Web Content Viewer
Actions
VB-H760VE
All Network Cameras
Item Code: 1063C001AA
NETWORK VIDEO PRODUCTS NOW SOLD BY AXIS COMMUNICATIONS (A CANON GROUP COMPANY). Learn more on the Axis Communications website.
Learn about our Network Video Solutions Software Developers Kit (API).
Find out which technology partners integrate with Canon Network Cameras.
Features
Clear video, even from long distances, can be captured thanks to the advanced optical technologies and high level of magnification of this Genuine Canon 20x Optical Zoom Lens. The optical zoom function uses a mechanical lens adjustment to increase the size of the subject or area of interest by up to 20 times allowing for greater image detail and clarity. Unlike digital zoom, optical zoom typically results in a clean image that is virtually free from pixilation and blurring.
The 1/3" high-sensitivity CMOS sensor processes and transmits 1920 x 1080 (Full HD) video helping to capture finer details, even in challenging low-light conditions, which is critical for subject identification and other important security matters.
An IP66 Rating means that the unit is both water resistant to powerful streams of water and dust tight, thus allowing this camera to be installed outdoors without the need for any additional protective equipment. (Not appropriate for underwater submersion).
This camera was built with two vandal resistant elements to help ensure safety from impact and tampering. The enclosure has an IK09 rating, which specifies withstanding up to 10 joules of impact resistance, roughly the equivalent of a 10 pound bowling ball being dropped on it from a distance of 7 inches. In addition, the enclosure is equipped with tamper-resistant screws to help prevent entry into and removal of the unit.
This camera is NEMA 250 Type 4x certified which specifies resistance to frost and corrosion. This certification gives the installer peace of mind when mounting this camera in locations, such as ports and other areas near salt water, that are prone to frost and/or corrosion.
For maximized image quality, Canon has incorporated the same DIGIC DV III Image Processor used in many of its high-end DSLR cameras in order to reproduce video with life-like colors, tonal accuracy, smooth gradation and reduced noise. Unlike other cameras that rely on a shared processor for image quality and compression, Canon network cameras are engineered with a DIGIC DV III Image Processor solely dedicated to maximizing image quality.
Canon's DIGIC DV III Image Processor is a high-speed engine with maximum processing power which helps to optimize overall video quality with:
  • Vivid, life-like color reproduction and image clarity
  • Rich, smooth gradations
  • Drastically reduced image noise
A host of optional on-board image optimization features were designed to maximize video image quality.
Haze Compensation automatically heightens contrast to display a clear image despite the presence of haze, fog or smog.
Smart Shade Control analyzes and selectively adjusts the exposure in overexposed and darkened areas.
Auto Gain Control Limit gives the user full control over the amount of digital gain applied when using auto exposure in low-light scenarios.
White Balance settings can be adjusted in order to compensate for different types of lighting to ensure color-accurate images.
This camera has a one-way moisture release vent that allows for efficient disposal of any excess moisture that builds up in the enclosure. A blower will circulate air throughout the inside of the enclosure, simultaneously removing excess moisture. This feature helps ensure that the viewing surface of the enclosure will not fog up and contributes to the long life-span of this unit.
The Enhanced Digital Zoom function can be used to get even closer to the subject without loss of video quality when optical zoom is not enough. With this feature, the camera streams a lower resolution digital crop of the original video, as opposed to digital zoom which manipulates the image to make the subject appear larger by increasing pixel sizes and reducing image quality. Enhanced Digital Zoom typically produces a higher-quality image than digital zoom while significantly lowering the amount of bandwidth and storage space needed to transmit and retain the video.
Image Stabilization is an optional feature that can be used to help reduce motion blur caused by wind or mechanical vibration. The camera calculates the amount of vibration being experienced both horizontally and vertically and stabilizes the image by digitally removing pixels, which results in capturing video with minimized motion blurring.
