Web Content Viewer
Actions
EF 70-300mm f/4-5.6 IS II USM
Telephoto Zoom
Item Code: 0571C002AA
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Features
High-speed autofocus for shooting stills and smooth
The EF 70–300mm f/4–5.6 IS II USM's NANO USM technology delivers quick, near-silent autofocus whether you're capturing an athlete jumping for a ball or recording wildlife in their natural habitat. For still images, it provides high-speed autofocus to help ensure you get the shot you want. When recording videos, the near-silent operation keeps unwanted noise out of your videos. For additional artistic control, manual focus is also possible even when the lens is set for autofocus. This means that when recording a video, for example, you can slowly pull in or out of focus for a dramatic effect.
New Lens Information Display
The EF 70–300mm f/4–5.6 IS II USM features a new integral Lens Information Display for fast access to a wide variety of lens information. This lets you see the information you need at a glance, and then get right back to taking photos. The focusing distance display mode provides the distance the lens is focusing and an estimate of the depth of field, while the focal length display mode shows the 35mm-equivalent focal length. In shake amount display mode, the Lens Information Display gives an estimate of how much the lens and the camera are moving. To aid viewing in different lighting conditions, both black text on a light background or light text on a black background are selectable.
One UD Lens Helps Reduce Chromatic Aberration
With an all-new design, the EF 70–300mm f/4–5.6 IS II USM features 12 groups with 17 total elements, including an optimally positioned UD lens. UD, or Ultra Low Dispersion, helps correct chromatic aberrations (colored halos around objects) while reducing color blurring and keeping overall detail high. This helps the EF 70–300mm f/4–5.6 IS II USM produce sharp, high-contrast, richly colorful images throughout its zoom range.
Image Stabilizer Effect at up to 4* stops
For consistently sharp results, the EF 70–300mm f/4–5.6 IS II USM features an improved Image Stabilizer system that provides significantly enhanced shake reduction for up to 4 stops* of shutter speeds. This means more reliable handheld performance and clearer detail in low-light situations or at lower ISOs. Because of its enhanced stabilization, the EF 70–300mm f/4–5.6 IS II USM can also help minimize the need for a tripod.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using the EOS-1D X digital SLR camera at a focal length of 300mm.
Circular aperture (9 blades) helps deliver beautiful, soft backgrounds
Thanks to its 9-blade, circular aperture, the EF 70–300mm f/4–5.6 IS II USM is capable of gorgeous, evocative out-of-focus areas and soft backgrounds throughout its zoom range. By delivering an incredible level of control over background blur, it helps you create intimacy and intensity in your photos and videos for impactful results.
Full-time Manual Focus
The EF 70–300mm f/4–5.6 IS II USM offers complete manual control, even when AF is engaged, with a simple twist of the lens's focus ring. Additionally, full-time manual focus means it's easy to achieve and maintain focus manually, which can be especially handy when shooting video or composing still images on an SLR's screen.
Specifications
Focal Length & Maximum Aperture
70-300mm f/4-5.6
Lens Construction
17 elements in 12 groups
Diagonal Angle of View
34° - 8° 15' (with full-frame camera)
Focus Adjustment
AF with full-time manual
Closest Focusing Distance
3.94 ft. / 1.2 m
Filter Size
2.6 in. / 67mm diameter
Max. Diameter x Length, Weight
Φ3.15 x 5.73 in., approx. 25.04 oz. / Φ80 x 145.5mm, approx. 710g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 70-300mm f/4-5.6 IS II USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Tele MTF Chart
Wide MTF Chart
This is to make Misc appear on the page when needed.
Videos
Introducing the EF 70-300mm f/4-5.6 IS II USM Lens
Join Canon Technical Advisor Rudy Winston as he introduces the new EF 70-300mm f/4-5.6 IS II. The powerful new addition to Canon’s midrange telephoto series brings features such as fast and smooth Nano USM, LCD lens information display, and more.
DISCLAIMERS
 Return to Top
