabilization, the EF 24–105mm f/4L IS II USM can also minimize the need for a tripod.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS-1D X digital SLR camera at a focal length of 105mm. The number of stops may vary based on the camera model used.
Circular aperture (10 blades) helps deliver beautiful, soft backgrounds
Thanks to its 10-blade, circular aperture, the EF 24–105mm f/4L IS II USM is capable of gorgeous, evocative out-of-focus areas and soft backgrounds throughout its zoom range. By delivering an incredible level of control over background blur, it helps you define the mood of your image, creating impactful photos and videos.
Fluorine coating on front and rear lens surfaces helps reduce smears and fingerprints
To help maintain a clean lens, even after multiple lens changes in sub-optimal conditions, the EF 24–105mm f/4L IS II USM has a specially designed non-stick fluorine coating on its front and rear surfaces. This fluorine coating helps prevent dust, water, oil and other surface residue like fingerprints from sticking to the lens, resulting in quick and easy wiping, without the use of solvents.
Highly resistant to dust and water intrusion, enabling shooting even in harsh conditions
Befitting an L-series lens, the EF 24–105mm f/4L IS II USM is built to endure photography and moviemaking in even the harshest conditions. It features a dust- and water-resistant construction on the switch panel, the zoom and focus rings, and on the lens mount, helping to prevent dust and moisture from interfering with operation.
Inner focusing, ring USM, high-speed CPU and optimized AF algorithms for fast and accurate autofocusing
The EF 24–105mm f/4L IS II USM is engineered to provide fast, accurate operation for efficient performance across the board. It features a high-performance control CPU that drives Canon’s quick inner focusing with ring USM for quick starts and stops. Plus, it’s programmed with optimized AF algorithms that help achieve fast, accurate focus and maintain it consistently.
Full-time manual focus allows manual focus adjustment while in AF mode
The EF 24–105mm f/4L IS II USM offers complete manual control, even when AF is engaged, with a simple twist of the lens’s focus ring. Additionally, full-time manual focus means it’s easy to achieve and maintain focus manually, which can be especially handy when shooting video or composing still images on an SLR’s screen.
Specifications
Focal Length & Maximum Aperture
24-105mm f/4
Lens Construction
Diagonal Angle of View
84°00' - 23° 20'
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
1.5 ft. / 0.45m
Filter Size
3.0 in. / 77mm diameter
Max. Diameter x Length, Weight
φ3.3 x 4.7 in., approx. 28.04 oz. / φ83.5 x 118mm, approx. 795g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 24-105mm f/4L IS II USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
 Return to Top
