Web Content Viewer
Actions
VB-H751LE
All Network Cameras
Item Code: 1386C001AA
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
Canon uses high refractive index glass and advanced optical processing technologies to produce high quality wide-angle lenses. The wide-angle monitoring capability* gives this camera the ability to take video of large areas, helping to reduce the number of cameras needed to effectively cover a region thus helping to control costs.
*The VB-H751LE Network Camera is equipped with a 124.3° Wide-Angle Lens.
The 1/3" high-sensitivity CMOS sensor processes and transmits 1920 x 1080 (Full HD) video helping to capture finer details, even in challenging low-light conditions, which is critical for subject identification and other important security matters.
This camera's low-light performance is enhanced by Built-in Infrared (IR) Illuminators that can be activated to enable the capture of bright, useful video throughout the entire field of view - even in areas where there is little to no visible light. This feature can allow for low-light visibility at 0.0 lux from significant distances. IR illuminator operation requires either a 24 V AC or PoE+ power source.
The VB-H751LE has four built-in IR emitters (2 IR lights for wide-angle visibility and 2 IR lights for long-range visibility) that allow for the delivery of virtually clear video in complete darkness from a distance of up to 98.4 ft.
An IP66 Rating means that the unit is both water resistant to powerful streams of water and dust tight, thus allowing this camera to be installed outdoors without the need for any additional protective equipment. (Not appropriate for underwater submersion).
This camera is NEMA 250 Type 4x certified which specifies resistance to frost and corrosion. This certification gives the installer peace of mind when mounting this camera in locations, such as ports and other areas near salt water, that are prone to frost and/or corrosion.
This camera has a built-in heater that allows it to operate in extremely cold environments with temperatures as low as -58°F. With its cold startup feature, when the camera is initially powered on the heater will be activated to warm up the camera to its minimum startup temperature. Once the camera reaches a safe level of warmth, all remaining systems will power on and the camera will function within the allowable temperature range of -58°F to +131°F. The built-in heater can be operated with an AC or PoE+ power source.
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
  • Vivid, life-like color reproduction and image clarity
  • Rich, smooth gradations
  • Drastically reduced image noise
A host of optional on-board image optimization features were designed to maximize video image quality.
Haze Compensation automatically heightens contrast to display a clear image despite the presence of haze, fog or smog.
Smart Shade Control analyzes and selectively adjusts the exposure in overexposed and darkened areas.
Auto Gain Control Limit gives the user full control over the amount of digital gain applied when using auto exposure in low-light scenarios.
White Balance settings can be adjusted in order to compensate for different types of lighting to ensure color-accurate images.
This camera has a one-way moisture release vent that allows for efficient disposal of any excess moisture that builds up in the enclosure. A blower will circulate air throughout the inside of the enclosure, simultaneously removing excess moisture. This feature helps ensure that the viewing surface of the enclosure will not fog up and contributes to the long life-span of this unit.
Image Stabilization is an optional feature that can be used to help reduce motion blur caused by wind or mechanical vibration. The camera calculates the amount of vibration being experienced both horizontally and vertically and stabilizes the image by digitally removing pixels, which results in capturing video with minimized motion blurring.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems. This camera also supports ONVIF Profile G which specifies SD card recording, searching and streaming compatibility.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
The network camera accepts 24 V AC, 12 V DC, Power over Ethernet (PoE) and PoE+ offering flexibility when it comes to power sources in the installation environment.
This optional feature allows cameras to be installed in areas even if there are restrictions on what can be recorded, as a digital mask can be applied to up to 8 sections within the camera's field of view. This prevents the user from seeing any sensitive material that may be behind the masked area, such as an ATM machine displaying banking information.
