Web Content Viewer
Actions
VB-H610D
All Network Cameras
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
In addition to Canon's WebView network camera protocol, the VB-H610D is easily adaptable to third party integration thanks to being ONVIF version 2.2 conformant. The Profile S standard included in this compatibility gives you more interoperability than found in previous network cameras. You will find it easier than ever to create a system which best meets your needs, working with compliant equipment from different manufacturers and third party recording software systems. The ONVIF Profile S allows for easy identification of supported features without needing to know the compatibility of the different versions of ONVIF, and includes specific features such as audio streaming and relay outputs.
"ONVIF" and are trademarks of ONVIF Inc
The VB-H610D's high sensitivity sensor is combined with a bright lens and exceptional video quality optimization to acquire exceptional color video down to 0.05 Lux* and black & white video down to 0.002 Lux*. For challenging poorly lit areas or vital nighttime surveillance, this capability is a great advantage.
* Ratings based on F1.2, 1/8 second and Smart Shade Control on.
The megapixel CMOS Sensor of the VB-H610D ensures maximum image quality, a hallmark of Canon products. Its approximately 2.1 million pixels deliver incredibly sharp, high resolution video - up to 1920 x 1080 - with far greater detail than that of a VGA resolution camera. The result is clearer, more accurate and useful video monitoring.
Canon's well known excellence in lens technology is responsible for the superb visual quality and image consistency of the VB-H610D's 111° wide angle, 3x Optical Zoom lens. The broad range delivered by this lens gives a wide angle of view of your location and its superb optical quality - giving you a clear and sharp image through the entire field of view.
Even the most challenging and difficult installation locations become far more manageable with the Remote Adjustment Function of the Canon VB-H610D. After the camera is mounted, it's simple to get the exact lens position for your needs thanks to built-in motors that allow you to change the pan, tilt, rotation, zoom, and focus – all after the camera is installed, from the comfort of a remote location.
The VB-H610D is packed with features which enhance its functionality and usability. Among the most useful are its sophisticated On-board Video Analytics, enabling the camera to detect Moving, Abandoned, or Removed Objects in its range of vision, and also detect attempts at Camera Tampering and changes in Sound Levels. In addition, Passing Detection has been added to the list to enhance the monitoring capabilities of the VB-H610D, allowing you to define a line which triggers an alert when it is crossed in a defined direction.
For increased control in monitoring sensitive areas, the VB-H610D also offers a Privacy Mask function. With it, you can block specific sections of the camera's field of view, to avoid intrusions of privacy, or password theft.
Thanks to the VB-H610D's impressive algorithm, highly precise detection is achieved using polygonal and rectangular shapes to specify up to 15 areas of detection. Adding polygonal to rectangular shapes allows for increased flexibility in detection areas. An additional benefit comes from the provision for notification of a detection through the network from the camera using a number of functions. They include automatic recording, e-mail transmission, and uploading videos and images to a specified target server. It is also possible to combine a number of detection functions for simultaneous notification.
Moving Object Detection
Removed Object Detection
Abandoned Object Detection
Camera Tampering Detection
Sound Level Detection
Passing Detection
Privacy Mask Function
The usefulness of the VB-H610D is considerably enhanced with the On-screen Display feature. This allows the camera to support an on-screen display that can contain time, date and a text field to further define the monitored location, making it easier to identify.
The high-quality images captured by the VB-H610D are due in no small part to Canon's proprietary processing technologies. One is the latest version of our hardware-based compression engine, DIGIC NET II. This powerful processor allows the VB-H610D to simultaneously deliver both H.264 and JPEG video in high resolution 1920 x 1080 at the maximum frame rate of 30fps – with no loss in frame rate, unlike many competing models. The other is Canon's powerful DIGIC DV III image processor. As employed in our class-leading video camcorders and unlike most security cameras, DIGIC DV III provides superior image quality with lifelike colors, tonal accuracy and reduced image noise - all with lower power consumption
Smart Shade Control, or SSC, is an exclusive Canon technology that automatically adjusts images which may have a bright background by adjusting the gain of the underexposed areas without affecting the exposure of the properly exposed areas. This feature helps to make backlit images easier to see and vital areas of interest easier to monitor.
