Web Content Viewer
Actions
EF-M 15-45mm f/3.5-6.3 IS STM Graphite
Standard Zoom
Item Code: 0572C002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
See the possibilities provided by the EOS M Series of digital cameras and EF-M Lenses.
EOS M Series
Features
  • Compact and stylish standard zoom lens with image stabilization for EOS M series digital cameras.
  • A stepping motor (lead screw-type STM) helps provide smooth and quiet operation when taking photos, and near-silence when shooting videos.
  • High-speed, high-precision autofocusing is achieved by utilizing the full-time manual focus mode (AF+MF) to make fine adjustments after focusing.
  • Optical Image Stabilizer technology helps reduce camera shake, and achieves a level of sharpness equivalent to a shutter speed 3.5 settings faster* for great performance even when using for handheld photography.
  • Efficiently designed with three aspheric lenses and uses short back focus to help produce high-quality results.
  • Lens retraction mechanism helps shorten the length of the lens and a compact, lightweight design allows easy portability.
  • Optimized lens placement helps to minimize ghosting and flare.
This is to make Misc appear on the page when needed.
Specifications
Focal Length & Maximum Aperture
15-45mm f/3.5-6.3
Lens Construction
10 elements in 9 groups
Diagonal Angle of View
84°30'-33°40'
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
0.82 ft./0.25m
Filter Size
1.9 in./49mm diameter
Max. Diameter x Length, Weight
2.40 x 1.76 in., approx. 4.6 oz.
60.9 x 44.5mm, approx. 130g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-M 15-45mm f/3.5-6.3 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
 Return to Top