The Low Power Consumption offered by this camera helps reduce the occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
SCANNING METHOD
Progressive Scan
LENS
2.4x optical zoom lens (electric drive)
FOCAL LENGTH
2.55 (W) - 6.12 mm (T)
F-NUMBER
F1.2 (W) - F1.8 (T)
DIGITAL ZOOM
4x
HORIZONTAL VIEWING ANGLE
124.3° (W) - 50.5° (T)
VERTICAL VIEWING ANGLE
66.9° (W) - 28.4° (T)
DAY / NIGHT MODE
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
.035 lux (F1.2, shutter speed 1/30 sec.)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
0 lux (F1.2, shutter speed 1/30 sec., IR light on)
.002 lux (F1.2, shutter speed 1/30sec., IR light off)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3 m (12 in.) - infinity
Night Mode: 0.3 m (12 in.) - infinity
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/ Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
MOTION ADAPTIVE NOISE REDUCTION
Available
CLEAR IR
N/A
PAN ANGLE RANGE
344° (-217° - +127°)
TILT ANGLE RANGE
93° (-3° - +90°)
ROTATION ANGLE RANGE
344° (±172°)
IR ILLUMINATION RANGE
30 m (98.4 ft.) (When using 24 V AC, PoE+) 15 m (When using PoE/12 V DC)
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64-16384 kbps
VIDEO SIZE
JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
JPEG, H.264 (1920 x 1080): 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
Profile S, Profile G
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP(LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
G.711 μ-law (64 kbps)
AUDIO COMMUNICATION METHOD
Full-duplex (two-way) - Echo cancellation function compliant RTP, Sound Transfer Protocol by Canon
AUDIO FILE PLAYBACK
Available (audio files can be played back when an event is triggered by the intelligent function or external device input.)
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
N/A
PRESETS
Number of registers: Max. 20 positions (+Home Position) Number of Preset Tour Route: Max. 1
INTELLIGENT FUNCTION - VIDEO
Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO
Volume Detection, Scream Detection
INTELLIGENT FUNCTION - DETECTION SETTINGS
Max. 15
EVENT TRIGGER TYPE
External Device Input, Intelligent Function (Video), Intelligent Function (Audio), Timer, Day/Night Switch
Number of Linked Events: 2 Linked Event Conditions: AND, OR (whether or not there is a sequence to events)
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM
N/A
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
TBD
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) Switch LINE IN/MIC IN in the setting page.
AUDIO OUTPUT TERMINAL
Φ3.5 mm (Φ0.14 in.) mini-jack connector (monaural) LINE OUT (connect to an amplifier speaker)
EXTERNAL DEVICE I/O TERMINAL
Input x 2, Output x 2
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Operating Temperature Range (including direct sun exposure)
AC, PoE+: -50°C - +55°C (-58°F - +131°F)
DC, PoE: -10°C - +55°C (+14°F - +131°F)
Start-up Temperature Range (including direct sun exposure)
AC, PoE+: -30°C - +55°C (-22°F - +131°F)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
IEEE802.3af Class 0 (PoE) / IEEE802.3at (PoE+)
AC ADAPTER
PA-V18 (100 - 240 V AC) (sold separately)
EXTERNAL POWER SOURCE
24 V AC/12 V DC
MAXIMUM POWER CONSUMPTION
WITH PoE
Max. approx. 10.2W
WITH AC ADAPTER
AC Adapter PA-V18: Max. approx. 12.5 W (100 V AC)
Max. approx. 12.6 W (240 V AC)
WITH 12VDC
Max. approx. 11.2W
WITH PoE +
Max. approx. 20.1W
WITH 24VAC
Max. approx. 20.9W
OTHER
DIMENSIONS
(H x W x D) 111 x 102 x 214 mm (4.37 x 4.02 x 8.43 in.) (camera body only)
- Length when joint fully extended (D): 402 mm (15.83 in.)
MOUNTING POSITION
Ceiling mount/Surface mount
HEATER
Built-in
WEIGHT
Approx. 2600 g (5.74 lb.)
OUTDOOR READY
Yes
IP RATING
IP66
VANDAL RESISTANT
No
IMPACT RESISTANCE
N/A
This is to make Misc appear on the page when needed.
VB-H751LE Network Camera Camera, Screws (M4) x 4 Setup CD-ROM Waterproofing packing I/O & Audio Interface Cable (BK200057-000) GND Screw (M3) x 1 Waterproofing explanation Sheet Template Warranty Card Safety Wire, Screws (M3) x 1 LAN Cable Cap Zip Tie (for LAN Cable) Installation Guide Ceiling Plate Dedicated wrench Waterproofing Tape
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-H751LE that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
