Web Content Viewer
CANON U.S.A.,Inc. MAKES NO GUARANTEES OF ANY KIND WITH REGARD TO ANY PROGRAMS, FILES, DRIVERS OR ANY OTHER MATERIALS CONTAINED ON OR DOWNLOADED FROM THIS, OR ANY OTHER, CANON SOFTWARE SITE. ALL SUCH PROGRAMS, FILES, DRIVERS AND OTHER MATERIALS ARE SUPPLIED "AS IS." CANON DISCLAIMS ALL WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NON-INFRINGEMENT.
CANON U.S.A.,Inc. SHALL NOT BE HELD LIABLE FOR ERRORS CONTAINED HEREIN, OR FOR LOST PROFITS, LOST OPPORTUNITIES, CONSEQUENTIAL OR INCIDENTAL DAMAGES INCURRED AS A RESULT OF ACTING ON INFORMATION, OR THE OPERATION OF ANY SOFTWARE, INCLUDED IN THIS SOFTWARE SITE.
I have read and understand the information above, and wish to download the designated software.
VB-H652LVE
All Network Cameras
Canon Store: $
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
VB-H652LVE
Canon's VB-H652LVE Infrared Vandal Resistant Outdoor Fixed Dome Network Camera is ideal for monitoring outdoor environments in a variety of climates, as it has an IP66 rated water-tight housing, is vandal resistant to impacts (IK10 rated) and includes tamper-proof screws, and also offers an optional heater unit. For added protection from the elements, its anti-fog airflow design allows for the circulation of air to prevent the dome from fogging up and blocking the field of view. The VB-H652LVE is also NEMA250 Type 4X Certified allowing it to be installed near salt water or in colder areas that may be prone to frost.
When it comes to low-light performance, the VB-H652LVE is well equipped. In addition to its Genuine Canon Lens, sophisticated 2.1 Megapixel (1920 x 1080) high-sensitivity CMOS image sensor and powerful DIGIC DV III Image Processor – three core elements that allow for crisp images with remarkable color accuracy, even in low light environments – this camera also features four built-in IR illuminators for obtaining clear video, throughout its entire field of view (wide angle to telephoto), even in pitch darkness.
The VB-H652LVE features a 122.1° wide angle of view and an Auto-Focus lens that can automatically adjust its focus for subjects both near and far, helping to ensure a clear image despite varying distances between the camera and subject matter. An Image Stabilization feature also helps ensure that the VB-H652LVE can deliver clear video with minimal motion blurring even when installed in areas with frequent vibrations such as on top of a pole or near heavy machinery. An analog video output can be connected to a monitor during installation of the VB-H652LVE to enable the installer to receive immediate feedback on the camera's field of view and focus.
With multiple power options including AC, DC, PoE and PoE+ and the fact that it uses a mere 8.4W of power when using PoE, this camera offers installation flexibility while lowering overall system power requirements.
When a situation calls for an outdoor-ready camera that can capture clear video even in areas with little-to-no visible light, choose Canon's VB-H652LVE Infrared Vandal Resistant Outdoor Fixed Dome Network Camera.
Features
Canon uses high refractive index glass and advanced optical processing technologies to produce high quality wide-angle lenses. The wide-angle monitoring capability gives this camera the ability to capture video of large areas, helping to reduce the number of cameras needed to effectively cover an area thus helping to control costs.
The 1/3" high-sensitivity CMOS sensor processes and transmits 1920 x 1080 (Full HD) video helping to capture finer details, even in challenging low-light conditions, which is critical for subject identification and other important security matters.
This camera's low-light performance is enhanced by Built-in Infrared (IR) Illuminators* that can be activated to enable the capture of bright, useful video throughout the entire field of view, even in areas where there is little to no visible light. This feature can allow for low-light visibility at 0.0 lux.
* IR illuminator operation requires either a 24 V AC or PoE+ power source.
A monitor can be connected to the analog out video terminal on this camera to receive a live video feed during installation. This allows the installer to adjust the pan, tilt, zoom and focus of this camera while watching the resulting video output. This feature can help reduce labor costs by expediting the installation process, as it allows a single installer to both install and position the camera without having to bring extra equipment up a ladder or return to a central location to check the camera's angle of view.
This camera was built with two vandal resistant elements to help ensure safety from impact and tampering. The enclosure has an IK10 rating, which specifies withstanding up to 20 joules of impact resistance, roughly the equivalent of a 10 pound bowling ball being dropped on it from a distance of 15 inches. In addition, the enclosure is equipped with tamper-resistant screws to help prevent entry into and removal of the unit.
