Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 70-200mm f/2.8L IS II USM
Telephoto Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
Improving upon one of the most celebrated lenses in the Canon EF line is no easy feat, but Canon has done just that. The all-new EF 70-200mm f/2.8L IS II USM increases the speed, performance and optical quality of the EF 70-200 f/2.8L IS USM while maintaining all of the characteristics that have made it a legend for professionals and advanced amateurs alike. The EF 70-200mm f/2.8L IS II USM features one fluorite and five UD elements for increased optical quality and reduced chromatic aberration. It has a minimum focusing distance of 1.2m/3.9 ft. at all zoom settings, which is useful for photographers in smaller spaces trying to get closer to a subject. It features a next-generation Optical Image Stabilizer, providing up to 3.5 stops of correction at all focal lengths. And as with all L-series lenses, the EF 70-200mm f/2.8L IS II USM is dust- and moisture-resistant and designed for use in the challenging environments typical of rigorous professional use.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Lens Cap, Lens Hood and Pouch
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 70-200mm f/2.8L IS II USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
77mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 460.0
77mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter.
MSRP: 95.0
77mm UV Haze Filter
UV Protector filters allow you to correct for the UV effect to varying degrees. These filters can also help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter, please see Compatibility tab for compatible lenses.
MSRP: 55.0
Gelatin Filter Holder Adapter III 77
The Gelatin Filter Holder Adapter III allows the use of commercially available square filters without the need for cutting. The holder attaches to the lens through an adapter that fits the filter diameter. Use with 3-inch square type III gelatin filters. Gelatin filters can be used with most EF lenses.
MSRP: 60.0
Gelatin Filter Holder Adapter IV 77
The 77mm Gelatin Filter Holder Adapter IV 77 is used to attach the Gelatin Filter Holder IV to most EF lenses.
MSRP: 60.0
Lens Cap E-77 II
The Lens Cap E-77 II is newly designed and fits Canon EF lenses with a 77mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 15.0
Lens Cap E-77U
Indispensable for protecting your valuable lenses, this cap should be used on all lenses with a 77mm filter size.
MSRP: 12.0
Lens Case LZ1326
MSRP: 85.0
Lens: CarePAK PLUS (2YR)
CarePAK PLUS offers protection from accidental damage such as drops, spills, power surges, and more, including normal wear and tear, beyond the standard warranty period. It also includes Image Recovery (included with Cameras, Camcorders, and Printers with a memory card slot only), priority repair service, free return shipping, $0 deductible, genuine Canon factory service with only genuine Canon parts, and is transferable if you sell or gift your product. With a CarePAK PLUS, a damaged product will be repaired to good working condition or replaced with an equivalent product.
Lens: CarePAK PLUS (3YR)
Rain Cover ERC-E5S
Protects camera and lens when shooting during inclement weather conditions.
MSRP: 149.0
Raincover Small
Keeps your professional camera clean and dry when shooting in a wet environment. Compatible with Canon EOS Cameras. Contains attachable eyecups (L,S) for compatibility with all EOS Digital cameras. Transparent window enables clear visibility of the top and rear LCD panels and LC monitor. Front fastener enables easy attachment and removal of all lenses.
MSRP: 125.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
