Web Content Viewer
Actions
EF 8-15mm f/4L Fisheye USM
Ultra-Wide Zoom
Item Code: 4427B002AA
Experience how changing your lens can unlock a world of possibilities, and see beyond what meets the eye. Start Exploring!
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Learn more about the Canon milestone that has helped you capture many of yours with Canon EF lenses.
Specifications
Focal Length & Maximum Aperture
15mm 4.0
Lens Construction
14 elements in 11 groups
Diagonal Angle of View
180°
Focus Adjustment
Lens extension via inner focusing and focus cam plus floating mechanism
Closest Focusing Distance
0.16m / 6.2 in.
Filter Size
Rear Gel Holder (accepts up to 3 pre-cut gel filters)
Max. Diameter x Length, Weight
3.1 x 3.7 in, 19.1 oz. / 78.5 x 83.0mm, 540g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 8-15mm f/4L Fisheye USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
Videos
Canon EF 101: Series Overview
Canon offers a wide range of EF lenses and lens accessories. In this 9 part video series you'll learn all about lens basics and the various lenses available from your host, Canon expert Jon Lorentz.
Canon EF 101: Lens Basics
Take a quick and informative first step into the world of lenses with Canon expert Jon Lorentz, providing insight into the type of lenses available, helpful tips and more.
Canon EF 101: Fisheye Lens
With its 180º field of view, fisheye lenses give a unique view of the world. Canon expert Jon Lorentz shows some examples of the amazing images you can capture with Canon lenses like the 8-15mm lens.
Canon EF 101: Lens Accessories
Canon expert Jon Lorentz takes a look at some lens accessories including lens hoods, filters, extenders and more and how to care for them.
 Return to Top