An IP66 Rating means that the unit is both water resistant to powerful streams of water and dust tight, thus allowing this camera to be installed outdoors without the need for any additional protective equipment. (Not appropriate for underwater submersion).
This camera is NEMA 250 Type 4x certified which specifies resistance to frost and corrosion. This certification gives the installer peace of mind when mounting this camera in locations, such as ports and other areas near salt water, that are prone to frost and/or corrosion.
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
- Vivid, life-like color reproduction and image clarity
- Rich, smooth gradations
- Drastically reduced image noise
DIGIC NET II Processor is a powerful and efficient compression, encryption, and transmission processor that gives Canon Network Cameras the ability to simultaneously deliver full HD (1920 x 1080) video at 30 frames per second in both M-JPEG and H.264 codecs. Users have the flexibility of streaming multiple resolutions of M-JPEG and H.264, all while minimizing power consumption. In situations where remote cameras are using cellular data, users can potentially realize substantial savings in data charges.
Image Stabilization is an optional feature that can be used to help reduce motion blur caused by wind or mechanical vibration. The camera calculates the amount of vibration being experienced both horizontally and vertically and stabilizes the image by digitally removing pixels, which results in capturing video with minimized motion blurring.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
This network camera is equipped with an impressive selection of video capture settings that can be tailored to better accommodate environmental lighting changes, such as shifts in sunlight direction and during the transitions between day and night. Users are able to define presets that include settings such as shutter speed, gain, aperture, white balance, day/night mode and more in addition to the camera's pan/tilt/zoom position. These presets can be recalled on a schedule or can tie-in with the camera's automatic day/night switch options to help ensure high-quality video even in situations with varying ambient light conditions.
A host of optional on-board image optimization features were designed to maximize video image quality.
Haze Compensation automatically heightens contrast to display a clear image despite the presence of haze, fog or smog.
Smart Shade Control analyzes and selectively adjusts the exposure in overexposed and darkened areas.
Auto Gain Control Limit gives the user full control over the amount of digital gain applied when using auto exposure in low-light scenarios.
White Balance settings can be adjusted in order to compensate for different types of lighting to ensure color-accurate images.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems. This camera also supports ONVIF Profile G which specifies SD card recording, searching and streaming compatibility.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
The Low Power Consumption offered by this camera helps reduce the potential occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
The network camera accepts 24 V AC, 12 V DC, Power over Ethernet (PoE) and PoE+ offering flexibility when it comes to utilizing power sources available at the installation location.
The Built-in SD Card Slot, which supports microSD, microSDHC and microSDXC memory cards, provides temporary secondary storage for video data and camera logs. In addition, the memory card recording can be used in remote deployments to reduce the amount of additional hardware needed to store video.
Live images and H.264 video can be saved to the memory card during network outages, event triggers, at scheduled times and manually via the Camera Viewer. When issues occur, system logs can also be created on the memory card for future troubleshooting.
The Recorded Video Utility allows for searching, downloading and viewing the recorded video and the Canon Camera Management Tool allows for backing up and restoring camera settings to/from the memory card.
An optional "Auto Video Delete" feature allows the user to define a retention period for recorded videos (up to 90 days).
Multiple Networking Configuration, Security and Encryption Functions for Powerful Network Protection
This network camera can be installed in environments where a high level of network security is of extreme importance. It supports IEEE802.1X authentication, which provides additional network security with port-based access control that helps ensure only authorized client devices are connected to the network. In addition, IPSec is used to encrypt all packets of IP data sent over the network and SSL/TLS is used to safeguard data by encrypting sensitive information transmitted between a client and an application.
I/O support can be used to move the camera to a particular position or trigger an alarm when a door is opened or closed. An external microphone and speakers can be attached to this network camera so that the operator can hear what is going on at the camera location as well as playback audio files to people at that site.
CCMT provides a powerful, single unified method of configuring and managing all Canon network cameras on the local network. CCMT not only saves valuable time by streamlining the initial camera configuration, but greatly simplifies the management of an entire Canon network camera deployment. This tool supports network settings configuration, batch firmware upgrades, settings backup/restore, modifying video stream settings, and more.
