Web Content Viewer
Actions
EF 16-35mm f/4L IS USM
Ultra-Wide Zoom
Item Code: 9518B002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Features
  • High performance L-series ultra-wide zoom lens in a compact design and Optical Image Stabilizer for up to four stops of correction*.
  • Three aspheric lens elements, including a large-diameter aspheric lens, help correct aberration.
  • Two UD lens elements help reduce chromatic aberration from the center to the periphery throughout the entire zoom range for excellent image quality with high resolution and contrast.
  • Optimized lens coatings help provide excellent color balance while also helping to minimize ghosting.
  • Highly resistant to dust and water intrusion, enabling shooting even in harsh conditions**.
  • Inner focusing and ring USM for silent, fast and accurate autofocusing.
  • Circular aperture (9 blades) delivers beautiful, soft backgrounds.
  • Minimum focusing distance of 0.92 ft/0.28m across entire zoom range.
  • Full-time manual focus allows manual focus adjustment while in AF Mode.
* Based on CIPA (Camera & Imaging Products Association) standards. Testing performed using EOS-1D X Digital SLR camera at focal length of 35mm (35mm equivalent).
** Requires a Canon PROTECT filter (sold separately) to be mounted.
This is to make Misc appear on the page when needed.
Specifications
Focal Length & Maximum Aperture
16-35mm 1:4:0
Lens Construction
16 elements in 12 groups
Diagonal Angle of View
108°10' - 63°
Focus Adjustment
Inner focus system
Closest Focusing Distance
0.92 ft. / 0.28m
Filter Size
77mm diameter
Max. Diameter x Length, Weight
3.3 x 4.4 in., 21.7 oz. / 82.6 x 112.8mm, 615g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 16-35mm f/4L IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
 Return to Top
