Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
EF 35mm f/2 IS USM
Wide-Angle
Canon Store: $
Compare lenses from the abundant Canon lineup of EF Lenses and see the difference each one can make.
Overview
A modern day update to a versatile, compact and lightweight wide-angle lens, the EF 35mm f/2 IS USM is incredibly bright and offers image stabilization, superb image quality and construction perfect for use on any EOS digital camera. With a redesigned mechanical and optical structure, the EF 35mm f/2 IS USM features a GMo aspherical lens element for high image quality with improved performance in the periphery. It incorporates a rear focus system and ring-type USM for faster, more precise autofocus performance. Full-time manual focus enables manual focusing while in AF mode, a micro-stepping drive provides quieter operation and a low speed focus drive delivers optimal results for video shooting. Canon Optical Image Stabilizer system delivers the equivalent effect of 4 stops and can detect normal shooting or panning, and automatically switches to the optimal IS mode. Compact and lightweight, the EF 35mm f/2 IS USM has an 8-blade circular aperture diaphragm for soft backgrounds, a minimum focusing distance of 0.79 ft./0.24m, plus optimized lens coatings for minimized ghosting and flare.
Specifications
Focal Length & Maximum Aperture
Lens Construction
Diagonal Angle of View
Focus Adjustment
Closest Focusing Distance
Filter Size
Max. Diameter x Length, Weight
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you EF 35mm f/2 IS USM that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
67mm Circular Polarizer PL-CB
Filter enhances picture quality by blocking harmful reflected light.
MSRP: 390.0
67mm Protect Filter
These filters can help protect your lens against dust, moisture, fingerprints, scratches and damage and can be kept on your lens at all times. Filter fits select lenses with a 67mm diameter.
MSRP: 85.0
Extension Tube EF 12 II
Extension Tube EF 12 II is especially suited for close-focusing with wide-angle lenses.
MSRP: 130.0
Extension Tube EF 25 II
25mm fully coupled Extension Tube for EOS camera and most lenses to 350mm.
MSRP: 210.0
Lens Cap E-67 II
The Lens Cap E-67 II is newly designed and fits Canon EF lenses with a 67mm filter size. It helps protect the front glass from dust and scratches.
MSRP: 10.0
Lens Case LP1116
Lens pouch cases and the zipper-type soft cases are compact, yet keep your lenses looking like new.
MSRP: 35.0
Lens Dust Cap E Rear Cap
Rear lens cap for all EF type lenses, lens extenders, and extension tubes. Used to protect the rear glass element from dust and scratches.
MSRP: 7.0
Lens Hood EW-72
The lens hood helps prevent unwanted glare.
MSRP: 70.0
Brochures
Resources
MTF Charts
A Modulation Transfer Function (MTF) chart measures a lens’ expected optical performance at the center of the picture area and measures repeatedly along the diagonal line, further and further toward the corners of the image. The higher a curve is shown on the chart, the better the lens is performing in the area the chart is measuring. As a curve moves from left to right, it displays the lens' results from center towards the corners.
For more information on understanding how to read Canon Lens MTF charts, please click here.
