Web Content Viewer
Actions
TS-E 90mm f/2.8
Tilt-Shift
Item Code: 2544A003AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Specifications
Focal Length & Maximum Aperture
90mm 1:2.8
Lens Construction
6 elements in 5 groups
Diagonal Angle of View
27° (without tilt or shift)
Image circle dia. 58.6mm.
Focus Adjustment
Manual focus, Overall linear extension system
Closest Focusing Distance
0.5m / 1.6 ft.
Filter Size
58mm
Max. Diameter x Length, Weight
2.9 x 3.5, 1.2 lbs. / 73.6 x 88.0mm, 565g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you TS-E 90mm f/2.8 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Videos
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: Tilt-Shift Lenses
Canon expert Jon Lorentz gives some tips on architectural and landscape photography using Canon tilt-shift lenses.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
 Return to Top
