Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 28-135mm f/3.5-5.6 IS USM
Standard Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
Standard zoom lens with an Image Stabilizer and high zoom ratio. With the Image Stabilizer turned on, you can obtain sharp, natural-looking pictures in dim lighting without using flash or a tripod. Very handy for places where flash is prohibited. Uses ring-type USM for swift, silent autofocus and full-time manual focus. Closest focusing distance is 20 in. (50cm).
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Zoom System
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 28-135mm f/3.5-5.6 IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
72MM UV Protector Filter
UV Protector filters allow you to correct for the UV effect to varying degrees. These filters can also help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 72mm diameter, please see Compatibility tab for compatible lenses.
MSRP: 25.0
72mm Circular Polarizer PL-C
Polarizing filters enhance picture quality by blocking harmful reflected light. Use it to reduce light reflections from glass and water surfaces or to improve color saturation. Simple to use, these filters polarize light circularly, rather than linearly, so they do not interfere with autofocus or TTL light metering.
MSRP: 230.0
72mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 400.0
72mm Close-Up Lens 500D
MSRP: 190.0
72mm Protect Filter
UV Protector filters allow you to correct for the UV effect to varying degrees. These filters can also help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter, please see Compatibility tab for compatible lenses.
MSRP: 85.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Lens Cap E-72 II
The Lens Cap E-72II is newly designed and fits Canon EF lenses with a 72mm filter size. It helps protect the front glass from dust and scratches.
Lens Cap E-72U
MSRP: 8.5
Lens Case LP1116
Lens pouch cases and the zipper-type soft cases are compact, yet keep your lenses looking like new.
MSRP: 35.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood EW-78BII
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs. Compatible with: EF 28-135 IS.
MSRP: 35.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
