Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
TS-E 50mm f/2.8L MACRO
Tilt-Shift
Canon Store: $
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Overview
For advanced photography with precise control, look no further than the TS-E 50mm f/2.8L Macro. It takes an L-series optical formula that includes two UD lens elements and adds extensive tilt-and shift movements for a combination of precision and quality that can be ideal for macro photography, advertising, architecture and more. Delivering reliable and versatile use both in the studio and in the field, it has large, easily operated knobs and locking mechanisms, sophisticated construction, plus a convenient minimum focusing distance of 10 in./0.27m. As part of Canon’s expanded line of TS-E lenses ranging from ultra-wide angle to mid-telephoto, the TS-E 50mm f/2.8L Macro offers a level of performance that can be ideal for working professionals and enthusiasts alike.
Features
An excellent addition to Canon's L-series collection of lenses, the
With a large f/2.8 maximum aperture, the
The
To help minimize the ghosting and flare that reflected light can cause on image capture, the
For greater ease of use, the
To deliver high operability, the
For greater flexibility in shooting, the
For expansive control, the
With a minimum focusing distance of 10 in./0.27m, the
Thanks to a maximum magnification of 0.5x, the
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you TS-E 50mm f/2.8L MACRO that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
77mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 460.0
77mm Close-Up Lens 500D
Canon Close-Up Lens 500D is a double-element accessory that attaches to front of lens. It changes closest focusing distance from infinity to 500mm (approx. 19.7" from front of lens).
MSRP: 220.0
77mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter.
MSRP: 95.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Lens Cap E-77 II
The Lens Cap E-77 II is newly designed and fits Canon EF lenses with a 77mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 15.0
Lens Case LP1219
Soft drawstring lens case made for Canon EF 135mm f/2.0L, EF 24-70mm f/2.8, EF 28-70mm f/2.8L, EF 100mm f/2.8 USM, EF 50mm f/1.0L or EF 85mm 1.2L USM lens.
MSRP: 40.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood ES-84
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 60.0
Lens: CarePAK PLUS (2YR)
CarePAK PLUS offers protection from accidental damage such as drops, spills, power surges, and more, including normal wear and tear, beyond the standard warranty period. It also includes Image Recovery (included with Cameras, Camcorders, and Printers with a memory card slot only), priority repair service, free return shipping, $0 deductible, genuine Canon factory service with only genuine Canon parts, and is transferable if you sell or gift your product. With a CarePAK PLUS, a damaged product will be repaired to good working condition or replaced with an equivalent product.
Lens: CarePAK PLUS (3YR)
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
Videos
Introducing Canon's New Tilt Shift Lenses
Learn how these three Tilt-Shift lenses can offer new options for shooting products, portraits, landscapes, architecture and creative effects for both stills and video. These three lenses join the two current wide-angle tilt-shift lenses, creating a family of five outstanding L-series, tilt-shift lenses.TS-E x Sushi
Watch this sample movie shot using Canon Tilt Shift lenses and experience how they can open creative ways to capture video with their versatility and unique functionality.Behind The Scenes: TS-E x Sushi
Watch this sample movie shot using Canon Tilt Shift lenses and experience how they can open creative ways to capture video with their versatility and unique functionality.Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.Canon EF 101: Macro Lenses
Macro lenses not only let you close-in on a subject, but also allow you to zoom in on a subject that you cannot get close to. Canon expert Jon Lorentz gives some tips on the best way to capture these shots with Canon macro lenses.Canon EF 101: Tilt-Shift Lenses
Canon expert Jon Lorentz gives some tips on architectural and landscape photography using Canon tilt-shift lenses.Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.† Prices and specifications subject to change without notice. Actual prices are determined by individual dealers and may vary.
- ${title}${badge}
