Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 400mm f/2.8L IS II USM
Super Telephoto
Canon Store: $
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Overview
The stellar combination of superlative optics, astonishing performance and brilliant construction, the EF 400mm f/2.8L IS II USM super telephoto is the professional's choice for a long lens, and perfect for nature and wildlife photography. Over 28% lighter than its predecessor and now the lightest lens in its class, the EF 400mm f/2.8L IS II USM features Fluorite optics that deliver sharper images with less chromatic aberration, a completely redesigned Image Stabilization system that offers up to four extra stops of performance, a newly-developed Fluorine coating that keeps soiling, smears and fingerprints to a minimum, plus new construction in line with only the best that Canon has to offer. With a third Image Stabilization mode (Mode 3) that activates IS only when the shutter button is fully pressed, and giving the equivalent effect of a shutter speed four stops faster, the EF 400mm f/2.8L IS II USM allows for easy panning and is ideally positioned for professional action photography. With a new security slot for wire-type security locks, buttons and switches are redesigned for intuitive, deliberate operation, and dust and water sealing keeps the lens functioning flawlessly in even the most challenging environments.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 400mm f/2.8L IS II USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Drop in Gelatin WII 52MM
A holder for screw-type filters, for use with rear mounted drop-in filters. Filter fits select lenses with a 52mm diameter, please see link below for compatible lenses.
MSRP: 160.0
FILTER DROPIN PL-C WII 52MM
MSRP: 320.0
Filter Drop in Screw Holder 52II
MSRP: 170.0
Lens Cap E-180D
MSRP: 140.0
Lens Case 400C
MSRP: 860.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood ET-155 (WII)
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
Lens Wide Strap B
MSRP: 55.0
Raincover Large
MSRP: 125.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.Canon EF 101: Telephoto Lenses
Telephoto lenses let you get close in on a subject. Canon expert Jon Lorentz shows you how to get the most out of your Canon telephoto lenses.Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
- ${title}${badge}