CAMERA |
IMAGE SENSOR | 1/3" CMOS (RGB) |
NUMBER OF EFFECTIVE PIXELS | Approx. 2.1 million pixels |
ANALOG VIDEO RESOLUTION | |
ANALOG VIDEO STANDARD | |
ANALOG S/N RATIO | |
SCANNING METHOD | Progressive Scan |
LENS | 2.4x optical zoom lens with auto focus |
FOCAL LENGTH | 2.55 (W) - 6.12mm (T) |
F-NUMBER | F1.2 (W) - F1.8 (T) |
DIGITAL ZOOM | 4x |
HORIZONTAL VIEWING ANGLE (16:9) | 122.1° (W) - 50.1° (T) |
VERTICAL VIEWING ANGLE (16:9) | 65.9° (W) - 28.1° (T) |
DAY / NIGHT MODE | Yes |
I/R CUT FILTER | Automatically removable infrared-cut filter |
MIN. SUBJECT ILLUMINATION - DAY (COLOR) | 0.035 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE) |
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME) | 0 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE with IR light on) 0.002 lux (F1.2, shutter speed 1/30 sec., when smart shade control is off, 50IRE) |
FOCUS MODES | Auto/One-shot AF/Manual/Fixed at infinity |
SHOOTING DISTANCE | Day Mode: 0.3 m (12 in.) - infinity Night Mode: 0.3 m (12 in.) - infinity |
SHUTTER SPEED | 1 - 1/16000 sec. |
EXPOSURE MODES | Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Auto (Aperture-priority AE)/Manual (Shutter Speed, Aperture, Gain) |
WHITE BALANCE | Auto/Light Source/Manual Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/Halogen Lamp Manual: One-shot WB/R Gain/B Gain |
METERING MODES | Center-Weighted/Average/Spot |
EXPOSURE COMPENSATION | 9 levels |
SMART SHADE CONTROL | Auto/Manual/Disable Auto: 3 levels Manual: 7 levels |
HAZE COMPENSATION | Auto/Manual/Disable Auto: 3 levels Manual: 7 levels |
AGC LIMIT | 6 levels |
IMAGE STABILIZER | Digital (2 levels) |
PAN ANGLE RANGE | 360° (±180°) |
TILT ANGLE RANGE | 90° (-15° - +75°) |
ROTATION ANGLE RANGE | 350° (+220°/-130°) +: Clockwise |
IR ILLUMINATION RANGE | 20m (65.6ft) |
MOVING SPEED | Limited to manual movement |
SERVER |
VIDEO COMPRESSION METHOD | JPEG, H.264 |
BIT RATE CONTROL | Target Bit Rate: 64-16384 kbps |
VIDEO SIZE | JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270 1280 x 720, 640 x 360, 320 x 180 1280 x 960, 640 x 480, 320 x 240 |
SIMULTANIOUS VIDEO STREAMS | |
PLACE HOLDER | |
VIDEO QUALITY | JPEG, H.264: 10 levels |
FRAME RATE | JPEG: 0.1 - 30 fps H.264: 1/2/3/5/6/10/15/30 fps |
MAXIMUM FRAME RATE | 1920 x 1080 : 30fps |
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION | Number of Specified Areas: Max. 8 windows |
I-FRAME INTERVAL | 0.5/1/1.5/2/3/4/5 sec. |
SIMULTANIOUS CLIENT ACCESS | Max. 30 Clients + 1 Admin Client - H.264: Max. 10 Clients |
CAMERA CONTROL | Administrator, Authorized user, Guest user (level of control varies depending on user) |
ACCESS CONTROL | User authority (user name and password), Host Access Restrictions (IPv4, IPv6) |
ENCRYPTED COMMUNICATIONS | SSL/TLS, IPsec |
IEEE 802.1X | EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP |
ONVIF VERSION | Profile S, Profile G |
IPv4 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
IPv6 PROTOCOL | TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary) |
AUTO IP (LINK-LOCAL) | Yes |
AUDIO COMPRESSION METHOD | G.711 μ-law (64 kbps) |
AUDIO COMMUNICATION METHOD | Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon |
AUDIO FILE PLAYBACK | Available (audio files can be played back when an event is triggered by the intelligent function or external device input) |
PRIVACY MASK | Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors) |
VIEW RESTRICTION | Available |
PRESETS | Number of registers: Max. 20 positions (+Home Position) Number of Preset Tour Route: Max. 1 |
INTELLIGENT FUNCTION - VIDEO | Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection |
INTELLIGENT FUNCTION - AUDIO | Volume Detection, Scream Detection |
INTELLIGENT FUNCTION - DETECTION SETTINGS | Max. 15 |
EVENT TRIGGER TYPE | External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch |
IMAGE UPLOAD | FTP/HTTP/SMTP (e-mail) |
EVENT NOTIFICATION | HTTP/SMTP (e-mail) |
ON-SCREEN DISPLAY | Available |
IMAGE CROPPING FUNCTION | Digital PTZ Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72 640 x 480/512 x 384/384 x 288/256 x 192/128 x 96 |
