Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 28 f/1.8 USM
Wide-Angle
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
With the large maximum aperture, excellent background blur is possible even with a fast shutter speed. The aspherical lens element makes the lens compact and corrects spherical aberrations. The image is sharp even at the edges. Lead-free glass is used.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 28 f/1.8 USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Gelatin 52mm Adapter Ring
Canon Gelatin Filter Holder Adapter III used to attach Gelatin Filter Holder III to most Canon EF lenses.
MSRP: 45.0
58mm Circular Polarizer PL-C
MSRP: 170.0
58mm Circular Polarizer PL-CB
Polarizing filters enhance picture quality by blocking harmful reflected light. Use it to reduce light reflections from glass and water surfaces or to improve color saturation. Simple to use, these filters polarize light circularly, rather than linearly, so they do not interfere with autofocus or TTL light metering.
MSRP: 260.0
58mm Close-up Lens 250D
Double-element accessory attaches to front of lens, changes closest focusing distance from infinity to 250mm (approx. 9.9") from front of lens.
MSRP: 130.0
58mm Close-up Lens 500D
Double Element accessory attaches to front of lens or to adapter. Changes closest focusing distance from infinity to 500mm (approx. 19.6"") from front of lens. For use with most EF lenses and PowerShot cameras. Requires Conversion Lens Adapter which is specific to camera model.
MSRP: 130.0
77mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter.
MSRP: 95.0
77mm UV Haze Filter
UV Protector filters allow you to correct for the UV effect to varying degrees. These filters can also help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 77mm diameter, please see Compatibility tab for compatible lenses.
MSRP: 55.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Gelatin 58mm Adapter Ring
Gelatin Filter Holder Adapter IV used to attach Gelatin Filter Holder IV to most Canon EF lenses.
MSRP: 50.0
Lens Cap E-58 II
The Lens Cap E-58 II is newly designed and fits Canon EF lenses with a 58mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Cap E-58U
MSRP: 8.5
Lens Case LP814
MSRP: 30.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood EW-63II
Designed to prevent stray light from entering the lens in order to keep unwanted glare from affecting your photographs.
MSRP: 29.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