As the available light changes, the Auto Day/Night feature allows this camera to automatically adjust to maintain optimal image quality. A removable IR cut filter and optimized IR light reflection suppression coating allow for exceptional low light visibility with minimal ghosting.
The VB-H610D continues to demonstrate versatility by accepting a variety of power options. Choose between 12vDC, 24vAC or PoE. Power over Ethernet (IEEE 802.3af) - allows the use of a single LAN cable to both power the camera and transfer video and audio data when connected to a Power over Ethernet switch or PoE injector. This eliminates the need to run AC connections to the installation sites of the cameras, which can help to keep installation costs to a minimum.
With the VB-H610D, you can have two-way mono audio communication between the remote monitoring center and the surveillance location. The Mic/Line In, Line Out jack offers echo cancellation. This feature allows the camera to serve as an even more powerful component of your security infrastructure.
The VB-H610D has a built-in SD Memory Card slot which supports SD, SDHC and SDXC memory cards. It allows streamed images from the camera to be saved to an SD card, giving reliable backup in the event of network power failures or outages. In addition, when issues occur, system logs are also created and stored on the SD card for future troubleshooting.
An administrative tool, Recorded Video Tool allows you to search, download and view the recorded video.
The VB Admin Tools come resident on the VB-H610D's webserver and do not require client software installation. This saves time and makes it easier to configure the camera for use.
The VB-H610D supports the receiving of IPv6 network configuration information from DHCPv6 servers. Adoption of this latest protocol makes this camera an integral part of any system which will see development or expansion going forward as IPv4 will eventually be replaced with IPv6.
For security in network communication, the VB-H610D supports HTTP over SSL (HTTPS). It will support both self-signed security certificates as well as certificates issued by a Certificate Authority.
Canon's proprietary recording software is included at no cost with the purchase of the VB-H610D. A limited function version of the RM-9/25/64 recording software, which is available for purchase, RM-Lite 2.0 allows for the monitoring of JPEG and H.264 video and the recording and playback of the JPEG video from up to four cameras. This complimentary software is well suited for small systems and eliminates the need to purchase software separately.
CAMERA
IMAGE SENSOR
1/3 type CMOS (primary color filter)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
ANALOG VIDEO RESOLUTION
N/A
ANALOG VIDEO STANDARD
N/A
ANALOG S/N RATIO
N/A
SCANNING METHOD
Progressive
LENS
3x optical (4x digital) zoom lens (electric drive)
FOCAL LENGTH
2.8 (W) - 8.4mm (T)
F-NUMBER
F1.2 (W) - F2.0 (T)
HORIZONTAL VIEWING ANGLE
111.0° (W) - 36.5° (T)
VERTICAL VIEWING ANGLE
60.1° (W) - 20.5° (T)
DAY/NIGHT SWITCH
Auto/Manual
I/R CUT FILTER
Removable
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
0.3 lux (F1.2, shutter speed 1/30 sec., SSC off , 50IRE)
0.02 lux (F1.2, shutter speed 1/2 sec., SSC off , 50IRE)
0.008 lux (F1.2, shutter speed 1/2 sec., SSC on, 50IRE)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0.015 lux (F1.2, shutter speed 1/30 sec., SSC off , 50IRE)
0.001 lux (F1.2, shutter speed 1/2 sec., SSC off , 50IRE)
0.0005 lux (F1.2, shutter speed 1/2 sec., SSC on, 50IRE)
FOCUS
One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Night Mode: 1.0m (3.3 ft.) - infinity
Day Mode: 0.3m (12 in.) - infinity
SHUTTER SPEED
1, 1/2, 1/4, 1/8, 1/15, 1/30, 1/60, 1/100, 1/120, 1/250, 1/500, 1/1000, 1/2000, 1/4000, 1/8000, 1/16000 sec.
