Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF-S 18-55mm f/3.5-5.6 IS STM
Standard Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
Designed for high-quality still image and video capture while being compact and lightweight, the new EF-S 18-55mm f/3.5-5.6 IS STM lens features the optics, AF and image stabilization necessary for shooting in any number of situations. For brilliant image quality it has one high-precision aspheric lens to reduce chromatic aberration throughout the zoom range. It features optimized lens coatings to ensure exceptional color balance while minimizing ghosting and flare and a 7-blade circular aperture to ensure beautiful, soft backgrounds. For outstanding performance, the EF-S 18-55mm f/3.5-5.6 IS STM lens perfectly complements the Movie Servo AF feature found on select EOS Cameras with a compact six-group zoom system and a new stepping motor and focus mechanism to deliver smooth and quiet continuous AF during movie shooting. Still photography benefits from a high-speed CPU and an optimized AF algorithm. Full-time manual focus is available in AF mode and the front element does not rotate during focus, perfect for use with polarizing filters. Handheld photography is enhanced by the lens' Optical Image Stabilizer system, offering the equivalent of four stops of compensation. Compact and highly versatile, it is the ideal lens to carry anywhere.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-S 18-55mm f/3.5-5.6 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Gelatin 52mm Adapter Ring
Canon Gelatin Filter Holder Adapter III used to attach Gelatin Filter Holder III to most Canon EF lenses.
MSRP: 45.0
58mm Circular Polarizer PL-C
MSRP: 170.0
58mm Close-up Lens 250D
Double-element accessory attaches to front of lens, changes closest focusing distance from infinity to 250mm (approx. 9.9") from front of lens.
MSRP: 130.0
58mm Close-up Lens 500D
Double Element accessory attaches to front of lens or to adapter. Changes closest focusing distance from infinity to 500mm (approx. 19.6"") from front of lens. For use with most EF lenses and PowerShot cameras. Requires Conversion Lens Adapter which is specific to camera model.
MSRP: 130.0
58mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 58mm diameter.
MSRP: 45.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Gelatin 58mm Adapter Ring
Gelatin Filter Holder Adapter IV used to attach Gelatin Filter Holder IV to most Canon EF lenses.
MSRP: 50.0
LENS HOOD EW-63C
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 29.0
Lens Cap E-58
Indispensable for protecting your valuable lenses, this cap should be used on all lenses with a 52mm filter size.
MSRP: 8.5
Lens Cap E-58 II
The Lens Cap E-58 II is newly designed and fits Canon EF lenses with a 58mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Case LP1016
Lens pouch cases and the zipper-type soft cases are compact, yet keep your lenses looking like new.
MSRP: 35.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
