Web Content Viewer
Actions
FPA-6300ES6a
DUV Scanners
Nanoimprint Lithography
Learn about Canon Industrial Product Technology.
Semiconductor Training
Canon Certified Product Optimization (CPO) Program
Contact Us
Contact Us
Features
  • High-Productivity Scanner: The new Canon DUV scanner incorporates a newly designed reticle stage and wafer stage that significantly reduces wafer handling, alignment and exposure processes times. The FPA-6300ES6a scanner realizes a throughput of more than 200 wafers per hour* when available options are applied.
    *12-inch wafers, 98 shots, with Throughput Upgrade applied
  • High-Accuracy Scanner: The FPA-6300ES6a employs highly sophisticated stage-control technologies, an improved alignment scope and precise temperature and distortion control to make possible an overlay accuracy of 5 nm** when available options are applied. The advanced 0.86NA projection optical system and a wide range of options support demanding and robust device production.
    ** with Overlay Upgrade applied
  • High-Reliability Scanner: The FPA-6300ES6a platform provides substantial improvements in terms of base durability and maintenance requirements, as well as reduced install times and increased system uptime and availability***. FPA-6300ES6a options and upgrades further improve overlay accuracy and productivity, offering scalability to support next-generation semiconductor manufacturing.
    *** Compared with FPA-6000ES6a scanner
This is to make Misc appear on the page when needed.
Specifications
Model Type
KrF (248 nm) DUV Scanner
Wafer Size
300 mm
Resolution
≤ 90 nm
Numerical Aperture (NA)
0.50 ~ 0.86
Reticle Size
6 in. (0.25 in. thick)
Reduction Ratio
4:1
Field Size
26 mm x 33 mm
Overlay Accuracy
≤ 5 nm* (|m| + 3 σ, Single Tool Overlay)
* Overlay Upgrade Required
Throughput
≥ 200 wph** (300 mm, 98 shots)
** High-Throughput Upgrade Required
 Return to Top
