Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF-S 55-250mm f/4-5.6 IS II
Telephoto Zoom
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
This telephoto zoom lens is designed with Canon's Optical Image Stabilizer technology while retaining compactness and lightness, in response to demands of photographers. This high zoom ratio lens is equivalent to a focal length of 88-400mm in the 35mm format (when used on Canon EOS cameras compatible with EF-S lenses), and the image stabilizer effect equivalent to a shutter speed about 4 stops faster than the same size lens without Image Stabilizer. In other words, if the slowest shutter speed you could formerly hold a 250mm lens steadily was 1/250th of a second, with Canon's 4-stop stabilization correction, you could hand-hold at shutter speeds as slow as 1/15th of a second. It also uses a UD-glass lens element to correct chromatic aberration for excellent image quality throughout the zoom range. This new EF-S telephoto lens with great features delivers excellent performance at an affordable price for all photographers.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-S 55-250mm f/4-5.6 IS II that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Gelatin 52mm Adapter Ring
Canon Gelatin Filter Holder Adapter III used to attach Gelatin Filter Holder III to most Canon EF lenses.
MSRP: 45.0
58mm Circular Polarizer PL-C
MSRP: 170.0
58mm Close-up Lens 250D
Double-element accessory attaches to front of lens, changes closest focusing distance from infinity to 250mm (approx. 9.9") from front of lens.
MSRP: 130.0
58mm Close-up Lens 500D
Double Element accessory attaches to front of lens or to adapter. Changes closest focusing distance from infinity to 500mm (approx. 19.6"") from front of lens. For use with most EF lenses and PowerShot cameras. Requires Conversion Lens Adapter which is specific to camera model.
MSRP: 130.0
58mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 58mm diameter.
MSRP: 45.0
Compact, lightweight lens with Optical Image Stabilizer technology High zoom ratio lens equivalent to 88-400mm in 35mm format Can hand-hold at shutter speeds slow as 1/15th of a second UD-glass lens element to correct chromatic aberration
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Gelatin 58mm Adapter Ring
Gelatin Filter Holder Adapter IV used to attach Gelatin Filter Holder IV to most Canon EF lenses.
MSRP: 50.0
Gelatin Filter Holder Adapter III 58
58mm adapter ring. Used to attach Gelatin Filter Holder III to most EF lenses.
MSRP: 60.0
Gelatin Filter Holder Adapter IV 58
Adapter ring used to attach Gelatin Filter Holder IV to most 58mm EF lenses.
MSRP: 60.0
Gelatin Filter Holder Hood III
Canon Gelatin Filter Holder III allows 3-inch square gelatin filters to be fitted to most EF lenses.
MSRP: 45.0
Gelatin Filter Holder Hood IV
Allows 4-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods IV.
MSRP: 45.0
Allows 3-inch square gelatin filters to be fitted to most EF lenses. Requires Gelatin Filter Holder Adapter. Can be combined with optional Gelatin Filter Holder Hoods III.
MSRP: 140.0
MSRP: 150.0
Lens Cap E-58
Indispensable for protecting your valuable lenses, this cap should be used on all lenses with a 52mm filter size.
MSRP: 8.5
Lens Cap E-58 II
The Lens Cap E-58 II is newly designed and fits Canon EF lenses with a 58mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Case LP1019
Canon LP1019 Soft Lens Case for the Canon EF 100-300mm f/4.5-5.6 USM, 75-300mm f/4.0-5.6 III or 75-300mm f/4.0-5.6 III USM lens.
MSRP: 35.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood ET-60
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 29.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
DISCLAIMERS
*For Canon EOS DSLR cameras with APS-C sized sensors.