DAYLIGHT SAVING TIME | Available |
CUSTOM SETTINGS | Available |
INTERFACE |
NETWORK TERMINAL | LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex)) |
AUDIO INPUT TERMINAL | Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) LINE IN (connect to an amplifier microphone) or MIC IN (connect to a microphone w/o amplifier) - Switch LINE IN/MIC IN in the setting page. |
AUDIO OUTPUT TERMINAL | Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker) |
EXTERNAL DEVICE I/O TERMINAL | Input x 2, Output x 2, 1x Analog Video Output |
ANALOG VIDEO OUT | Available (only for checking camera angle) |
MEMORY CARD TYPE | microSD Memory Card, microSDHC Memory Card, microSDXC Memory Card Compatible. |
MEMORY CARD RECORDED CONTENT | Log, Video (Event, Manual, ONVIF, Timer, Upload) |
MEMORY CARD RECORDED FRAME RATE | Max. 1 fps (JPEG) Max. 30 fps (H.264) |
OPERATING ENVIRONMENT |
TEMPERATURE | When the heater unit (sold separately) is installed Operating Temperature Range: AC, PoE+: -40°C - +55°C (-40°F - +131°F) DC, PoE: -10°C - +55°C (+14°F - +131°F) Start-up Temperature Range: AC, PoE+: -30°C - +55°C (-22°F - +131°F) DC, PoE: -10°C - +55°C (+14°F - +131°F) - Sunshade cover (sold separately) necessary when under direct sun exposure When the heater unit (sold separately) is not installed AC, DC, PoE+, PoE: -10°C - +55°C (+14°F - +131°F) - Sunshade cover (sold separately) necessary when under direct sun exposure |
HUMIDITY | 5% - 85% (without condensation) |
STORAGE ENVIRONMENT |
TEMPERATURE | -30°C - +60°C (-22°F - +140°F) |
HUMIDITY | 5% - 90% (without condensation) |
POWER SUPPLY |
PoE | PoE power supply via LAN connector (IEEE802.3at Type1/Type2 compliant) |
AC ADAPTER | PA-V18 (100 - 240 V AC) (sold separately) |
EXTERNAL POWER SOURCE | 24 V AC/12 V DC |
POWER CONSUMPTION |
WITH PoE | 12.4W |
WITH AC ADAPTER | AC Adapter PA-V18: Max. approx. 15.2 W (100 V AC) Max. approx. 15.2W (240 V AC) |
WITH 12VDC | 13.8W |
WITH PoE + | 23.1W (with heater installed) 12.4W (no heater installed) |
WITH 24VAC | 24.1W (with heater installed) 12.7W (no heater installed) |
OTHER |
DIMENSIONS | (Φ; x H) Φ180 x 145 mm (Φ7.09 x 5.71 in.) |
MOUNTING POSITION | |
HEATER | Optional |
WEIGHT | Approx. 1850 g (4.08 lb.) |
OUTDOOR READY | Yes |
IP RATING | IP66 |
VANDAL RESISTANT | Yes |
IMPACT RESISTANCE | IK10 (20J) |
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-H652LVE that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
A-BK3(OW)
Pole Mount Adapter and 59" length Non-Tool Aluminum Clamp (Minimum Pole Diameter 4")
A-BK3(OW)
A-BK3S POLE MOUNT ADAPTER
A-CM3 CORNER MOUNT ADAPTER
A-SWD5ZWB-2
Attachment Plate for A-SWD5ZWB (Required if installing VB-M600)
A-SWD5ZWB-2
A-SWD5ZWB600
A-SWD5ZWB600
DU652-S-VB
HU652-VB
Pendant Mounting Kit PC640-VB
Kit used to connect camera to 1.5" NPS pipe.
RM-Lite-V Network Video Monitoring and Recording Software
One (1) viewer license for RM-Lite Network Video Monitoring and Recording Software. (License only, no software included)
Sunshade Cover SC640-VB
Cover used to protect camera from prolonged exposure to direct sunlight when wall mounted.
Brochures
A&E System Design Tools
Angle of View Calculator
Choose the camera with the required distances, scene sizes and focal lengths.
Note: For best results, please view the Calculator on either a desktop or laptop screen.
Angle of View Calculator >
Required Disk Space Calculator
Determine your surveillance system's hard drive storage space needs.
Required Disk Space Calculator >
Camera Layout Simulator
Place your cameras into a simulated environment to determine video coverage area.
Camera Layout Simulator >
DISCLAIMERS
This is a class A product. In a domestic environment this product may cause radio inference in which case the user may be required to take adequate measures.
©2016 Canon U.S.A., Inc. All rights reserved. Canon and DIGIC are registered trademarks of Canon Inc. in the United States and may also be trademarks or registered trademarks in other countries. “ONVIF” and are trademarks of ONVIF Inc.. Some of the images and effects are simulated. Not responsible for typographical errors.
