Web Content Viewer
Actions
RF70-200mm F4 L IS USM
Telephoto Zoom
Item Code: 4318C002AA
Features
Canon's Shortest and Lightest 70-200mm f/4 Interchangeable Zoom Lens
Convenience is a major consideration when shooting, and the RF70-200mm F4 L IS USM lens is our most compact and lightest 70-200mm f/4 lens, making it even more appealing to use for your photo and video opportunities. As a more portable 70-200mm option than our EF version, this new RF lens is easier to fit into a messenger bag as well as a camera backpack vertically so it's always on-hand and ready to go.
High Image Quality and Bright, Constant f/4 Aperture Telephoto Zoom RF L Lens
The EF 70-200mm F4 lenses provided impressive picture quality and that superb reputation has carried over and has been improved with this RF version. With L series optics and a 9 blade circular aperture for creative bokeh, this is an excellent telephoto complement to the RF24-105mm F4 L IS USM and will provide you with impressive results, even when shooting in low light situations.
Optical Image Stabilizer with up to 5 Stops of Shake Correction*
Because RF lenses are designed specifically for the RF Mount found on EOS R series cameras, the lens and camera combine to share shooting data, helping to dramatically reduce the effect of camera shake that can occur when using handheld. This applies when capturing both stills and video with up to 5 stops of stabilization* for accurate and clear content.
Up to 7.5 stops of Shake Correction** with Coordinated Optical Image Stabilizer and In-Body Image Stabilizer
When combined with an EOS R series camera equipped with In-Body Image Stabilizer, the lens' Optical Image Stabilizer teams up with the In-Body Image Stabilizer to provide coordinated IS up to 7.5 stops, further helping to alleviate shaking for photos and video, and adjusting the ratio from optical to in-body stabilization automatically throughout the zoom range so you have the best of both worlds.
High Speed, Smooth and Quiet Auto Focus with Dual Nano USM
Like some of its predecessors such as the RF70-200mm F2.8L IS USM and RF100-500mm F4.5-7.1L IS USM lenses, the RF70-200mm F4 L IS USM is equipped with dual independent Nano USMs to help achieve high-speed and focus accuracy at any focal length or throughout its travel, and its focusing range. This helps you quickly focus and keep up with fast-moving subjects and also provides smooth and silent autofocus while shooting movies, so there is relatively no disturbance for you, the subject or in what you see visually and hear audibly during shooting and playback.
Minimum Focusing Distance of 1.97 ft. and Maximum Magnification of 0.28x***
While the EF 70-200mm f/4L IS II USM counterpart lets you shoot at a minimum focusing distance of approx. 3.3 ft., the dual independent Nano USMs found in the RF70-200mm F4 L IS USM lets you get even closer, up to 1.97 ft. from the subject at full zoom range and at a maximum magnification of 0.28x (at 200mm), so you can get highly detailed, highly impressive images even at close range with a telephoto zoom lens.
Control Ring for Direct Setting Changes
Standard on all RF lenses, the control ring on the lens barrel enables you to adjust numerous settings including shutter speed, aperture, exposure compensation and more. Located towards the front of the lens and effectively adding a third dial to the EOS R and EOS RP, and a fourth dial for EOS R5 and EOS R6 cameras, the control ring has a tactile, easily distinguished surface and features a clicking mechanism that provides tangible feedback for confident use while looking through the viewfinder. For photographers and moviemakers who would prefer a silent control ring, the clicking mechanism can be removed by a Canon service provider for a fee.
12-Pin Communication System
Designed to quickly process data, the 12-pin communication system inherent in all RF lenses helps accelerates AF, Image Stabilization, the Digital Lens Optimizer and more, helping to simplify complex operations and provide a quick and reliable user experience.
Dust - and Weather-resistant
Feel confident shooting in almost any weather condition, from rain to snow, thanks to dust- and weather-resistant construction in the lens mount, switch panel, lens barrel extension and all rings. Sealing is applied to lens joining sections and switch panels to help prevent water and dust from entering into the lens.
Fluorine Coating
The RF70-200mm F4 L IS USM lens features fluorine coatings on the front and rearmost surfaces to help prevent water and oil from sticking to the lens, making it easy to clean off smudges and fingerprints.
Four UD Elements and Air-Sphere Coating (ASC)
Clear, high-quality images are produced with the help of four low refractive and ultra-low dispersion lenses, providing significant chromatic aberration correction through the entire zoom range. In addition, the RF70-200mm F4 L IS USM lens features our Air Sphere Coating (ASC), which helps to reduce the occurrence of lens flare and ghosting. This helps provide clean results with minimal distractions and aberrations.
Specifications
Focal Length
70-200mm
Maximum and Minimum Aperture
F4-32
Lens Mount Type
RF Mount
1.97 ft. /0.6m (throughout zoom range)
0.28x (at 200mm)
Angle of View
Diagonal: 34°00′ – 12°00′
Lens Construction
16 elements in 11 groups
Special Elements
4 UD lenses
Filter Size Diameter
Ø77mm
Aperture Blades
9
Dust/Water Resistance
Supported ( Rubber ring on lens mount)
Focusing System
Nano USM (focusing) + Nano USM (floating)
IS Mode Selection
Provided: mode 1, 2, 3
Supported: Up to 5 Stops of Shake Correction*
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 200mm using the EOS R camera.
Shake Correction with EOS R Series cameras with In-Body Image Stabilizer
Supported: up to 7.5 Stops of Shake Correction**
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 50mm using the EOS R5 camera.
Maximum Outer Diameter x Length
Approx. 3.29 in x 4.69 in. / 83.5mm x 119.0mm
Weight
Approx. 1.5 lbs. / 695g
Lens hood
ET-83G (WIII) (Bundled)
Lens Cap
E-77 II (center pinch type) (Bundled)
Dust Cap
Lens Dust Cap RF (Bundled)
Lens Case
LP1319 (Bundled)
  • RF70-200mm F4 L IS USM
  • Lens Cap E-77II
  • Lens Hood ET-83G (WIII)
  • Lens Pouch LP1319
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you RF70-200mm F4 L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Sample Images
More Details
More Details
More Details
*ISO speed is based on recommended exposure index.
This is to make Misc appear on the page when needed.
Videos
Discover the RF70-200mm F4 L IS USM Lens with Mason Higa
Take a closer look at the RF70-200mm F4 L IS USM lens with Canon USA's Mason Higa as he highlights the key benefits of this lens and why it’s a great option for a number of shooting scenarios.
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens' expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
DISCLAIMERS
*Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 200mm using the EOS R camera.
**Based on CIPA (Camera & Imaging Products Association) standards. Testing performed at a focal length of 200mm using the EOS R5 camera.
*** At 200mm.
 Return to Top