Motion Adaptive Noise Reduction helps reduce overall bandwidth consumption and lower the costs associated with transmitting data, while providing clean images in low light areas where motion is detected. Areas without motion receive added noise reduction thus minimizing bandwidth consumption, while areas with motion receive a smaller amount of noise reduction resulting in greater visual clarity for optimized monitoring and surveillance.
Area-Specific Data Size Reduction (ADSR) is an optional function that allows users to reduce bandwidth consumption and video storage space requirements, thus lessening the need for expensive networking and storage equipment. The reduction in bandwidth and storage is achieved by defining up to eight specific areas in the camera's field of view which are most critical and where high video quality must be maintained, while video quality in the rest of the camera's field of view is lowered.
A host of intelligent On-board Video Analytics have been built into the camera to aid in analyzing video content for the purposes of identifying and alerting potentially critical situations. For maximum flexibility, detection characteristics (sensitivity, area and duration) can be finely tuned by users to allow for precise event detection by the camera, while notification tools can alert the correct parties to help expedite response time. In addition, costly storage space can be saved by using these On-board Video Analytics as triggers to start recording so that the camera does not have to continuously record during all hours of the day.
Moving Object Detection - used to detect moving objects, such as persons or vehicles, in predefined areas such as hallways and parking lots.
Abandoned Object Detection - used to identify motionless objects that have been left behind by a moving object such as a suspicious package placed on a city street.
Removed Object Detection - used to identify the removal of a static object from a designated area, such as a priceless painting in a museum/gallery.
Camera Tampering Detection - used to detect the tampering of a camera such as redirection, blocking, defocusing, or even spray paint.
Passing Detection - used to detect when a moving object passes through the camera's field of view in a specified direction, such as an individual entering into a restricted area from the exit doorway.
Intrusion Detection - used to identify when a moving object enters and remains in a specified area for a period of time deemed unacceptable, such as an individual stepping over a partition in a museum.
The Open Network Video Interface Forum (ONVIF) is a growing industry standard that promotes interoperability of security devices and eliminates the need for custom drivers. This network camera supports ONVIF Profile S which helps ensure that basic features such as video streaming, pan / tilt / zoom control, audio streaming and more, will work properly with a wide array of VMS systems. This camera also supports ONVIF Profile G which specifies SD card recording, searching and streaming compatibility.
Camera Viewer with Mobile Device Support allows user to access the camera's functionality from any location via the web browser on their PC or mobile device. The "Mobile Viewer" interface is designed to provide easy control of the essential functions necessary to operate the camera (video stream, pan/tilt/zoom control, presets, exposure settings, etc.) via the touch screens of mobile iOS or Android devices. Installers can also quickly configure their camera at the installation site and remotely control it.
This optional feature allows cameras to be installed in areas even if there are restrictions on what can be recorded, as a digital mask can be applied to up to 8 sections within the camera's field of view. This prevents the user from seeing any sensitive material that may be behind the masked area, such as an ATM machine displaying banking information.
Power over Ethernet (PoE) is a single cable solution which allows more flexibility in choosing installation locations by eliminating the constraint of requiring AC power outlets nearby. Additionally, the cost of cable installation is reduced because a dedicated power cable is no longer necessary to operate the camera.
The Low Power Consumption offered by this camera helps reduce the occurrence of overheating and failure. In addition, overall system power requirements are lessened, potentially giving the user the ability to save on energy, back-end equipment and hardware costs while lowering environmental impact.
CAMERA
IMAGE SENSOR
1/3" CMOS (RGB)
NUMBER OF EFFECTIVE PIXELS
Approx. 2.1 million pixels
SCANNING METHOD
Progressive Scan
LENS
20x optical zoom lens with auto focus
FOCAL LENGTH
4.7 (W) - 94 mm (T)
F-NUMBER
F1.6 (W) - F3.5 (T)
DIGITAL ZOOM
20x
HORIZONTAL VIEWING ANGLE
60.4° (W) - 3.2° (T)
VERTICAL VIEWING ANGLE
35.1° (W) - 1.8° (T)
DAY / NIGHT MODE
Yes
I/R CUT FILTER
Automatically removable infrared-cut filter
MIN. SUBJECT ILLUMINATION - DAY (COLOR)
.06 lux (F1.6, shutter speed 1/30 sec.)