EXPOSURE
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/ Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source (Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp)/Lock (One-shot WB)/Manual
METERING MODE
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
7 levels
AGC LIMIT
5 levels
IMAGE STABILIZER
N/A
PAN ANGLE RANGE
350° (±175°)
TILT ANGLE RANGE
150° (±75°)
ROTATION ANGLE RANGE
350° (±175°)
MOVING SPEED
Pan: 19.2°/sec., Tilt: 14.2°/sec., Rotation: 43.7°/sec - When the Camera Angle Setting Tool is used
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
VIDEO SIZE
JPEG: 1920 x 1080, 960 x 540, 480 x 270, 320 x 240
H.264: 1920 x 1080, 960 x 540, 480 x 270
VIDEO QUALITY
JPEG, H.264: 5 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1920 x 1080: 30 fps
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user
Max. 50 user names and passwords registered for authorized users.
ACCESS CONTROL
User authority (user name and password), Host Access
Restrictions (IPv4,IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec (Auto Key Exchange/Manual)
IEEE 802.1X
N/A
ONVIF Version
ONVIF Ver. 2.2 / Profile S
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMP (MIB2), SMTP (Client), DHCP (Client), DNS (Client), ARP, ICMP, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon proprietary), ONVIF
IPv6 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SMTP (Client), DHCPv6 (Client), DNS (Client),ICMPv6, POP3, NTP, SMTP authentication, RTSP, WV-HTTP (Canon proprietary), ONVIF
AUTO IP
Available
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places
Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
Max. 20 positions (Digital)
INTELLIGENT FUNCTION - VIDEO
moving object detection, abandoned object detection, removed object detection, camera tampering detection, and passing detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
INTELLIGENT FUNCTION - VOLUME
Volume Detection
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Volume), Timer
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
Temporary storage memory in camera: Max. approx. 5 MB, Frame Rate: Max. 10 fps
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
N/A
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5mm (Φ0.14 in.) mini-jack connector (monaural) - Connect via an audio interface cable (included)
Switch LINE IN/MIC IN in the setting page.
LINE IN x 1 (connect to an amplifier microphone) or
MIC IN x 1 (connect to a microphone w/o amplifier)
AUDIO OUTPUT TERMINAL
LINE OUT x 1 (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD
SD, SDHC, SDXC Memory Card Compatible.
Frame Rate: Max. 1 fps
OPERATING ENVIRONMENT
TEMPERATURE
Temperature: -10°C - +50°C (+14°F - +122°F)
HUMIDITY
Humidity: 5% - 85% (without condensation)
POWER SUPPLY
PoE
PoE power supply via LAN connector (IEEE802.3af compliant)
AC ADAPTER
PA-V17 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
POWER CONSUMPTION
WITH PoE
Max. approx. 7.8 W
WITH AC ADAPTER
Max. approx. 10.2 W
WITH 12VDC
Max. approx. 8.3 W
WITH 24VAC
Max. approx. 7.5 W
OTHER
DIMENSIONS
(Φ x H) Φ186 x 140mm (Φ7.32 x 5.51 in.)
MOUNTING POSITION
Horizontal / Vertical
HEATER
N/A
WEIGHT
1200g (2.65 lb.)
OUTDOOR READY
No
IP RATING
N/A
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
This is to make Misc appear on the page when needed.
VB-H610D
VB-H610D VB-H610D Network Camera Power Connector Setup CD-ROM Safety Wire Audio Interface Cable Installation Template Installation Guide Warranty Card
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-H610D that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
A&E System Design Tools
A&E Specifications
Date:
05/17/13
Size:
377 KB
Drawings / 3D CAD
Date:
01/21/14
Size:
1.46 MB
Date:
01/21/14
Size:
168 KB
Date:
01/21/14
Size:
856 KB
Date:
01/21/14
Size:
128 KB
Date:
01/21/14
Size:
682 KB
Date:
01/21/14
Size:
119 KB
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
Brochures
Loading...
DISCLAIMERS
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and ONVIF logo are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
 Return to Top
