Web Content Viewer
Actions
RF100-500mm F4.5-7.1 L IS USM
Super Telephoto
Item Code: 4112C002AA
Be the Revolution - EOS R System
The EOS R System expands the EOS lineup with full-frame mirrorless cameras, the RF lens series, optional mount adapters for compatibility with EF/EF-S lenses, and a game-changing RF lens mount at the heart of it all. Learn more.
Features
High Performance L-series versatile Super-Telephoto Zoom RF Lens
The RF100-500mm F4.5-7.1 L IS USM lens is a highly portable option for EOS R series camera users from professionals to advanced amateurs shooting sports, wildlife, photo journalism, aviation subjects and more, providing a wide zoom range from medium telephoto to super telephoto, with high quality results.
Optical Image Stabilization with up to 5 Stops* of Shake Correction
The RF100-500mm F4.5-7.1 L IS USM lens is designed to work in conjunction with EOS R series cameras, with both the camera and the lens sharing data to dramatically reduce camera-shake blur, regardless of the situation, whether shooting video or stills. With up to 5 stops* of optical image stabilization, it delivers impressively clear results.
Three Image Stabilization Modes (Standard, Panning, and during exposure only) for Creative Versatility
Three image stabilization modes (standard, panning, and during exposure only) provide corrective camera shake functions for outstanding results in a wide range of shooting situations. These include when shooting stationary subjects like portraits (IS Mode 1); helping to correct vertical camera shake when panning horizontally, or horizontal camera shake when panning vertically, depending on the camera’s orientation (IS Mode 2); and when tracking movement during a sporting event, for example (IS Mode 3).
High Speed, Smooth and Quiet Auto Focus with Dual Nano USM
The RF100-500mm F4.5-7.1 LIS USM lens uses two NANO USM focus motors which provide a near-silent, power saving, and high-speed auto focus operation so fast moving subjects can more accurately be tracked and captured without missing the moment for both stills and movies.
Minimum Focusing Distance of 2.95ft. / 0.9 m**
With a minimum focusing distance of 2.95ft./0.9m (at 100mm or 3.9 ft./1.2m at 500mm), the RF100-500mm F4.5-7.1 L IS USM lens is capable of capturing sharp and detailed images from various distances. Whether you're photographing birds, landscapes or a sporting event, the RF100-500mm F4.5-7.1 L IS USM lens' combination of impressive minimum focusing distance and a maximum magnification of 0.33x at 500mm provides outstanding versatility and impressively sharp images.
Rotation-type Zoom Ring and Torque Adjustment allows for Precise Composition or Traveling Convenience
Rotation-type zoom ring allows you to adjust from Smooth to Tight for more precise composition and excellent balance when handholding.
12-pin Communication System
Designed to quickly communicate shooting data, the RF100-500mm F4.5-7.1 L IS USM features the 12 pin communication system inherent in all RF lenses. This helps coordinate complex processes requiring high-speed communication and large data transfer, such as fast AF response with broader AF area, Image Stabilization, the Digital Lens Optimizer, and even the adjustment of the customizable Lens Control Ring for a quick and efficient user experience.
Dust and Weather-resistant with Flourine Coating
For reliable performance even when weather conditions get difficult, the RF100-500mm F4.5-7.1 L IS USM lens features a dust-and weather-resistant construction in the lens mount, switch panel and all rings. Sealing is applied to lens joining sections, and switch panels to help prevent water and dust from entering into the lens.
The RF100-500mm F4.5-7.1 L IS USM lens features fluorine coatings on the front and rearmost surfaces to help prevent oil and water from adhering to the lens, making it easy to clean smudges and fingerprints off.
One Super UD Lens and Six UD Elements
The RF100-500mm F4.5-7.1 L IS USM lens features an optical design built specifically for the RF mount. This includes one Super UD lens, plus six UD elements to reduce both axial chromatic aberration and chromatic aberration of magnification to achieve high image quality throughout the zoom range. Additionally the inclusion of Air Sphere coating is employed to alleviate flare and ghosting.
Lens Hood with Side Window allows Specialty Filters to be Adjusted even while Lens Hood is Attached
The lens hood features a sliding side window for easy operation and adjustment of specialty filters such as PL filters even with the hood attached.
Compatible with Extenders RF1.4x and RF2x***.
When used in combination with the Extender RF1.4x or RF2x, you’ll be able to reach even further subjects that would traditionally require much longer focal lengths. With the RF 1.4x attached it is possible to achieve a range of 420-700mm at f/8-10, or a range of 600-1000mm at f/11-14 with RF2x attached.
Specifications
Focal Length & Maximum Aperture
100-500mm, f/4.5-7.1
Maximum Aperture (1/3 steps, 1/2 steps)
Wide: 4.5, 4.5, Tele: 7.1, 6 .7
Minimum Aperture (1/3 steps, 1/2 steps)
Wide: 32, 32, Tele: 51, 5 4
At 100mm: 2.95 ft. / 0.9m
At 300 mm: 3.28 ft. / 1m
At 500mm: 3.94 ft. / 1.2m
Maximum Magnification
At 100mm: 0.12x
At 500mm: 0.33x
Lens Construction
20 elements in 14 groups
Special Elements
One Super UD, Six UD
Filter Size Diameter
Ø77mm
Aperture Blades
9
Maximum Outer Diameter x Length
Shortest (wide): Approx. 3.69 in x 8.17 in. / 93.8mm x 207.6mm
Longest (tele): Approx. 3.69 in x 11.71 in. / 93.8mm x 297.6mm
Weight
Approx. 3.0 lbs. / 1365g (No tripod mount)
Approx. 0.35 lbs / 160g (Tripod only)
RF 24-70mm F2.8 L IS USM
  • RF100-500mm F4.5-7.1 L IS USM
  • Lens cap E-77II
  • Lens hood ET-83F (WIII)
  • Lens case LZ1328
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you RF100-500mm F4.5-7.1 L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Sample Images
More Details
More Details
This is to make Misc appear on the page when needed.
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
DISCLAIMERS
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 500mm using the EOS R camera.
** 2.95 ft. / 0.9m (at 100mm), 3.9ft. / 1.2m (at 500mm).
*** Extenders can only be used from a 300-500mm range (cannot be used from 100-299mm).
 Return to Top
