Web Content Viewer
Actions
EF 70-200mm f/2.8L USM
Telephoto Zoom
Item Code: 2569A004AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Specifications
Focal Length & Maximum Aperture
70-200mm 1:2.8
Lens Construction
18 elements in 15 groups
Diagonal Angle of View
34° - 12°
Focus Adjustment
Inner focusing system with USM
Closest Focusing Distance
1.5m / 4.9 ft.
Zoom System
Rotating Type
Filter Size
77mm
Max. Diameter x Length, Weight
3.3 x 7.6, 2.9 lbs. / 84.6mm x 193.6mm, 1310g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 70-200mm f/2.8L USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
 Return to Top
