Web Content Viewer
Actions
TS-E 90mm f/2.8L MACRO
Tilt-Shift
Item Code: 2274C002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Features
High-performance L-series Lens
An excellent addition to Canon's L-series collection of lenses, the TS-E 90mm f/2.8L Macro offers outstanding optics, reliable performance and refined design, featuring the quality professionals and advanced photographers demand. Engineered to complement Canon's high-resolution camera sensors, it's poised to deliver phenomenal image quality in any number of applications.
Large f/2.8 Maximum Aperture
With a large f/2.8 maximum aperture, the TS-E 90mm f/2.8L Macro is extremely bright, excellent for composing images and for quick shutter speeds – even at low ISO speeds. This means striking portraits, minimized movement even in windy conditions and high flexibility for low-light situations.
UD Lens Element Helps Reduce Chromatic Aberration
The TS-E 90mm f/2.8L Macro is designed to deliver the image quality necessary for detailed, high-resolution image capture. A UD Glass lens in an 11-element optical formula helps to minimize chromatic aberration. The TS-E 90mm f/2.8L Macro's optics deliver gorgeous, high-resolution images with sharp edge-to-edge detail.
Optimized Lens Coating for Ghosting and Flare Reduction
To help minimize the ghosting and flare that reflected light can cause on image capture, the TS-E 90mm f/2.8L Macro features Canon's ASC coating. Air Sphere Coating (ASC) technology is designed to help significantly minimize reflections, particularly with light that enters the lens vertically. It adds a protective film that includes air spheres over the lens's conventional multi-layer coatings, reducing reflections and delivering clear images with high contrast and minimal glare.
Large Tilt and Shift Knobs for Increased Operability
For greater ease of use, the TS-E 90mm f/2.8L Macro features enlarged knobs for fast, intuitive control of tilt and shift. Feel free to make adjustments as you please without having to take your eyes off the composition.
Tilt-locking Mechanism for Use When Shooting
To deliver high operability, the TS-E 90mm f/2.8L Macro features large tilt and shift lock knobs and a rotation lock release button. It also has a tilt-locking mechanism that keeps the lens in the zero position, helping to prevent unintended movement when in use.
Increased Tilt Range of ±10°
For greater flexibility in shooting, the TS-E 90mm f/2.8L Macro has an enhanced tilt range of ±10° to deliver a higher level of control. Whether focusing on a subject not parallel to the camera's sensor, increasing or decreasing the lens's depth of field or establishing a specific plane of focus, the TS-E 90mm f/2.8L Macro's enlarged tilt range can prove indispensable in defining the composition.
Increased Shift Range of ±12mm
For expansive control, the TS-E 90mm f/2.8L Macro features an incredibly large shift range of ±12mm, enabling seemingly impossible image capture with ease. This increased range helps the TS-E 90mm f/2.8L Macro eliminate converging lines, reflections or nearby objects from the composition, recompose the image without moving the camera and even capture a wider angle of view through photo stitching.
Minimum Focusing Distance of 16 in/0.39m
With a minimum focusing distance of 16 in./0.39m, the TS-E 90mm f/2.8L Macro is incredibly well-suited for close-up photography. Combined with its expanded range of movements, its minimum focusing distance helps make sharp and detailed close-up images with specifically defined depth of field a reality.
Maximum Magnification of 0.5x
Thanks to a maximum magnification of 0.5x, the TS-E 90mm f/2.8L Macro is well-suited for capturing images of small objects. Whether shooting photos of still life, product photography or anything in between, its combination of maximum magnification, close focusing distance and expanded movements enables a truly phenomenal level of control for even the most challenging subjects.
Specifications
Focal Length & Maximum Aperture
90mm f/2.8
Lens Construction
11 elements in 9 groups
Diagonal Angle of View
27° 00'
Focus Adjustment
Manual focus
Closest Focusing Distance
1.28 ft. / 0.39m
Filter Size
77mm
Max. Diameter x Length, Weight
Φ3.4 x 4.6 in., approx. 32.3 oz. / Φ86.9 x 116.5mm, approx. 915g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you TS-E 90mm f/2.8L MACRO that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Sample Images
More Details
More Details
More Details
Videos
Introducing Canon's New Tilt Shift Lenses
Learn how these three Tilt-Shift lenses can offer new options for shooting products, portraits, landscapes, architecture and creative effects for both stills and video. These three lenses join the two current wide-angle tilt-shift lenses, creating a family of five outstanding L-series, tilt-shift lenses.
TS-E x Sushi
Watch this sample movie shot using Canon Tilt Shift lenses and experience how they can open creative ways to capture video with their versatility and unique functionality.
Behind The Scenes: TS-E x Sushi
Canon EF 101: A Beginner's Guide
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: Macro Lenses
Macro lenses not only let you close-in on a subject, but also allow you to zoom in on a subject that you cannot get close to. Canon expert Jon Lorentz gives some tips on the best way to capture these shots with Canon macro lenses.
Canon EF 101: Tilt-Shift Lenses
Canon expert Jon Lorentz gives some tips on architectural and landscape photography using Canon tilt-shift lenses.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
 Return to Top
