Web Content Viewer
Actions
RF 28-70mm F2 L USM
Standard Zoom
Item Code: 2965C002AA
Features
Bright, Constant f/2 USM Zoom Lens
For a stunningly bright f/2 aperture throughout the zoom range, look no further than the amazing RF 28–70mm F2 L USM. It is the world's first autofocus zoom lens compatible with 35mm full frame sensors to have a maximum f/2 aperture*. Thanks to the large-diameter RF mount and short back focus design, the RF 28–70mm F2 L USM also features a balanced and comfortable size for unfettered operation, amazing performance in low-light areas and sharp images with gorgeous background blur at various focal lengths.
High Image Quality at f/2 that Rivals the EF 24–70mm f/2.8 at f/2.8
Thanks to an optical design made possible by the RF mount, the RF 28–70mm F2 L USM lens is able to render image quality at f/2 that rivals that of the EF 24–70mm f/2.8 at f/2.8. With an extra stop of light, this means faster shutter speeds or lower ISOs for enhanced image quality, and marvelous performance when shooting movies.
High Precision and Flexibility to Match Fixed Focal Length Lenses
With a brilliant optical design and speedy performance, the RF 28–70mm F2 L USM lens delivers the flexibility, performance and image quality of 28mm, 35mm, 50mm and 70mm fixed focal length lenses in one discreet package. Combining the outstanding performance, brightness and versatility of several focal lengths into one lens, the RF 28–70mm F2 L USM lens performs with reassuring consistency, especially in high-pressure situations where quality matters and there's no time for lens changes.
Control Ring for Direct Setting Changes
The RF 28–70mm F2 L USM lens incorporates a control ring on the lens barrel that can directly adjust numerous settings including shutter speed, aperture, exposure compensation and more. Located towards the front of the lens and effectively adding a third dial to the EOS R camera's main dial and quick control dial, the control ring has a tactile, easily distinguished surface and features a clicking mechanism that provides tangible feedback for confident use while looking through the viewfinder. For photographers and moviemakers who would prefer a silent control ring, the clicking mechanism can be removed by a Canon service provider for a fee.
High Reliability and Durability for Professional Use
Like all L series lenses, the RF 28–70mm F2 L USM lens is built to endure the rigors of professional use. Constructed to be rugged, refined and precise, it can be operated intuitively so concentration can remain on the subject at hand.
Vibration Shock Resistance
Engineered to accommodate its optical system, the RF 28–70mm F2 L USM lens features L series level vibration shock resistance in the lens barrel, helping to maintain focus and settings even in turbulent situations.
Dust- and Water-resistant
For reliable performance even when weather conditions get difficult, the RF 28–70mm F2 L USM lens features dust- and water-resistant construction in the lens mount, switch panel and all rings.
Fluorine Coating
The RF 28–70mm F2 L USM lens features fluorine coatings on the front and rearmost surfaces to help prevent dirt and dust from sticking to the lens, making it easy to clean smudges and fingerprints off.
High-speed Communication with the EOS R Camera
Designed to quickly process data, the RF 28–70mm F2 L USM features a 12 pin communication system that is the fastest yet for a Canon lens/camera combination. This accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
Lens Information Display
Another helpful feature, the EOS R camera can display lens information right in the viewfinder, making it easy to confirm the lens's focal length without looking away from the subject at hand.
In-camera Digital Lens Optimizer
The EOS R system's 12 pin communication system enables the Digital Lens Optimizer, which works in-camera to combat aberrations and image deterioration, especially in the edges of the image frame when shooting at a large aperture. Data from the RF 28–70mm F2 L USM lens is transferred automatically to the camera body, facilitating near immediate correction for clear, detailed images.
Two UD Elements and One Super UD Element
The RF 28–70mm F2 L USM features an all-new optical design built specifically for the RF mount. This includes four aspheric lenses that correct for aberrations, distortions and astigmatism, plus two UD elements and one Super UD element to reduce chromatic aberration and achieve high image quality across the board. Strategically placed coatings and a 9-blade aperture help ensure superlative quality images with sharp detail, gorgeous color and minimized distortion throughout the zoom range.
Air Sphere Coating (ASC) Minimizes Lens Flare and Ghosting
The RF 28–70mm F2 L USM lens features Canon's Air Sphere Coating (ASC), which significantly reduces the occurrence of lens flare and ghosting regardless of focal length or the angle of light. This helps provide clean results with minimal distractions and aberrations.
Specifications
Focal Length & Maximum Aperture
28-70mm f/2
Lens Construction
19 elements in 13 groups
Diagonal Angle of View
75°00'-34°00'
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
1.28 ft. / 0.39m
Filter Size
95mm
Max. Diameter x Length, Weight
Φ4.09 x 5.50 in., approx. 3.15 lbs. / Φ103.8 x 139.8mm, approx. 1430g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you RF 28-70mm F2 L USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
RF 24-105mm f/4L IS USM Tele MTF Chart
White Papers
EOS R System - A New Lens-Camera System
09/05/18
53.09 MB
Software Development Kit (SDK)
The Canon EOS Digital Camera Software Development Kit (EDSDK) enables developers to integrate select Canon cameras directly into their software application solutions, giving them access to remote camera control and communication functionality of the camera. There are two versions of the EDSDK compatible with Windows or Macintosh.
The Software Developer Kit is provided free of charge and can be found at DeveloperCommunity.usa.canon.com.
To learn more please visit the Canon Developer Community site and register to download Canon’s SDKs.
https://www.developersupport.canon.com
This is to make Misc appear on the page when needed.
Videos
Reimagine Optical Excellence
See how Canon’s new EOS R System can help reimagine optical excellence and help capture the beauty of the world.
Discovering Canon’s new EOS R System
Get to know Canon’s new EOS R System that enables maximum optical performance and opens up an exciting possibility to anyone wanting to capture creati ... read moreve images.
Introducing Canon’s RF Lenses
Discover Canon’s new RF lenses and EOS R camera’s features that help to deliver incredible possibilities.
Canon EOS R System Operability
Watch how Canon’s new EOS R system operations provide a high level of customization options for fast, intuitive shooting.
Canon EOS R Sample Video-Lake Natron
Watch and discover why the new EOS R System is set to make an impression on photographers and storytellers today and far into the future.
Discover the New Canon EOS R System with Rudy Winston
Find out all the great benefits and future possibilities the EOS R System has to offer with this insightful video hosted by Canon U.S.A. Technical Adv ... read moreisor, Rudy Winston.
Canon EF 101: STM Lenses
Canon STM lenses have stepping motors that allow you to focus quietly and follow your subject smoothly. Canon expert Jon Lorentz demonstrates the quiet smoothness of Canon's STM technology.
Sample Images
More Details
More Details
 Return to Top