MIN. SUBJECT ILLUMINATION - NIGHT (MONOCHROME)
.003 lux (F1.6, shutter speed 1/30 sec.)
FOCUS MODES
Auto/One-shot AF/Manual/Fixed at infinity
SHOOTING DISTANCE
Day Mode: 0.3 m (12 in.) - infinity (W), 1.0 m (3.3 ft.) - infinity (T)
Night Mode: 1.0 m (3.3 ft.) - infinity (W), 1.5 m (4.9 ft.) - infinity (T)
SHUTTER SPEED
1 - 1/16000 sec.
EXPOSURE MODES
Auto/Auto (Flickerless)/Auto (Shutter-priority AE)/Manual (Shutter Speed, Aperture, Gain)
WHITE BALANCE
Auto/Light Source/Manual
Light Source: Daylight Fluorescent/White Fluorescent/Warm Fluorescent/Mercury Lamp/Sodium Lamp/
Halogen Lamp
Manual: One-shot WB/R Gain/B Gain
METERING MODES
Center-Weighted/Average/Spot
EXPOSURE COMPENSATION
9 levels
SMART SHADE CONTROL
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
HAZE COMPENSATION
Auto/Manual/Disable
Auto: 3 levels
Manual: 7 levels
AGC LIMIT
6 levels
IMAGE STABILIZER
Digital (2 Levels)
MOTION ADAPTIVE NOISE REDUCTION
Available
CLEAR IR
N/A
PAN ANGLE RANGE
348° (±174°)
TILT ANGLE RANGE
90°
ROTATION ANGLE RANGE
360° (±180°)
IR ILLUMINATION RANGE
N/A
MOVING SPEED
N/A
SERVER
VIDEO COMPRESSION METHOD
JPEG, H.264
BIT RATE CONTROL
Target Bit Rate: 64-16384 kbps
VIDEO SIZE
JPEG, H.264: 1920 x 1080, 960 x 540, 480 x 270
1280 x 720, 640 x 360, 320 x 180
1280 x 960, 640 x 480, 320 x 240
SIMULTANIOUS VIDEO STREAMS
VIDEO QUALITY
JPEG, H.264: 10 levels
FRAME RATE
JPEG: 0.1 - 30 fps
H.264: 1/2/3/5/6/10/15/30 fps
MAXIMUM FRAME RATE
1920 x 1080 : 30fps
ADSR: AREA-SPECIFIC DATA SIZE REDUCTION
Number of Specified Areas: Max. 8 windows
I-FRAME INTERVAL
0.5/1/1.5/2/3/4/5 sec.
SIMULTANIOUS CLIENT ACCESS
Max. 30 Clients + 1 Admin Client
- H.264: Max. 10 Clients
CAMERA CONTROL
Administrator, Authorized user, Guest user (level of control varies depending on user)
ACCESS CONTROL
User authority (user name and password), Host Access Restrictions (IPv4, IPv6)
ENCRYPTED COMMUNICATIONS
SSL/TLS, IPsec
IEEE 802.1X
EAP-MD5, EAP-TLS, EAP-TTLS, EAP-PEAP
ONVIF Version
Profile S, Profile G
IPv4 PROTOCOL
TCP/IP, UDP, HTTP, FTP, SNMPv1/v2c/v3 (MIB2), DHCP, DNS, AutoIP, mDNS, ARP, ICMP, POP3, NTP, SMTP, RTP/RTCP, RTSP, SSL/TLS, IPsec, ONVIF, WV-HTTP (Canon proprietary)
IPv6 PROTOCOL
AUTO IP(LINK-LOCAL)
Yes
AUDIO COMPRESSION METHOD
N/A
AUDIO COMMUNICATION METHOD
N/A
AUDIO FILE PLAYBACK
N/A
PRIVACY MASK
Number of registration: Max. 8 places, Number of mask colors: 1 (select from 9 colors)
VIEW RESTRICTION
Available
PRESETS
Number of registers: Max. 20 positions (+Home Position)
Number of Preset Tour Route: Max. 5
INTELLIGENT FUNCTION - VIDEO
