Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 24-105mm f/4L IS USM
Standard Zoom
Canon Store: $
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
This easy-to-use standard zoom lens can cover a large zoom area ranging from 24mm wide-angle to 105mm portrait-length telephoto, and its Image Stabilizer Technology steadies camera shake up to three stops. Constructed with one Super-UD glass element and three aspherical lenses, this lens minimizes chromatic aberration and distortion. The result is excellent picture quality, even at wide apertures. Canon's ring-type USM gives silent but quick AF, along with full-time manual focus. Moreover, with dust- and moisture-resistant construction, this is a durable yet sophisticated lens that meets the demands of advanced amateur photographers and professional photographers alike.
Sample Image
MTF Charts
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Zoom System
Filter Size
Max. Diameter x Length, Weight
Brochures
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 24-105mm f/4L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
77mm Circular Polarizer PL-C
MSRP: 250.0
77mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 460.0
77mm Close-Up Lens 500D
Canon Close-Up Lens 500D is a double-element accessory that attaches to front of lens. It changes closest focusing distance from infinity to 500mm (approx. 19.7" from front of lens).
MSRP: 220.0
77mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter.
MSRP: 95.0
77mm UV Haze Filter
UV Protector filters allow you to correct for the UV effect to varying degrees. These filters can also help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter, please see Compatibility tab for compatible lenses.
MSRP: 55.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Gelatin Filter Holder Adapter IV 77
The 77mm Gelatin Filter Holder Adapter IV 77 is used to attach the Gelatin Filter Holder IV to most EF lenses.
MSRP: 60.0
Gelatin Filter Holder Hood IV
Allows 4-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods IV.
MSRP: 45.0
MSRP: 150.0
Lens Cap E-77 II
The Lens Cap E-77 II is newly designed and fits Canon EF lenses with a 77mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 15.0
Lens Cap E-77U
Indispensable for protecting your valuable lenses, this cap should be used on all lenses with a 77mm filter size.
MSRP: 12.0
Lens Case LP1219
Soft drawstring lens case made for Canon EF 135mm f/2.0L, EF 24-70mm f/2.8, EF 28-70mm f/2.8L, EF 100mm f/2.8 USM, EF 50mm f/1.0L or EF 85mm 1.2L USM lens.
MSRP: 40.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood EW-83H
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 70.0
- ${title}${badge}
