Web Content Viewer
Actions
FPA-6300ES6a
DUV Scanners
Nanoimprint Lithography
Learn more about the technology behind Canon Lithography Tools.
Glowing Earth on dark background
For more information, click to download the Product Catalog.
FPA 6000es6a DUV Scanner
Canon Certified Product Optimization (CPO) Program
For inquiries, please contact us.
Contact Us
Features
  • High-Productivity Scanner: The new Canon DUV scanner incorporates a newly designed reticle stage and wafer stage that significantly reduces wafer handling, alignment and exposure processes times. The FPA-6300ES6a scanner realizes a throughput of more than 200 wafers per hour* when available options are applied.
    *12-inch wafers, 98 shots, with Throughput Upgrade applied
  • High-Accuracy Scanner: The FPA-6300ES6a employs highly sophisticated stage-control technologies, an improved alignment scope and precise temperature and distortion control to make possible an overlay accuracy of 5 nm** when available options are applied. The advanced 0.86NA projection optical system and a wide range of options support demanding and robust device production.
    ** with Overlay Upgrade applied
  • High-Reliability Scanner: The FPA-6300ES6a platform provides substantial improvements in terms of base durability and maintenance requirements, as well as reduced install times and increased system uptime and availability***. FPA-6300ES6a options and upgrades further improve overlay accuracy and productivity, offering scalability to support next-generation semiconductor manufacturing.
    *** Compared with FPA-6000ES6a scanner
This is to make Misc appear on the page when needed.
Specifications
Model Type
KrF (248 nm) DUV Scanner
Wafer Size
300 mm
Resolution
≤ 90 nm
Numerical Aperture (NA)
0.50 ~ 0.86
Reticle Size
6 in. (0.25 in. thick)
Reduction Ratio
4:1
Field Size
26 mm x 33 mm
Overlay Accuracy
≤ 5 nm* (|m| + 3 σ, Single Tool Overlay)
* Overlay Upgrade Required
Throughput
≥ 200 wph** (300 mm, 98 shots)
** High-Throughput Upgrade Required
 Return to Top
