Web Content Viewer
Actions
MPAsp-E813 Flat-Panel Exposure System
Flat-Panel Exposure Equipment
Nanoimprint Lithography
Learn more about the technology behind Canon Lithography Tools.
For inquiries, please contact us.
Contact Us
Features
High-definition production on Generation 6 glass panels
  • Smartphones, smartwatches and AR/VR (Augmented Reality / Virtual Reality) displays increasingly demand higher definition displays.
  • MPAsp-E813 flat-panel exposure systems have helped manufacturers realize the production of high-definition panels with Generation 6 glass panels (1500 mm × 1850 mm) and have become indispensable for LCD (Liquid Crystal Display) and OLED (Organic Light Emitting Diode) panel production.
World's highest panel process resolution
  • MPAsp-E813 systems achieve the world's highest Generation 6 panel process resolution of 1.5 μm for Line & Space patterns (L/S) and 2.0 μm for Contact Holes (CH) (among equivalent class of exposure equipment; examination by Canon).
  • MPAsp-E813 systems adopt a new mirror optical system design and illumination system that can produce high-definition panels exceeding 800 pixels per inch (ppi).
Overlay accuracy improvement
  • MPAsp Series flat-panel exposure systems enjoy improved overlay accuracy due to a new magnification correction mechanism and temperature control system.
  • MPAsp Series flat-panel exposure systems provide higher overlay accuracy at a higher speed when compared to previous flat-panel exposure equipment thanks to the new alignment system.
High productivity & high utilization rate
  • MPAsp Series flat-panel exposure systems feature wide-field exposure and are capable of producing high-definition display panels efficiently using a one-shot exposure method without stitching.
  • MPAsp systems boast a high stability and utilization rates thanks in part to stage precision improvements and increases in body rigidity.
  • Further cycle time reduction options are available to improve productivity and Canon is constantly striving to deliver additional improvements.
Designed for ultra-thin glass panels
  • Mobile products such as smartphones are required to be lightweight and thin and subsequently, glass panels required for displays must also be thinner.
  • MPAsp-E813 Series flat-panel exposure systems feature improved glass panel handling technology that makes exposure of a 0.3 mm thickness glass panels a reality.
This is to make Misc appear on the page when needed.
Specifications
Resolution
1.5 μm (L/S)
Overlay Accuracy
± 0.3 μm
Projection Optical System
Reflection Projection Optical System
(no magnification)
Reduction Ratio
1:1
Mask Size
850 mm x 1,200 mm
Maximum Plate Size
1,500 mm x 1,850 mm
One-Shot Exposure Area
750 mm x 1,100 mm
Main Body Dimensions
(W) 8,000 x (D) 9,900 x (H) 5,700 mm
 Return to Top
