Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 70-300mm f/4.5-5.6 DO IS USM
Telephoto Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
A superior performance, ultra-compact telephoto zoom lens with Canon's Image Stabilization. These Diffractive Optics elements are combined to reduce size and boost image quality. AF is super-fast and silent with a ring-type USM, and it focuses down to 4.6 feet – without rotating the front element. A new zoom lock button keeps the lens safe and secure when not in use or used at the wide angle.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Zoom System
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 70-300mm f/4.5-5.6 DO IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Gelatin 52mm Adapter Ring
Canon Gelatin Filter Holder Adapter III used to attach Gelatin Filter Holder III to most Canon EF lenses.
MSRP: 45.0
58mm Circular Polarizer PL-C
MSRP: 170.0
58mm Circular Polarizer PL-CB
Polarizing filters enhance picture quality by blocking harmful reflected light. Use it to reduce light reflections from glass and water surfaces or to improve color saturation. Simple to use, these filters polarize light circularly, rather than linearly, so they do not interfere with autofocus or TTL light metering.
MSRP: 260.0
58mm Close-up Lens 250D
Double-element accessory attaches to front of lens, changes closest focusing distance from infinity to 250mm (approx. 9.9") from front of lens.
MSRP: 130.0
58mm Close-up Lens 500D
Double Element accessory attaches to front of lens or to adapter. Changes closest focusing distance from infinity to 500mm (approx. 19.6"") from front of lens. For use with most EF lenses and PowerShot cameras. Requires Conversion Lens Adapter which is specific to camera model.
MSRP: 130.0
58mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 58mm diameter.
MSRP: 45.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Gelatin 58mm Adapter Ring
Gelatin Filter Holder Adapter IV used to attach Gelatin Filter Holder IV to most Canon EF lenses.
MSRP: 50.0
Gelatin Filter Holder Adapter III 58
58mm adapter ring. Used to attach Gelatin Filter Holder III to most EF lenses.
MSRP: 60.0
Gelatin Filter Holder Adapter IV 58
Adapter ring used to attach Gelatin Filter Holder IV to most 58mm EF lenses.
MSRP: 60.0
Gelatin Filter Holder Hood III
Canon Gelatin Filter Holder III allows 3-inch square gelatin filters to be fitted to most EF lenses.
MSRP: 45.0
Gelatin Filter Holder Hood IV
Allows 4-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods IV.
MSRP: 45.0
Allows 3-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods III.
MSRP: 140.0
MSRP: 150.0
Lens Cap E-58 II
The Lens Cap E-58 II is newly designed and fits Canon EF lenses with a 58mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Cap E-58U
MSRP: 8.5
Lens Case LP1116
Lens pouch cases and the zipper-type soft cases are compact, yet keep your lenses looking like new.
MSRP: 35.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood ET-65B
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 55.0
Lens: CarePAK PLUS (2YR)
CarePAK PLUS offers protection from accidental damage such as drops, spills, power surges, and more, including normal wear and tear, beyond the standard warranty period. It also includes Image Recovery (included with Cameras, Camcorders, and Printers with a memory card slot only), priority repair service, free return shipping, $0 deductible, genuine Canon factory service with only genuine Canon parts, and is transferable if you sell or gift your product. With a CarePAK PLUS, a damaged product will be repaired to good working condition or replaced with an equivalent product.
Lens: CarePAK PLUS (3YR)
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
