Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 70-200mm f/4L IS USM
Telephoto Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
The EF 70-200mm f/4L IS USM is a lightweight, compact L Series telephoto zoom lens with Image Stabilizer. The optical Image Stabilization in the new EF 70-200mm f/4L IS USM lens provides up to an incredible four stops of shake correction-a first for Canon IS lenses. The use of fluorite UD lens elements provides excellent optical performance in terms of resolution and contrast. These features, together with its water-and dust-proof construction, provide both the performance and portability to meet user demands.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Zoom System
Filter Size
Max. Diameter x Length, Weight
26.8 oz./760g (lens only)
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 70-200mm f/4L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
67mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 390.0
67mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 67mm diameter.
MSRP: 85.0
EF 1.4X Extender
MSRP: 429.99
EF 1.4X Extender
MSRP: 429.99
EF 2XII Extender
MSRP: 429.99
EF 2XII Extender
MSRP: 429.99
Extender EF 1.4x III
Extends focal length by a factor of 1.4x Built-in microcomputer for seamless communication with camera body, lens and extender Newly-developed Fluorine coating keeps soiling, smears and fingerprints to a minimum
MSRP: 429.99
Extender EF 2x III
Extends focal length by a factor of 2x Built-in microcomputer for seamless communication with camera body, lens and extender Newly-developed Fluorine coating keeps soiling, smears and fingerprints to a minimum
MSRP: 429.99
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Filter UV Haze 67mm
MSRP: 25.0
Gelatin Filter Holder Hood III
Canon Gelatin Filter Holder III allows 3-inch square gelatin filters to be fitted to most EF lenses.
MSRP: 45.0
Gelatin Filter Holder Hood IV
Allows 4-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods IV.
MSRP: 45.0
Allows 3-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods III.
MSRP: 140.0
Gelatin Filter Holder IV
MSRP: 150.0
Lens Cap E-67 II
The Lens Cap E-67 II is newly designed and fits Canon EF lenses with a 67mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Cap E-67U
MSRP: 8.5
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood ET-74
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 55.0
Lens: CarePAK PLUS (2YR)
CarePAK PLUS offers protection from accidental damage such as drops, spills, power surges, and more, including normal wear and tear, beyond the standard warranty period. It also includes Image Recovery (included with Cameras, Camcorders, and Printers with a memory card slot only), priority repair service, free return shipping, $0 deductible, genuine Canon factory service with only genuine Canon parts, and is transferable if you sell or gift your product. With a CarePAK PLUS, a damaged product will be repaired to good working condition or replaced with an equivalent product.
Lens: CarePAK PLUS (3YR)
Tripod Mount Ring A II W
Canon Tripod Mount Ring A II (W) for the EF 70-200mm f/4L Lens.
MSRP: 210.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Awards
Hot One Winner
