Web Content Viewer
Actions
EF-S 55-250mm f/4-5.6 IS STM
Telephoto Zoom
Item Code: 8546B002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Specifications
Focal Length & Maximum Aperture
55-250mm 1:4-5.6
Lens Construction
15 elements in 12 groups
Diagonal Angle of View
27° 50' - 6° 15'
Focus Adjustment
Rear focus system
Closest Focusing Distance
2.79 ft. / 0.85m
Filter Size
58mm diameter
Max. Diameter x Length, Weight
2.8 x 4.4 inches, approx. 13.2 oz. / 70.0 x 111.2mm, approx. 375g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF-S 55-250mm f/4-5.6 IS STM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
 Return to Top
