Web Content Viewer
Actions
VB-H43
All Network Cameras
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
  • 20x Optical Zoom with Fast and Precise Pan/Tilt Mechanism
  • 2.1 Megapixel (Native 1920 x 1080 Full HD Resolution)
  • Advanced DIGIC DV III Image Processor Helps Maximize Image Quality and Minimize Power Consumption
  • Superb Low Light Performance
  • Smart Shade Control and Auto Gain Control Limit
  • Custom Video Settings
  • Powerful DIGIC NET II Processor Allows Simultaneous Streaming of M-JPEG and H.264 Codecs in Multiple Resolutions
  • On-Board Video Analytics and Versatile Functions
  • Multiple Networking Functions
  • ONVIF 2.2 / Profile S Conformant
  • Built-in SD Card Slot with Enhanced SD Card Functionality
  • Various Power Options (12 VDC, 24 VAC and PoE IEEE 802.3af)
This is to make Misc appear on the page when needed.
CAMERA
IMAGE SENSOR
1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
ANALOG VIDEO RESOLUTION
N/A
ANALOG VIDEO STANDARD
N/A
ANALOG S/N RATIO
N/A
SCANNING METHOD
Progressive
LENS
20x optical (12x digital) zoom lens with auto focus
FOCAL LENGTH
4.7 (W) - 94mm (T)
F-NUMBER
F1.6 (W) - F3.5 (T)
HORIZONTAL VIEWING ANGLE
60.4° (W) - 3.2° (T)
VERTICAL VIEWING ANGLE
35.1° (W) - 1.8° (T)
DAY/NIGHT SWITCH
Auto/Manual
I/R CUT FILTER
Removable
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.4 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.03 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.01 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.02 lux (F1.6, shutter speed 1/30 sec., smart shade control is off , 50IRE)
0.002 lux (F1.6, shutter speed 1/2 sec., smart shade control is off , 50IRE)
0.001 lux (F1.6, shutter speed 1/2 sec., smart shade control is on, 50IRE)
FOCUS
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3m (12 in.) - infinity (W), 1.0m (3.3 ft.) - infinity (T)
Night Mode: 1.0m (3.3 ft.) - infinity (W), 1.5m (4.9 ft.) - infinity (T)
SHUTTER SPEED
1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/10000, 1/16000 sec.
EXPOSURE
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury
Lamp/Sodium Lamp/Halogen Lamp)/Manual(One-shot WB/R Gain/B Gain)
METERING MODE
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto / Manual / Disable
Auto: 3 Levels
Manual: 7 Levels
AGC LIMIT
5 levels
IMAGE STABILIZER
2 levels (digital)
PAN ANGLE RANGE
340° (±170°)
TILT ANGLE RANGE
100° (ceiling-mounted position: -90° - +10°)
ROTATION ANGLE RANGE
N/A
MOVING SPEED
Pan: Max. 150°/sec., Tilt: Max. 150°/sec.
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
VIDEO SIZE
JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280x720, 640x360,
320x180
1280x960, 640x480, 320x240
VIDEO QUALITY
JPEG, H.264: 5 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1920 x 1080: 30 fps
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
ONVIF Ver. 2.4 / Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon proprietary), ONVIF
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client), ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon Proprietary), ONVIF
AUTO IP
Available
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
Available
PRESETS
Max. 64 positions
INTELLIGENT FUNCTION - VIDEO
Moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
INTELLIGENT FUNCTION - VOLUME
Volume Detection
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video),Intelligent Function (Volume), Timer
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max. approx. 5 MB
Frame Rate: Max. 10 fps (JPEG)
Max. 30 fps (H.264)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
N/A
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
Number of Registers: 4
Items to Register: Pan/Tilt/Zoom, Exposure, Smart Shade Control, Focus, White Balance, Image Quality Adjustment, Day/Night
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
φ3.5mm (φ0.14 in.) mini-jack connector (monaural)
Switch LINE IN/MIC IN in the setting page.
LINE IN x 1 (connect to an amplifier microphone) or
MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL
φ3.5mm (φ0.14 in.) mini-jack connector (monaural) LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD
SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible.
Frame Rate: Max. 1 fps (JPEG), Max. 30fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
PA-V17 or PA-V18(100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 9.2 W
WITH AC ADAPTER
PA-V17: Max. approx. 10.7W (100 VAC)
PA-V17: Max. approx. 10.0W (240 VAC)
PA-V18 Max. approx. 9.9W (100 VAC)
PA-V18: Max. approx. 9.4W (240 VAC)
WITH 12VDC
Max. approx. 8.6 W
WITH 24VAC
Max. approx. 8.8 W
OTHER
DIMENSIONS
(φ x H) φ132 x 155mm (φ5.20 x 6.10 in.)
MOUNTING POSITION
Ceiling
HEATER
N/A
WEIGHT
Approx. 1140 g (2.514 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
VB-H43B
VB-H43B VB-H43 Main Unit Power Connector Setup CD-ROM Installation Guide Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-H43 that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
Brochures
Loading...
Case Studies
WORKNET USES CANON NETWORK CAMERAS TO SHOW HOW DETAILS CAN MAKE ALL THE DIFFERENCE IN AN INNOVATIVE BILLBOARD ADVERTISING CAMPAIGN
When a major car company called Worknet to have its vehicle recognition software technology incorporated into a billboard advertising campaign, President of Worknet Analytics Michael Maziarka was ready. Worknet, a video analytics company, had previously worked on similar projects with automobile manufacturers in Europe, but this was the first initiative of its type in the United States.
The strategy behind the innovative outdoor campaign was to position digital billboards on highways in select cities and states that would generate dynamic, customized messages to drivers of competitive vehicles.
A&E System Design Tools
A&E Specifications
Date:
11/20/14
Size:
496 KB
Drawings / 3D CAD
Date:
07/24/15
Size:
1.06 MB
Date:
11/6/14
Size:
1.32 MB
Date:
11/6/14
Size:
126 KB
Date:
11/6/14
Size:
1.2 MB
Date:
11/6/14
Size:
273 KB
Date:
11/6/14
Size:
1.55 MB
Date:
11/6/14
Size:
322 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
