Web Content Viewer
Actions
EF 24mm f/1.4L II USM
Wide-Angle
Item Code: 2750B002AA
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Specifications
Focal Length & Maximum Aperture
24mm 1:1.4
Lens Construction
13 elements in 10 groups
Diagonal Angle of View
84°
Focus Adjustment
Rear focusing system with USM
Closest Focusing Distance
3.0 in./77mm
Filter Size
77mm
Max. Diameter x Length, Weight
3.4 in./86.9mm; 22.9 oz./650g
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 24mm f/1.4L II USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
This is to make Misc appear on the page when needed.
 Return to Top