Detection Types: Moving Object Detection, Abandoned Object Detection, Removed Object Detection, Camera Tampering Detection, Passing Detection, and Intrusion Detection
INTELLIGENT FUNCTION - AUDIO
N/A
INTELLIGENT FUNCTION - DETECTION SETTINGS
N/A
EVENT TRIGGER TYPE
Intelligent Function (Video), Timer, Day/Night Switch
IMAGE UPLOAD
FTP/HTTP/SMTP (e-mail)
EVENT NOTIFICATION
HTTP/SMTP (e-mail)
ON-SCREEN DISPLAY
Available
IMAGE CROPPING FUNCTION
Digital PTZ
Cropping sizes: 640 x 360/512 x 288/384 x 216/256 x 144/128 x 72
640 x 480/512 x 384/384 x 288/256 x 192/128 x 96
ENHANCED DIGITAL ZOOM
Available
DAYLIGHT SAVING TIME
Available
CUSTOM SETTINGS
TBD
INTERFACE
NETWORK TERMINAL
LAN x 1 (RJ45, 100Base-TX (auto/full-duplex/half-duplex))
AUDIO INPUT TERMINAL
N/A
AUDIO OUTPUT TERMINAL
N/A
EXTERNAL DEVICE I/O TERMINAL
N/A
ANALOG VIDEO OUT
N/A
MEMORY CARD TYPE
SD Memory Card, SDHC Memory Card, SDXC Memory Card Compatible
MEMORY CARD RECORDED CONTENT
Log, Video (Event, Manual, ONVIF, Timer, Upload)
MEMORY CARD RECORDED FRAME RATE
Frame Rate: Max. 1 fps (JPEG)
Max. 30 fps (H.264)
OPERATING ENVIRONMENT
TEMPERATURE
Operating Temperature Range (including direct sun exposure)
PoE: -10°C - +55°C  (+14°F - +131°F)
Start-up Temperature Range (including direct sun exposure)
HUMIDITY
Humidity: 5% - 85% RH (without condensation)
STORAGE ENVIRONMENT
TEMPERATURE
-30°C - +60°C (-22°F - +140°F)
HUMIDITY
5% - 90% RH (without condensation)
POWER SUPPLY
PoE
IEEE802.3af Class 0
AC ADAPTER
N/A
EXTERNAL POWER SOURCE
N/A
MAXIMUM POWER CONSUMPTION
WITH PoE
Max. Approx 7.4W
WITH AC ADAPTER
N/A
WITH 12VDC
N/A
WITH PoE +
N/A
WITH 24VAC
N/A
OTHER
DIMENSIONS
(H x W x D) 111 x 102 x 252 mm (4.37 x 4.02 x 9.92 in.) (camera body only)
- Length when joint fully extended (D): 455 mm (17.91 in.)
MOUNTING POSITION
Ceiling mount/Surface mount
HEATER
N/A
WEIGHT
Approx. 3360 g (7.41 lb.)
OUTDOOR READY
Yes
IP RATING
IP66
VANDAL RESISTANT
Yes
IMPACT RESISTANCE
IK09 (10J)
This is to make Misc appear on the page when needed.
VB-H760VE Network Camera
VB-H760VE Network Camera Camera, Screws (M4) x 4 Setup CD-ROM Waterproof packing Template Warranty Card Safety Wire, Screws (M3) x 1 LAN Cable Cap Installation Guide Ceiling Plate Dedicated wrench Zip Tie (for LAN cable)
Brochures
Loading...
Canon offers a wide range of compatible supplies and accessories that can enhance your user experience with you VB-H760VE that you can purchase direct. Scroll down to easily select items to add to your shopping cart for a faster, easier checkout. Visit the Canon Online Store
Expand All
 Return to Top
